Old 12-10-2011, 05:33 PM   #1
PCRedChev42
Transmission Oil
I have a 2005 Chevy Silverado 1500. My owner's manuel recomends changing the transmission oil at 100,000 miles but I have been informed that changing the oil could cause the transmission to slip or have other problems. Has anyone else heard of this and should the oil be changed? Thanks.
PCRedChev42 is offline   Reply With Quote
Old 12-10-2011, 05:52 PM   #2
truckdude239
truckdude239's Avatar
Re: Transmission Oil
changed ours in our s-10 at 100k we just droped the pan and changed the filter with no issuse so far were at 120k. just dont have it pressure flushed and you will be fine
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 12-10-2011, 07:03 PM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Drop the pan change the filter and refill. I would be scared to change one that hadn't been touched for 150k but not 100k.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 12-10-2011, 09:07 PM   #4
gregory5000
I have a 2002 Olds van and the transmission is showing a p1811 code. That is a code that is set when it takes to long to shift and then it ups the pressure and you fell a hard shift. I have a good friend(my wife's cousin too) that is the service manager at our local GM dealership. He pulled the code for and I asked him would changing the fluid help. He told me not to even think about. it has 161K. He said that if I changed it, it would start to slip. I have never changed it so that is why he said not to. It will clean the clutch disc and that why it would slip.
I think it would be OK to change yours.
2001 GMC 2WD, 1998 Chevy K2500
gregory5000 is offline   Reply With Quote
Old 12-10-2011, 11:46 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
I changed mine at 80K. I bought the truck used with 60K on it and by the looks of the hitch (chain hook area and receiver) and evidence that a brake controller was installed and removed... I'm pretty sure it did a lot of trailer pulling. I'm at 135K now and wondering if I should just leave it until it blows (hopefully long after I trade it in) or change it. It still shifts great.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-11-2011, 09:31 PM   #6
bighaas79
He should have known that there is a tsb out for this, to replace the pressure control solenoid. I've run into many of these and the pcs solenoid has taken care of it each time. When I replace them I change the fluid and the filter, regardless of mileage. I have never had a trans quit working right afterwords. Personally I believe the theory of not changing the trans fluid is a load of bull. Most that recommend not doing it have waited way to long and the damage was already done. Same with the fluid exchange. From what I have seen is the customer usually has known that something hasn't been right with the trans for a while, and fearing what it might cost, waits too long. It gets brought in for a service, and all of a sudden it doesn't work right anymore. I've gotten so I test drive the vehicle first so I know for sure exactly how it acts before the service. I have found that I find issues that already exist that won't be cured by the service and let the customer know, that way if the decision to go ahead and try it is in their hands, and I don't get blamed for it "all of a sudden doesn't work right anymore". As always though just my $.02
bighaas79 is offline   Reply With Quote
Old 12-17-2011, 06:54 PM   #7
dmarty
dmarty's Avatar
I change the trans filter on my 99 every 75k. My pan has a drain plug, so every other engine oil change, I drain the oil out of the trans pan, but don't bother with the filter and add new trans oil. I get about 3 qts out and add 3 fresh. When you drop the pan and change the filter, you're not draining the oil in the converter, oil cooler or lines. By replacing 3 qts at a time, eventually I'm changing all the oil. I use Dex6. I have 315k on the original trans, so I think my method works.
72 GMC Sierra Grande SWB 402 BB A/C
(Owned it since 1973)
99 Silverado 1500 LT with 315K miles
(RIP)
2012 GMC Sierra SLT
dmarty is offline   Reply With Quote
