#301 |
Re: What Did You Do With Your Truck Today ?
spent the night getting my engine ready to fire up for the first time since the rebuild, installed temp wiring, temp gauges, filled with oil & primed, double checked everything.... then the moment of truth, hit the starter button it struggled to turn over a few times and tried to fire, then nothing, thats when I realized I overlooked a minor detail ...... dohhh I forgot to put the battery on charge last night.
![]() guess I'm waiting one more night ![]() |
#302 | |
That is the Murphy's law Murphy. |
#303 |
#304 |
Installed the big brake kit for my truck,then stood back and took it all in and wished it was ready to drive!!
#305 |
IT'S ALIVE...IT'S ALIVE!!!!!!!
Finaly got the engine running! had the valves a bit too tight. sounds mean as hell ![]() |
#306 |
Ya know if it were too easy it wouldn't be any fun.
#307 | |
got any pics? |
#308 |
That looks like it will stop! how big are they?
#309 | |
![]() As for pics, have to solve a cooling/ overheating issue first, clean up my Dr. Frankenstein wiring then I'll take a vid & upload to YouTube then I'll post the link. I tried to take a video for the first start but the vibration from the reverb made it hard to watch and I ran out of memory after about 30 sec. |
#310 |
I made a dohickey. A adaptor that goes on my tape measure and so I can use a grease fitting to masure from.
#311 |
I just replaced my T5 this afternoon and am on #3. The first had some horrible noise in 4th and 5th. The second was not as bad so thought it might be bearings and ordered a rebuild kit. Not as noisy but still prominent in 5th. This morning I managed to find #3 on Craigs out of a GMC S15 for a $100 and now that I am an expert in re and re of T5`s, had it finished in under 2 hours. The noise is not as bad as the first 2 and I think that the problem with these used T5`s are 5th gear wear.
I think I will research and source gears now that I have a spare T5 to play with.
Life is too short to drive a boring vehicle. |
#312 |
#313 |
I got my new radiator installed and tried out the heater part of my Vintage Air system. Works great, and really blows out the heat. There doesn't seem to be much air from the defroster vents but I think that's because of the design of the dash trim. I also got my emergency brake handle put back in and installed the cover that hides the a/c and heater hoses inside the cab. The green wire in the pic is the backup light power. It's just tied up out of the way for now.
Getting a radio and something to fill the throttle hole in the dash are low priority for me. Getting it where I can drive it is what I'm most interested in. Orrie, thanks for the radiator hose numbers. NAPA didn't have the Gates hoses but had a NAPA equivalent that is made in USA so that's what I'm using. |
#314 |
Got the Corvette 283 installed and running in my '48
#315 | |
1959 Fleetside Big Window Long Box Standard Trim soon to be Deluxe 1953 GMC Carryall Suburban |
#316 |
Finished the blocking and priming on right door. Now on to the left!!
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
#317 |
big guy
![]() Join Date: Jun 2008
I picked up a new rear fender and did some body work to it, now it's off to the sand blaster so i can finish the body work and work on installing it on the truck!
Thanks Ray |
#318 |
Went to the local pull a part and found a seat for the ole '49.
#319 |
well i spent the last two days sorting out the wiring for the brake lights, tail lights and head lights. i got them all working but i pretty sure i need to buy a new wiring harness one that isnt pieced together. I believe i had to add about 15 splice just to run the wires where the needed to go and by pass some old wires all together with new ones. overall im happy i have lights just in case i need them. lol even if when i hit a bump the flash and flicker.
#320 |
Got the upper tailgate cable figured out, here it is so far. Also figured out that the taillight assembly does not have enough room to pivot out to put the filler behind it like later models.
#321 |
![]() Join Date: May 2010
Put the 54 in her new garage.
#322 | |
I am well known for getting a vehicle and within a short time the wiring will be laying in a pile next to it. |
#323 |
B.Y., Thanks for the compliment. Right now I'm thinking I'll put a pull type switch with an original style knob in the throttle hole. It will be to turn on my backup lights if I need some light behind the truck to load something. I think I can get by without having to repair the radio holes but I'll take care of that later.
#324 |
Tried to align the tailgate, but need to ease the trunion mount holes so they can move up. Did get the hidden latch rubber pieces mounted and worked some more on the cables. Wasted time trying to find the shoulder bolts to support the cable, the ones I got only came with 1 per side. Parts guy left a message with Dorman to see if the sell them separately, not listed in their catalog.
#325 |
Finnaly removed two leafs from the front corners. Came up with a 2 1/2 inch drop. Now the truck sits level again. Added new shocks to match the new shocks I put on when I did the rear c-notch. I have not noticed any real softness but wont know till I put it on the freeway tomorow.
