Old 12-08-2011, 10:18 PM   #26
66farmer
66farmer's Avatar
Re: few pics of my new brake booster
Thank you you just saved me (and others) alot of time.
66farmer is offline   Reply With Quote
Old 12-08-2011, 11:48 PM   #27
Fastrucken
Junior Member
Fastrucken's Avatar
Good work.... Come on, you knew you were going to get hounded by only posting up some pictures of a clean install...
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 12-09-2011, 02:22 AM   #28
Captainfab
60-66 Nut
Thanks for the mention
That is correct, my booster/hydroboost bracket is a direct bolt on to the firewall.
Originally Posted by sincity64 View Post
5. www.talonhydraulics.com is their web address and 1-906-440-5100 is their order line. they are very helpful and as you will see they have the parts you will need to get it together including complete kits(very expensive). By the way, they dont have a bracket for our trucks but the one for 67-72 trucks will work if you are willing to modify the fire wall by drilling two holes. since i already had modified my fire wall for the other booster it worked out for me. if not i believe captainfabs bracket is a bolt-on, no mods. i welded captured nuts on the inside once i lined up the holes with a few mods and then welded up the firewall after i was done. i also started a smoldering fire under the dash due to some hidden insulation, (nervous times), have fun and thanks for the compliments
Old 12-13-2011, 10:06 PM   #29
sincity64
sincity64's Avatar
in case anybody is considering making your own hydraulic hose for your hydroboost, these are the fittings and hose i used. the hose is russells powerflex hose for power steering and their endura hose ends.the hose ends are reusable which makes it easier to get the clocking of the ends just right. the fittings average about $13.00 each and 20 feet of hose about $85.00. i chose this route rather than tow the truck to the hydraulic shop to have the hose made. they went together pretty easy
sincity64 is offline   Reply With Quote
Old 06-25-2013, 09:38 PM   #30
Rusty69
What year truck did you get the steering box out of. Does your box have the metric fittings like the pump and booster?
Rusty69 is offline   Reply With Quote
Old 06-25-2013, 11:19 PM   #31
Captainfab
60-66 Nut
The '68-'80 steering boxes will have SAE fittings. The '81 and up boxes have the Metric with an O-ring fittings. Same for the pumps, but with the pumps, the pressrer fitting can be changed.
Old 06-25-2013, 11:32 PM   #32
Rusty69
Do the 2000 year model boxes have the same gearbox mounting pattern as a 69 c10? If not, which metric box does?
Old 06-25-2013, 11:35 PM   #33
Rusty69
There is already a power steering box on my truck from the previous owner starting the conversion. I'm not sure which year it is from, though.
Old 06-25-2013, 11:58 PM   #34
Captainfab
60-66 Nut
No. The '88 and up pickup steering boxes will not work....totally different
For a Metric steering box you will need one from a '81-'86 C series pickup, Suburban or 2wd K5 Blazer, or a '87-'91 R series pickup, Suburban or 2wd K5 Blazer.
Old 06-26-2013, 12:07 AM   #35
Rusty69
Last question. Which factory hydroboost would I need to look for to fit correctly on the firewall of my 69? Ive seen some say mid 80s Astros and another guy said 99 c3500. I appreciate all your help, bro.
Old 06-26-2013, 12:23 AM   #36
Captainfab
60-66 Nut
There is not any factory hydroboost bracket that will be a bolt on install to your '69 firewall. Once you remove the factory mounting bracket, the hydroboost units themselves are all the same physically. With that said, I sell the brackets to mount any hydroboost to your firewall, without drilling any holes.
Old 06-26-2013, 12:27 AM   #37
Rusty69
Do you have a photo of the bracket and what is the cost+shipping? Who knew big cams would cause so much trouble? Haha. Thanks for the help. Just pm me the info with pay pal address.
Old 06-26-2013, 12:43 AM   #38
Captainfab
60-66 Nut
There are links to the for sale threads in my sig line.
Here is the one for the '67-'72 brake booster bracket
http://www.67-72chevytrucks.com/vboa...d.php?t=347484
Here is the one for the hydroboost mounting plate.
http://www.67-72chevytrucks.com/vboa...d.php?t=347480
There are some installed pics there also.
I will PM you pricing and payment info.
Old 06-26-2013, 01:56 AM   #39
BigDan3131
BigDan3131's Avatar
Is it a waste of time adding hydro boost and a pump if I don't have power steering? I was working on a late model 1 ton Dodge today and the hydro boost has the hoses routed towards the wheelwells. I will probably get that style.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 06-26-2013, 12:14 PM   #40
sincity64
sincity64's Avatar
my power steering box came out of a 1972 chevy half ton. I swapped out the entire front cross member. the box does not have the metric fittings
