12-10-2011, 08:38 PM | #1 |
Snow from defrost vent
hey does anyone have a fix for the "start your truck in the morning and snow blows out the vent and causes a bizzard inside the truck Problem"
72 Chevy K20 NV 4500 /dana 60 /gm 14bt 72 GMC K10 Super Custom 84 GMC K35 SRW 454 t400/205 03 Ram 2500 w/Cummins |
12-10-2011, 08:47 PM | #2 |
Still Just Havin Some Fun!
Re: Snow from defrost vent
hhhhmmmm Can't say that I do.
a green one with some stuff done to it.... |
12-10-2011, 09:02 PM | #3 |
I'm guessing from your location you might not see much snow.
12-10-2011, 09:03 PM | #4 |
Active Member
Maybe move to Florida???
I've heard of those blizzards but never been in one. |
12-10-2011, 09:58 PM | #5 |
Sierra Grande Club
We use a inline heater that mounts on lower heater hose (next to the water pump inlet) on our community snow plow. Works good, get in and your ready to go!
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
12-10-2011, 10:15 PM | #6 |
I brush my cowl off before I start mine. It works. A block heater will get it up to temperature faster too.
12-11-2011, 08:39 AM | #7 |
Sisyphus was my mentor!
The cowl on our trucks is a huge snow trap. You could lay a blanket across the cowl grate until the truck warms up enough.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
12-11-2011, 07:00 PM | #8 |
I was hoping someone might have built a defection shield or some kind of widget to keep it from just pulling the snow in. Even if you sweep the snow off before you turn the defrost on there is allway some that blows in and the extra moisture fogs up the windows. Man what a bummer.
12-11-2011, 08:07 PM | #9 |
some have put window screen under the cowl to help with snow and leaves entering the area.
Trueman |
12-12-2011, 11:42 AM | #10 |
Florida Edition
My 70 GMC factory a/c truck has this flap vent in the cowel operated by a vacuum canister on the firewall. This would keep the snow out...if we had such a thing down here.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
12-12-2011, 12:39 PM | #11 |
C/10 junkie
What I would is charge admission to the interior of your truck and make a slide out each side for kids to go tubeing. Extra Christmas money.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
12-12-2011, 02:37 PM | #12 |
I have the same problem, These guys down south have it tough!
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
12-16-2011, 07:53 PM | #13 |
The AC fresh air door is a great idea. Does anyone have any ideas of how to run it on a non AC truck.I wonder if it would be posible to control it via a controle cable, like a manual choke cable?
12-16-2011, 08:24 PM | #14 | |
That is true. But it is open unless the lever is moved to max A/C (recirculate), is it not? |
12-16-2011, 08:30 PM | #15 |
SNOW? in your truck? you should post a video of that!
1967custom |
12-17-2011, 09:30 PM | #16 |
I've had dry, broken leaves blow around but not snow....yet. I bet it looks like a snow globe, though.
12-17-2011, 11:28 PM | #17 |
move
12-18-2011, 12:03 PM | #18 |
I dont know how to fix it but it even happened to me in my 92 gmc. It sucks, you try to turn on the heat and snow blows all over you.
1969 shortbed c/10 1998 GMC sierra |
12-18-2011, 06:23 PM | #19 |
LMAO, sounds like I need to post a video and have some holiday music in the back ground. Next time we get the dreaded snow I will try to at least get a pic for all you folks down south. Its no fun driving with an ice scraper in one hand and a starbucks in the other.
