Old 12-05-2011, 10:23 PM   #1
C15_Sierra
C15_Sierra's Avatar
Starter wiring
Maybe I'm overthinking this and there's a really simple answer...but here it is
Truck is a 1980 GMC, swap engine is a 5.3L from a '00 Silverado, right now I'm using the stock underhood fuse block from the Silverado to power my engine harness
I've gone as far as I can on my own to figure out what I need to connect to the cab in order to get everything turning. Online diagrams aren't helping (even tho they should, maybe I'm just an electrical idiot? ). I've identified some of the wires on the engine side of the firewall that go into the cab, but not all of them. I'd post pics if they would help, but its such a clusterf**k that it'll probably better serve to confuse than to help.
-What wires do I need to connect to the battery/ignition switch/charging circuit?
-Is there a specific/separate input that goes into the fuse block for the starter solenoid?
I'll probably have more questions as I knock out the final wiring stages, so please bear with me...you guys rulel
-Steve
1980 GMC C15 Sierra LWB
Dark Carmine Red/Carmine Int
Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011)
Now: 5.3/4L60E, 2.73 12-bolt open rear
C15_Sierra is offline   Reply With Quote
Old 12-06-2011, 09:06 AM   #2
Clyde65
Clyde65's Avatar
Re: Starter wiring
The only wires I hooked up between the swap and my original harness was one ign hot and one always hot connection, plus the brake/TCC, VSS and then running a #8 wire from alternator lug to the starter power lug
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-06-2011, 07:51 PM   #3
C15_Sierra
C15_Sierra's Avatar
Re: Starter wiring
Huh...I guess I am overthinking it. Now comes the question of which wires are which - I cut all wires going from the cab to the old engine...that was 7 months ago. But I guess that's more of a question for the 73-87 guys...thanks!
-Steve
