Old 12-05-2011, 03:55 PM   #1
Scrat
Scrat's Avatar
72 Blazer got the shakes bad - HELP
Hi All.
So I have a '72 Blazer that has an annoying shake/shimmy at 65mph. (It feels like a tire is out of balance) It starts to shake around 55-60 and is worst at 65 and then is better at about 70. I know, no biggie, drive 75 but my problem is the road I travel on mostly has a 65mph speed limit. I've been dealing with this for years now and dont drive the blazer as much as I'd like because of it. I cannot replicate the problem in the shop, only on the road.
What have I tried so far...
Balancing the tires, new tires, checking the axles/wheels for runout.
New shocks all the way around including steering stabilizer
rebuilt rear end - new bearings and axles
repack/check hubs etc on front end and new ball joints
new u joints/ balance drive shafts
New/rebuilt drive train including engine/tranny/transfer case
installed power steering
All this and I still have the shakes. Anybody else have anything like this happen? What did you do? Is there anything I have left out/overlooked?
I'm thinking my next step is to do body bushings and suspension (lift 3"). Perhaps the springs are shot ? I dunno.
Thanks for any help or guidance.
(pics to follow )
Scrat is offline   Reply With Quote
Old 12-05-2011, 05:59 PM   #2
cleszkie
cleszkie's Avatar
Re: 72 Blazer got the shakes bad - HELP
Is the shake/shimmy in the steering wheel, or in the seat of your pants? If in the seat of your pants, you may be dealing with a driveline balance/worn u-joint issue). If its in the steeing wheel, its probably an alignment issue. Are you running a lift and oversized tires? The reason I ask is that when you install a lift kit, the camber and caster settings on the front axle can get out of whack when the axle tube is rotated to mount the the new spring packs. It only takes a few degrees of change to affect things. Running oversized tires further aggravates the situation by amplifying the resonant wobble. I suggest you get the front end professionally aligned. However, a lot of shops will only be able to adjust the camber, which will not fully elimnate your problem. You may have to source out some shims to put your caster back to spec before you have the camber set. Good luck.
cleszkie is offline   Reply With Quote
Old 12-05-2011, 06:30 PM   #3
Scrat
Scrat's Avatar
Thanks for the reply. I should have mentioned: Its a stock blazer at stock height (no lift yet) running 10 -15 LTs (stock tires). The suspension is original (and may just be tired).
The shake is in the "seat of my pants" (no comment =-P ) .
Already tried new u joints and balancing drive shafts and tires.
Old 12-05-2011, 06:40 PM   #4
Steve-W
Steve-W's Avatar
Hmmm this is a difficult one.. my first thought was; did you balance the wheels while still on the car? some shops have a small car-like thingy they ride up against your wheel and then balance it while mounted. sometime balancing components seperatly isn't enough.
If you're suspension is so bad it starts dancing around by itself you must notice it when driving over speedbumps, or offroad-ish conditions. a shot damper will be noticed, clonky sound while going over bumps, body roll etc.
wheel alignment could possible be a factor, but then your car would most likely be pulling into one direction when you let go of the steering wheel. Let alone the tire wear and the 'off' reaction to direction changes. if you do realing, try to go to a place where they do the 4-wheel allignments.
I'll toss this one into my think tank and see if they can come up with a solution.
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 12-05-2011, 10:32 PM   #5
bweezy
bweezy's Avatar
Maybe loose/worn body mounts?
bweezy is offline   Reply With Quote
Old 12-05-2011, 10:39 PM   #6
pound41
My friend had a 90 ram 250 4x4 that was 8-9yrs old he told me he was driving on the highyway 55-65 mph and the front end on his truck started shaking/bouncing and he said it got worse and was like going over 1 million moguls or a low rider bouncing a hundred bounces a minute. He was scared. Said it was scary as hell he couldn't turn the wheel just hang on. I laughed at him and one day we were on the highway Washington DC semi rush hour it started doing it and I was shocked. people could see it in other cars and they started slowing down to get away. it finally stopped and we went home. I told my Dad who had owned a gas station for 40 years at the time and he knew exactly what I was talking about. Told my friend to take it to a Spring front end shop and they fixed it. My dad told him what to tell them. My Dad has since passed away or I would ask him but I am thinking it had to do with the springs
pound41 is offline   Reply With Quote
Old 12-06-2011, 12:21 AM   #7
richard2717
Equal opportunity joke ofender
richard2717's Avatar
took one of my heavy trucks to the spring shop and they said it had way to much camber (6.5 degrees) backed it off to 3.2 and it has not done it since, but mine was shaking in the steering
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 12-06-2011, 06:31 AM   #8
old man jimmy
not knowing who or how they ballanced your drive shaft. I would be looking into making sure it's not tweaked. Put it in a couple v blocks, and put a dial indicator on it while you turn it. should give you a rough idea. especially if it's a 4 speed. They have a nasty habit of blowing u-joints, and hitting the ground hard enough to bend.
old man jimmy is offline   Reply With Quote
Old 12-06-2011, 10:14 AM   #9
71RestoRod
71RestoRod's Avatar
65 MPH is right in the "first harmonic" zone so I would bet dollars for donuts you're looking at a wheel/tire problem. Is it possible that you have a bent rim?
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 12-06-2011, 04:24 PM   #10
Scrat
Scrat's Avatar
Thanks for all the replies and suggestions/information guys...
I checked the runout on the wheels/rims with them on the blazer with a dial indicator - they seem good, all less than 1/16" out of round.
The shake/bounce is definately not in the steering wheel.
The shop that balanced the driveshaft is a reputable shop and it doesnt seem out of round nor does it throw u joints. (I'll check it for runout with the dial indicator though)
This blazers been in my family since it was born and I know it was never riden hard and put away wet so to speak.
Speedbumps/offroad, no problems/clucks or funny noises.
I'm thinking about having my wife video tape me driving down the freeway (focusing on the drivetrain/tires) from her car so that I might be able to see a tire bouncing or something... I dunno still.
Worn spring bushings?
Old 12-06-2011, 05:39 PM   #11
Steve-W
Steve-W's Avatar
OFFTOPIC:
I can just see this ending up on youtube, but not the way you intended it
sound a bit hazerdous to me! (My wife would end up with a great video totalling her car hahahaha)
back on topic
projects:
1969 Chevy C10
1950 GMC 100
Old 12-06-2011, 07:10 PM   #12
cleszkie
cleszkie's Avatar
This may sound stupid, but have you checked for out of round tires (manufacturers defect or flat spot from braking). An out of round tire will balance just fine, but will roll like crap. I have heard of people encountering this issue with certain tire manufacturers. Just a though. Good Luck.
Old 12-06-2011, 07:30 PM   #13
jaros44sr
jaros44sr's Avatar
Or a broken cord or belt in the tar
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-06-2011, 07:46 PM   #14
Scrat
Scrat's Avatar
Originally Posted by Steve-W View Post
OFFTOPIC:
back on topic
LOL... what I meant was - Wife driving car, son in back seat video taping
I have checked the tires for out of round and flat spots, they appear good.
I havent noticed any signs of a broken tire belt on the exterior of the tire (inside may be different).
Old 12-06-2011, 07:54 PM   #15
Steve-W
Steve-W's Avatar
you don't sound stupid because cars standing on the same spot for a long time (at least several months) can get "flat spots" on the tires.
but: this creates a tremble also in the stearing wheel (front tires..duhh) and is very noisy, it sound like your wheel bearing has gone.
projects:
1969 Chevy C10
1950 GMC 100
Old 12-06-2011, 10:20 PM   #16
coyote72
coyote72's Avatar
You said you had checked the wheels and axles for runout.... was that up and down or side to side. Maybe its a bent axle flange? I had a similar problem with mine and it turned out to be sand in the tires from airing down and playing in the dunes. Good luck with the problem, it sounds like you have covered all the bases.
72 K5 4x4 350
70 Nova 454 5spd 4-link
coyote72 is offline   Reply With Quote
Old 12-06-2011, 10:44 PM   #17
allchevy58
allchevy58's Avatar
Just a thought, we had a 1978 Blazer that started shaking at highway speeds all of a sudden. Knew it wasn't tires/wheel problem, checked drivelines, okay. Opened hood and noticed one of the fan blades broke off. Didn't hear anything, didn't damage radiator or shroud. No signs of exit of blade. Replaced fan, problem solved.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 12-07-2011, 01:31 AM   #18
old man jimmy
have you tried getting up to the speed it starts bouncing, and kick it into N and just let it coast? does it stop, or still keep bouncing?
Old 12-07-2011, 11:33 AM   #19
Scrat
Scrat's Avatar
Wheel bearings on the front checked out fine (and were repacked and adjusted accordingly)
Tires (and wheels) were checked for side to side and up and down runout... all good.
I didnt notice any flat spats on tires from sitting either.
Blazer now has electric fan so its not a missing blade or a bent blade.
Good question, when I put it in neutral at 65 it still has the bounce.
Again, Thanks for all the suggestions and comments.
Old 12-07-2011, 03:26 PM   #20
Firebirdjones
I've found alignment issues to be the culprit on solid axle 4x4's most of the time.
Firebirdjones is offline   Reply With Quote
Old 12-07-2011, 08:41 PM   #21
AJs72K5
AJs72K5's Avatar
Threw a weight off the drum??
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 12-13-2011, 04:47 PM   #22
Scrat
Scrat's Avatar
Thanks for all the suggestions. The weather has shut me down for awhile so I wont be messing with this til next year... I'll keep the link alive with what I find and what I figure out.
Old 12-13-2011, 07:11 PM   #23
jaros44sr
jaros44sr's Avatar
good one aj, wouldve never thought of that
SAFETY FIRST
AS usual, off topic
Jim
Old 12-16-2011, 02:22 PM   #24
mcampbell
Big O Tires has dinged me a couple of times so I will cheerfully use their name here. First time I learned to never go back. The second time I bought a 99 Suburban with Big O tires already installed. I took it in for balance every month or two because it had vibrations in the front tires. Every time they rebalanced the speeds changed but they could never remove it completely. Sometimes the vibration was from 65 to 72 mph and after a balance it would be from 58-67 mph etc. Stock Suburban I had changed the cv shafts, rebalanced the drivelines etc.
After 6 months of this I asked,"At what point do you decide these tires are junk and give me a warranty?" I got the ol dance about how they had changed computers and it did not show me in the database and they would not help because this was my first complaint. I have since had Michelins, BF Goodrich, and Toyo's on the truck. (213,000 mi)with absolutly no vibration at different freeway speeds.
I would borrow tires and rims from one of your buddies and give them a test drive. You might also rotate tires and see if it changes. I would personally recommend as I already do to my friends to not patronize the Big Zero( but just not going there will likely not fix your vibration issue.) Good Luck.
mcampbell is offline   Reply With Quote
Old 12-16-2011, 06:43 PM   #25
Firebirdjones
There is alot of truth to that.
I have my own mount and balance machines here so I do my own tire mounting.
I've had alot of different brand tires on that spin balance machine and I can attest that some of those cheaper tires are much harder to balance and take more weight to do so.
I've always been a believer in a good quality tire, and just bite the bullet on cost. In the end it pays off.
