Old 08-27-2003, 11:09 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
porpoting valve reset
Can some one tell me really quick how to reset the damn thing!!!!
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-28-2003, 12:20 AM   #2
jimfulco
Have someone or something hold the little end button in, & pump the brakes a few times.
jimfulco is offline   Reply With Quote
Old 08-28-2003, 07:25 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
Thank's this damn valve is a pain in the arse!
MEMBER #6377
Project "7DEUCE"
Old 08-28-2003, 07:25 AM   #4
JimKshortstep4x4
Smile
Not all proportioning valves have the external button. If the valve is working and you get the system working it will reset itself.
Try bleeding both outlets at once. I use little tubes and direct the fluid back into the master cylinder reservoirs.
Jim
Old 08-28-2003, 09:54 AM   #5
tom hand
CCRider
tom hand's Avatar
The button is to bypass the "proportioning" part of the valve to make it easier to bleed the back brakes. Most sevice books have a diagram of a simple tool you can make to hold it in. Once all the air is out of the system, you simply press on the peddle really hard and it will reset.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 08-28-2003, 01:16 PM   #6
rickspickuppart
I have one of the tools for holding it in so you can do it by yourself but I don't remember where it was bought at.
rickspickuppart is offline   Reply With Quote
Old 08-28-2003, 01:55 PM   #7
Speedster 229
I installed a line loc on my 70 1/2 ton and the front brakes won't hold. Could this be the perportioning valve acting up. I have all new brakes etc. and they areadjusted right.
1970 1/2 ton LWB 350 / 700R Rebuilt top to bottom. Not custom, but really sanitary!!!!!!!!
Speedster 229 is offline   Reply With Quote
