Old 12-12-2011, 12:49 AM   #1
stomper
Junior Member
stomper's Avatar
Bed too high? What did I do wrong?
I just assembled my bed for the first time and the bed does not line up with the cab. It appears to me the bed is about 1” too high. Where did I go wrong?
Details:
I am assembling factory SWB fleet sides with the rest of the bed components coming from a long bed.
Installed new poly cab mounts that appear to be correct – the front sheet metal looks right.
Blue tape at body lines for reference.
Pix:
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 12-12-2011, 01:09 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Bed too high? What did I do wrong?
Did you use pads between the bed and the bed mounting brackets?
LockDoc
Leon
Old 12-12-2011, 01:11 AM   #3
stomper
Junior Member
stomper's Avatar
No pads. Metal on metal.
Old 12-12-2011, 01:17 AM   #4
LockDoc
LockDoc's Avatar
OK.
I think your tape is a little misleading. You should use the body line back toward the door for lining it up, not the end of the tape. Have the cab corners been replaced?
LockDoc
Leon
Old 12-12-2011, 01:24 AM   #5
windmill
windmill's Avatar
i dont know but,, does the chrome on the back of the cab line up with the top of bed?
72 swb pickup
http://i124.photobucket.com/albums/p...k/100_0958.jpg
1967 chevelle ss
1966 mustang getting a l33 ls motor
1969 chevy dump truck
1989 mustang 6.0 ls best time of 1.29 at 5.91
https://www.youtube.com/watch?v=JtbooZoGZmQ
windmill is offline   Reply With Quote
Old 12-12-2011, 01:36 AM   #6
scrapmetalart
Junior Member
old cab mounts?
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 12-12-2011, 01:44 AM   #7
PHAT TONY
PHAT TONY's Avatar
Metal vs wood box floors?
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 12-12-2011, 01:46 AM   #8
jocko
jocko's Avatar
If I were a betting man, I'd say the rear bed mount on the passenger side is too low (or needs a spacer - or pad, etc).
All of them need a pad - metal on metal not good. But unless it's currently perfectly level side to side (ref Windmill's email) then I'm guessing adding a little spacer (or slightly thicker spacer than the rest) in the passenger side rear mount would help the height problem and fix the vertical gap problem (it is big at the top and tight at the bottom, indicating the rear of the bed is too low or the fron of the bed is too high). I'd look at the fwd drivers side mount and make sure it's not bent (up) somehow. Looks ok in the pic (if that's it) except for the missing pad.
Could monkey with the rubber mounting spacers for the cab, but raising the cab to align would exacerbate the vertical gap problem, so I'd try to approach it from the bed if possible.
Old 12-12-2011, 03:14 AM   #9
stomper
Junior Member
stomper's Avatar
Hey guys thanks for all the replys late on a Sunday!!
More pix:
Old 12-12-2011, 03:27 AM   #10
stomper
Junior Member
stomper's Avatar
Originally Posted by LockDoc View Post
OK.
LockDoc
Yea it is. See new pix with tape gone. Original cab corners
See pic added. It's level enough for me.
Originally Posted by scrapmetalart View Post
old cab mounts?
Replaced those and I think I got it right?
I did a forum search and read they were different heights. These all measure about 2-1/4". Came off the LWB donor that was an original wood floor truck and I'm sure never apart.
I thought about raising the back to tip the box down in front but the front is bolted down solid. There's no room to lower the front.
Yes gap seems tight at the bottom and bigger at the top.
I'd prefer not to raise the cab unless I made a mistake installing the new cab bushings.
Old 12-12-2011, 03:35 AM   #11
67ChevyRedneck
67ChevyRedneck's Avatar
What cross braces are you using? I can't tell from the pics, but I went out and measured mine.
My stepside with a wood bed has 2-1/8" thick cross braces, and the steel fleetside bed floor I have has a hair over 3" thick cross braces. If you say you're about an inch high... it makes sense to me that you may have used the fleetside bed mounts? If you swap from a steel to a wood floor you need to use cross braces for the wood bed, the front bed panel is different, and even the "roll pan" looking piece that finishes off the back of the bed has to be unbolted, cut out, and swapped.
EDIT: You posted while I was typing mine out and missed your last post. That answers that, should be the right ones.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-12-2011, 03:50 AM   #12
stomper
Junior Member
stomper's Avatar
Thanks for measuring yours. Here's a pic I just took for good measue.
Old 12-12-2011, 05:04 AM   #13
WAAF
is the bed side where it meets the wood floor bracket correct.. it being over the wood..
if it was on the underside of the wood it drop the sides 3/4" and fix some of that tight gap.. I haven't seen a wood bed so I might be way off base..
WAAF is offline   Reply With Quote
Old 12-12-2011, 06:00 AM   #14
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: Bed too high? What did I do wrong?
the guy with the 1964--66 chevy truck is right you don't want to run metal on metal every time you hit a bump it will make noise and bang I've uses the square rubber cushions on the under bed tabs trust me every your bolt loosen up you will hate the sound
stsalvage is offline   Reply With Quote
Old 12-12-2011, 06:21 AM   #15
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Found this statement: "Wood bottom bed strips are different than the steel bottom ones are. The height is different and the way they mount are different. The tall wood bottom sills are 2 3/8" tall, and the tall steel bottom ones are 3 1/4" tall. WES www.ClassicHeartbeat.com" in this thread..... http://67-72chevytrucks.com/vboard/s...d.php?p=627553
Hope it helps you out....
screamin_c10 is offline   Reply With Quote
Old 12-12-2011, 08:12 AM   #16
But,he is using the 2 3/8" wood floor supports. So,that's not it.
This is a factory short bed frame? If it's a shortened C/20 the rear cab mounts on frame are lower and require a different cushion.
Old 12-12-2011, 08:29 AM   #17
screamin_c10
That's what I get for answering tech questions during a 12 hour graveyard shift LOL
Old 12-12-2011, 09:12 AM   #18
cdowns
cdowns's Avatar
when you were down to a bare naked frame did you measure the frame to see if it was straight after 40years of use
Old 12-12-2011, 09:55 AM   #19
DANTIP
DANTIP's Avatar
In the first photo, it looks like the rear of the bed may be a little low. If so, it would make the front high and the gap near the cab corner and bed would be narrow while the gap near the top of the bed and the rear of the cab wider. Hard to tell from photos.
DANTIP is offline   Reply With Quote
Old 12-12-2011, 11:07 AM   #20
JORGIE95961
Dude ive seen alot, im aen alot of this, shim the cab
JORGIE95961 is offline   Reply With Quote
Old 12-12-2011, 11:30 AM   #21
superchevy
Got big-block?
superchevy's Avatar
cab bushings
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 12-12-2011, 12:25 PM   #22
Hart_Rod
Hart_Rod's Avatar
The "rear" of the bed needs to come up 1/4" and then shim up the rear cab mounts to make it match....
Hart_Rod is offline   Reply With Quote
Old 12-12-2011, 12:34 PM   #23
trucks72
trucks72
trucks72's Avatar
Shim your cab up. Some of the new bushing you buy are not the same as GM. They are a litle thinner. Not all of them are this way but some. You will need to shim front and back some to get the gap of the cab and bed the same. As for the rubber on the under the bed. If you do that go as thin as possible. GM never did that from the factory.
trucks72 is offline   Reply With Quote
Old 12-12-2011, 02:19 PM   #24
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Mine's about 1 1/2" from top of the bed to bottom of the chrome strip.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-12-2011, 03:27 PM   #25
PHAT TONY
PHAT TONY's Avatar
The pic of the new cab mounts looks to me that the rubber is a little shorter than I've seen before.
1972 K10 4X4-Sold
