Old 12-07-2011, 10:22 PM   #1
Todd68Chevy
Todd68Chevy's Avatar
Parting out a 1972 Chevy Cheyenne C10 ***Parts list added 12-17***
*************Parts list added in post 59*************************
I have a 1972 Chevy Cheyenne 10 that is rough but I figure there are a few parts that need to be saved before the truck is disposed of. It was originally a v8 automatic but engine and transmission are missing. I am parting out the entire truck but I do have some parts already sold locally. I am planning on disassembling this truck Saturday December 10th. Post to the tread with interest and I will check and get pictures as soon as I can. I will need to remove most parts before the shipping charges can be figured. I accept PayPal or Bank Money Orders.
Items that are already sold locally:
Power brake booster, brackets, push rod, m/c and prop. valve
front cross member, suspension and brakes
rear differential
power steering box and power steering pump
Items I see that are worth saving:
******Parts list***** added 12-17****
1. Shifter linkage & Frame Pivot-- missing transmission tab $20.00 plus shipping
2. Grille brace- rusty-- Free plus shipping
3. Hood latch-- $15.00 plus shipping
4. Hood pin and latch plate (attaches to hood)-- $6.00 plus shipping
5. Small block engine stands-- SOLD
6. Interm. steering shaft-- $10.00 plus shipping
7. Evap. Canister bracket-- $5.00 plus shipping
8. Flange for exh. pipe against exh. manifold-- $5.00 pair plus shipping
9. Washer bottle bracket-- $5.00 plus shipping
10. Washer Jug-- FREE plus shipping
11. Core support to fender brace-- rusty but solid-- Free plus shipping
12. Exh. bracket that rivets to the frame by transmission crossmember--$10.00 plus shipping
13. Tailgate support links-- SOLD
14. Tailgate pivots-- SOLD
15. Heater hose clip/ bracket-- $2.00 plus shipping
16. Center bumper brackets-- $5.00 pair plus shipping
17. Battery hold down bracket-- $2.00 plus shipping
18. Steering column, automatic-- $40.00 plus shipping
19. Steering column mount-- under hood with clamp-- $10.00 plus shipping
20. Steering column mount-- strap attaches to brake pedal bracket-- $6.00 plus shipping
21. Steering wheel (cracked) with horn button and horn parts-- SOLD Locally
22. Steering column trim (goes up to cluster)-- $6.00 plus shipping
23. Throttle cable bracket-- $5.00 plus shipping
24. Carrier bearing bracket-- rivets to the trailing arm crossmember-- $15.00 plus shipping
25. Misc. parking brake cable items including center cable-- SOLD
26. Door panels and armrest wood grain worn, extra holes drilled, chrome trim good-- $30.00 plus shipping
27. Gas tank, small spot that looks like possible rust below strainer-- SOLD
28. Rear step bumper-- SOLD
29. Tail light harness, See issues pointed out in post 138-- $15.00 Shipped
30. Harness from firewall to taillight harness-- $10.00 plus shipping
31. Headlight harness-- $18.00 plus shipping
32. Dash harness, fuse box looks ok, gauge cluster, non-a/c and no cig. ligher-- $20.00 plus shipping
33. Dome light-- SOLD
34. Fuel gauge wire, from tank to fuse box-- $5.00 plus shipping
35. Fuel lines that hook to the sending unit-- $5.00 plus shipping
36. Evap. lines-- $5.00 plus shipping
37. Sunvisors, sticking is loose--$15.00 plus shipping
38. Sunvisor clips-- $5.00 pair plus shipping
39. Dash cluster w/ gauges, no tach-- SOLD
40. Headlight and washer knob-- $5.00 plus shipping -- Washer Knob- SOLD
41. Glove box lid-- $20.00 plus shipping
42. Glove box latch catch (attaches to dash)-- $2.00 plus shipping
43. Reverse light housing, right side-- $5.00 plus shipping
44. Reverse lense-- SOLD
45. Taillight lense-- SOLD
46. Taillight housing-- $10.00 pair plus shipping
47. Cheyenne fender emblems-- $25.00 pair plus shipping
48. 8/350 emblems (frt. fender)-- $15.00 pair plus shipping
49. Headlight bezel-- $20.00 pair plus shipping
50. Left outside door handle-- $6.00 plus shipping
51. Jack tool hold down items-- $5.00 plus shipping
52. Speaker bracket-- SOLD
53. Door lock lever and retainer-- $5.00 plus shipping
54. Brace under steering column (flat panel)-- $5.00 plus shipping
55. Door handle and window crank (inside)-- SOLD
56. Automatic brake pedal-- $35.00 plus shipping
57. Heater controls (face rivets are a little loose, levers are good and move)--SOLD
58. Inside heater box with cables-- $35.00 plus shipping
59. Outside heater box-- rechecked and found a rusted hole in the metal part
60. Cowl panel, extra holes-- FREE NO shipping
61. Driveshaft-- $20.00 NO shipping
62. Cig. lighter delete-- SOLD
63. Roof panel (cut at the bottom of the a pillar and acrosss the rear below the double panel)-- $75.00 NO shipping
Let me know what else you are interested in and I can inspect, get pictures and price. I will ship anything I can but I am limited on larger items and sometimes finding boxes. I do not have Greyhound shipping as an option.
Thanks for looking
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 12-07-2011, 10:25 PM   #2
Todd68Chevy
Re: Parting out a 1972 Chevy Cheyenne C10 Rusty
More Pictures.
Old 12-07-2011, 10:28 PM   #3
Todd68Chevy
More pictures
Old 12-07-2011, 10:38 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Does the truck still have the medium olive defrost vents in good shape?
Old 12-07-2011, 10:41 PM   #5
gcburdic
Restoration Virgin!
gcburdic's Avatar
steering wheel any good....if so please check shipping to 28031
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 12-07-2011, 10:49 PM   #6
Todd68Chevy
I have not really looked at them but I should be able to check them tomorrow.
It would be useable but does have cracks. I will try to get better pictures.
Old 12-07-2011, 11:02 PM   #7
6t727t2
Active Member
Shipping cost on seatbelts to 08008? If $10 or so and no damage to belts I'll take them. Price on door jamb vent ?
6t727t2 is offline   Reply With Quote
Old 12-07-2011, 11:24 PM   #8
gcburdic
Restoration Virgin!
gcburdic's Avatar
Todd...I'll pass...I didn't see that large crack along the base...thought it was a shadow
Geoff with a G
Old 12-08-2011, 01:56 AM   #9
MadnessBigBlock
If the vent windows are chrome and glass is soft ray and in good shape! Ill take them pending price shipped to 58265
MadnessBigBlock is offline   Reply With Quote
Old 12-08-2011, 03:29 AM   #10
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
I know where you found this!!! Had my eye on it too... A little too far from me... Good find!!! Good luck with the sales!!!
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 12-08-2011, 07:56 AM   #11
Todd68Chevy
I will get them removed and get better pictures and a shipping price. I would think $10.00 will be pretty close. I think the door jamb vent is cracked but I will check
No problem, I figured it was rougher than you would want.
I will get better pictures. How do I tell if the glass is soft ray?
Yes it is the one that was on Terre Haute Craigslist. It was only 25 miles for me. I was interested in the rust free tailgate but his rust free tailgate is full of bondo and has these bubbles under the paint. If they are not rust I guess I do not know much about old trucks. LOL It is pretty rough but I hate to see any of them just go for scrap.
Old 12-08-2011, 08:12 AM   #12
OLEBEATER
OLEBEATER's Avatar
How much for the heater controls and the lighter delete plug shipped to 22435?
OLEBEATER is offline   Reply With Quote
Old 12-08-2011, 08:00 PM   #13
supercheyenne1972
Todd,
hows the gas tank? Is there any rust inside the tank or leaks? I might be interested. What is the amount? Is it also possible to ship to 63301, close to Saint Louis.
Thanks,
Ray
supercheyenne1972 is offline   Reply With Quote
Old 12-08-2011, 09:47 PM   #14
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Interested in the door panels!! Price shipped to 74804?
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 12-08-2011, 09:57 PM   #15
Todd68Chevy
They probably were but have been painted black. Right side is warped some and the left side has a broken tab. Sorry
Here are some pictures, just let me know if you want more. The shipping would be $11.00. The webbing looks good but dirty. The latches all work. The chrome is not great. The retractor covers are not as good as I thought they were. I do also have a door vent. I would take $55.00 for the belts, vent and shipping. Let me know. Thanks
Old 12-08-2011, 10:02 PM   #16
Todd68Chevy
More belt pictures.
Old 12-08-2011, 10:05 PM   #17
zicc1835
zicc1835's Avatar
Outer door handles condition and passenger side inner front fender price shipped to 07981
zicc1835 is offline   Reply With Quote
Old 12-08-2011, 10:05 PM   #18
1967chevyswb
1967chevyswb's Avatar
Would be interested in one bed wheel tub. Can u tell me shipping to 67401. Thank you
1967chevyswb is offline   Reply With Quote
Old 12-08-2011, 10:09 PM   #19
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'll pass then. Thanks for checking. Pete
Old 12-08-2011, 10:12 PM   #20
Todd68Chevy
The heater control levers all move and not broken. 2 of the rivets holding the face to the back are getting loose and have some movement. Switch operation is unknown. I would take $25.00 for it. Shipping would be $8.00. Total of $40.00 for control head, lighter delete and shipping. Let me know. If you need more pictures just let me know. Thanks
Old 12-08-2011, 10:22 PM   #21
Todd68Chevy
Originally Posted by supercheyenne1972 View Post
Todd,
Thanks,
Ray
Ray, The gas tank looks good on the outside but I have not checked the inside yet. I would have no idea on how to ship it for a reasonable price. If it is clean inside I would take $45.00 for it. I am only 20 miles south of I70 if you know anybody that travels this way. I will let you know when I get the inside checked but it will probably this weekend.
I will get them off and get pictures, price and shipping quote. Did you notice they extar holes in them-- screws along the edge?
Left outside handle might be ok but the right side has the button broken in it. All the sheet metal is very rusted and I am sure the inner fenders are junk. I will let you know when I get it apart.
Old 12-08-2011, 10:27 PM   #22
Todd68Chevy
The main part is nice but the bottom lip is rusted around where it bolts into the bed. I planned on cutting them out so I will see what they look like after removal and get you a price and shipping quote.
Old 12-08-2011, 11:16 PM   #23
zicc1835
zicc1835's Avatar
Jess
Old 12-09-2011, 12:17 AM   #24
slammer72
Carpet available?
slammer72 is offline   Reply With Quote
Old 12-09-2011, 12:29 AM   #25
Collin
Collin's Avatar
How rough is that steering wheel? Any more photos available?
Thanks,
Collin
Collin is offline   Reply With Quote
