Old 12-12-2011, 03:37 PM   #1
webfoot
Heater sucks!!!
It has been getting pretty cold around here lately, the last couple days the high temp has gotten clear into the low 20s. My heater seemed like it worked fine in the fall but as I was driving on the freeway in some thick fog it was freezing to the windshield and the defrost vents felt like they were blowing out 60 degree air. I was still pretty chilly despite having an arctic carhartt jacket on.
I would not think the cold air would keep the coolant THAT cold, does this sound more like a nearly plugged up heater core?
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 12-12-2011, 04:07 PM   #2
70cst
70cst's Avatar
Re: Heater sucks!!!
I would think there is an issue as you should be getting heat...
Ideas fellow board members?
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-12-2011, 04:32 PM   #3
domeier
domeier's Avatar
Re: Heater sucks!!!
Might want to take a look at the firewall, too. Plugging up all the air leaks makes a big difference.
domeier is offline   Reply With Quote
Old 12-12-2011, 04:34 PM   #4
trev1
Re: Heater sucks!!!
Sounds like the thermostat is stuck open. Engine is not getting up temp. Replace the thermostat and see if it helps.
trev1 is offline   Reply With Quote
Old 12-12-2011, 04:49 PM   #5
Bert W
Bert W's Avatar
Re: Heater sucks!!!
I was thinking a stuck thermostat also, or nor thermostat, or a low temp. thermostat. I like the plugging the holes idea also.
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline   Reply With Quote
Old 12-12-2011, 04:51 PM   #6
webfoot
Re: Heater sucks!!!
Hadn't thought about the t-stat, that makes sense though.
-me
Old 12-12-2011, 04:58 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Heater sucks!!!
Could also be a clogged heater core.Take the hoses loose and run the water hose thru it.Flush both ways.Especially if it's a newer replacement.For some reason they have made the lines thru them smaller and they clog easier.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-12-2011, 05:00 PM   #8
trev1
Re: Heater sucks!!!
Yep...less than 20 bucks and less than 20 min.. first place I would start....IMO
Old 12-12-2011, 05:35 PM   #9
cdowns
cdowns's Avatar
Re: Heater sucks!!!
i'd take the blower motor out and check to seee if the phlenum is clogged with 40 years of crap causing no air circulation
cost is $20 less than that $20// i've found time with no money is better than money alot of times when solving problems
Old 12-12-2011, 05:47 PM   #10
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Heater sucks!!!
im with cdowns
John
1999 Toyota Tacoma 4x4
Old 12-12-2011, 06:50 PM   #11
slikside
slikside's Avatar
Re: Heater sucks!!!
This certainly won't hurt, but it won't help it get hotter. How is the airflow? If you can feel some volume coming through, it's not the blower. I'm inclined to think more of a core blockage or the thermostat.
slikside is offline   Reply With Quote
Old 12-12-2011, 06:54 PM   #12
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Heater sucks!!!
If it sucks then the motor is running backwards.
sorry J/K
First thing is check the air flow from the vents. Then check the lever on the heat door control for free travel no binding. Then check the top and bottom heater hoses after the engine warms up for equal temperature both warm to hot. If you have AC then the control valve might be stuck on the inlet hose to the heater core.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-12-2011, 06:57 PM   #13
webfoot
Re: Heater sucks!!!
Air volume is decent, I'd say similar to what my chevelle puts out. Still what I would consider inadequate, but I think thats about as good as these ol things get.
-me
Old 12-12-2011, 10:40 PM   #14
Dark Knight
Dark Knight's Avatar
Re: Heater sucks!!!
If your engine isn't getting up to operating temp, try blocking half of the radiator with a piece of cardboard. Watch your temp gauge though. I've got a 160 t-stat in mine, but didn't change it before winter. Now my truck barely warms up. The cardboard works. (Then I noticed all the big-rigs with the snap on covers over the front of their trucks.)
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 12-12-2011, 11:06 PM   #15
1972RedNeck
1972RedNeck's Avatar
Re: Heater sucks!!!
These trucks have HUGE heater cores. I've got a little laser-pointer-thermometer-thingy-mabobber and it says my output air temp is 145* on a 30* day. I have a 180* thermostat.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-12-2011, 11:12 PM   #16
z10kl
z10kl's Avatar
Re: Heater sucks!!!
Is the air comeing out warm at a low fan speed and then cools when you turn the fan to high? If so the core is clogged and the air is cooling it faster than the water can move though it. Mine was doing this and I removed the hoses form the motor and took a hose and blew through it backwards. At first hardly any water would go through. Then some grit and rust started coming out and I could tell The flow was getting better. Heats better now.
70 CST
Bunch of old Camaros
z10kl is offline   Reply With Quote
Old 12-13-2011, 09:06 AM   #17
Re: Heater sucks!!!
It must be in the thermostat. You're not "making" heat. These trucks have heaters that are second to none. They put out more heat than you will ever need. If the heater core was clogged you'd feel a hot heater hose going in and a cooler one going out. If the plenum was clogged you'd still have the heat,just less air bowing through. In fact,you'd have a very hot heater. I never wear a jacket while in my truck and it's rare the fan is ever blowing more than low. It only goes on high to deice when I first start it up or to defog when I get in the truck wet. Then,the temp is either set down or if it's on hot to dry the air I need to open the wing vent or crack a window. A proper working heater will make you sweat like a pig with fan on high and temperature set on hot.
Old 12-13-2011, 11:07 AM   #18
franks72
Junior Member
franks72's Avatar
Re: Heater sucks!!!
This is what I found in mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=396843
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82
12.39 @111.33 With a 180 shot nos
69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/
email fdelcoglin@hotmail.com
franks72 is offline   Reply With Quote
Old 12-14-2011, 07:35 AM   #19
trev1
Re: Heater sucks!!!
Webfoot,what did you find? Would sure like to know.
Old 12-14-2011, 02:15 PM   #20
webfoot
Re: Heater sucks!!!
Haven't played with it yet. We haven't been above freezing for about 2 weeks now so my motivation to go out and work on it is low. I will update the thread when I find out.
-me
Old 12-14-2011, 08:02 PM   #21
Mudder
Mudder's Avatar
Re: Heater sucks!!!
Low water/anti freeze mixture. Make sure it has plenty of water in it. After I redid my heater with new door rubber it would actually run you out.
Mudder is offline   Reply With Quote
