12-07-2011, 12:16 AM | #176 |
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
I received your payment....thanks
I probably won't get these shipped tomorrow but the following day. I have a rush job I have to get done tomorrow, and it takes 3+ hours to get these brackets ready to ship. Hopefully that will work for you. Regarding the Eldorado caliper cable bracket and lever. I did hear back on one set I inquired about. Now we just need to settle on a price, so I can get them.
12-07-2011, 07:18 AM | #177 | |
12-08-2011, 11:40 PM | #178 |
does your kit require removing axles to install??? and is the price the same as front page
and also which wilwood caliber too use i see some different sizes??
1971 rs camaro under the knife ls3 6 speed swap 1970 396 big block shorty fleet 67 clone 2010 rs/ss camaro |
12-09-2011, 12:27 AM | #179 |
60-66 Nut
You don't have to remove the axles to install these brackets, but you will have to, to remove the backing plates. Unless you cut them apart to get them past the axles. It really isn't difficult to remove the axles. When was the last time you changed the rear end oil? If it's been a while, it might be a good idea to pop the rear cover, R&R the axles, re-install the cover with a new gasket, and fill with your choice of gear oil......just sayin
Yes the price is still $232.00 plus $10.00 for shipping. The powder coating is still the same $28.00. You can use any D52 type caliper with this kit. Wilwood makes 2 different sizes of the dual piston D52 calipers. For the rear you will want the ones with the smaller pistons.....1.250" I believe.
12-31-2011, 12:25 PM | #180 |
Anyone run this set up with 15" wheels? I am interested in a set
12-31-2011, 12:45 PM | #181 |
60-66 Nut
Yes, 15" wheels will work with this conversion, as long as they are disc brake compatable wheels.
01-13-2012, 11:17 AM | #182 |
Have you considered adding tabs to the mounting plate to allow for the standalone wilwood mechanical parking break calipers? I'd love to run this setup and match my front Wilwoods, but need to be able to pass inspection with an eBrake....
www.tomthetruck.blogspot.com <-- Aka build thread. |
01-13-2012, 11:55 PM | #183 |
60-66 Nut
Yes I had thought of that some time ago. I just haven't done anything with the idea since it will add some cost to the conversion and I'm not sure if that would put it out of price range for more people.
I'm not saying I'm not going to persue it, it just may take a little time to get it to a final design. I checked with Summit, and these are on back order until the 23rd at the eaeliest.
01-14-2012, 12:28 AM | #184 | |
Still plays with trucks
http://www.wilwood.com/Calipers/Cali...me=Mech%20Spot They do have a hydro-mechanical parking brake caliper now though that can work with a 1" rotor. http://www.wilwood.com/Calipers/Cali...tion%20P-Brake
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
01-14-2012, 02:45 AM | #185 |
60-66 Nut
Yeah, I figured I would have to have some thicker spacers machined to make them work with the 1.250" thick rotors.
Those new Wilwood calipers, have a different type of mounting....they aren't cheap either! I wonder if a guy could add a spacer to those, and use them on the 1.250" rotors? Looks like they are a 2 piece design.....
01-15-2012, 12:59 AM | #186 | |
01-18-2012, 07:38 PM | #187 |
They are very proud of that caliper indeed. I would rather make the spacer for the puck caliper and use it in conjunction with my caliper of choice instead.
I thought about a differential pinion mounted parking brake setup using a single puck type mechanical caliper but for the work & parts involved it would be easier and cheaper to just run these on the actual brake rotors instead.
01-19-2012, 12:47 AM | #188 |
60-66 Nut
Adding a mechanical e-brake to this conversion bracket, is high on my list of to do's. I'm going to be ordering one of the Wilwood mechanical spot calipers soon.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 01-19-2012 at 12:52 AM. |
01-19-2012, 12:49 AM | #189 |
If you do that and still have it laying around when I go to order mine (which I WILL be doing if you update this to have ebrake) I'll gladly buy it off of you.
02-12-2012, 08:08 AM | #190 |
hey, captainfab i would like to order some of your D52 disc brake brackets and the brake booster bracket for a 72 chevy pickup. do you have any left?
02-12-2012, 11:37 PM | #191 |
60-66 Nut
I replied to your PM........
02-13-2012, 07:05 PM | #192 |
do you have an idea when these will ship?
02-14-2012, 12:28 AM | #193 |
60-66 Nut
Ordinarily your order would have shipped today, but I am currently extremely busy. Your order will ship tomorrow, and you should receive it by Friday.
02-14-2012, 07:25 PM | #194 |
thank you very much Captain. i cant wait to get them on my truck.
02-18-2012, 09:24 AM | #195 |
got my brackets a few days ago, they look great. thanks for everything captain. Ill let you know how it goes.
02-18-2012, 11:06 PM | #196 |
Are the GM D52 calipers used on the front of the 88-98 trucks?
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E 2018 Dodge Ram 2500 HD R/C |
02-19-2012, 12:19 AM | #197 |
60-66 Nut
No, those are the D369 calipers. The last year for the D52's on the trucks was '87, or '91 for the V and R series
02-19-2012, 03:50 PM | #198 |
Thanks for that information. I'd love to install Wilwood two piston calipers on my truck. I guess that can't happen...
02-19-2012, 11:43 PM | #199 |
60-66 Nut
If you are talking about the '89 K1500 in your sig, I do have a 6 lug rear disc conversion that uses the D369 calipers.
http://www.67-72chevytrucks.com/vboa...d.php?t=494411 But that does not get you the Wilwood dual piston calipers
02-23-2012, 01:50 AM | #200 |
60-66 Nut
Has anyone had an issue with the outside pad rubbing on the hat of the rotor with this conversion?
