Old 12-12-2011, 11:31 PM   #1
SHOWDOG
Brake line diagram? Anybody have one?
OK .......I didn't take enough pics on the tear down and now I'm trying to install new brake lines..uh without guessing! Anybody have a overall brake line diagram?
Thanks,
Showdog
SHOWDOG is offline   Reply With Quote
Old 12-13-2011, 12:03 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Brake line diagram? Anybody have one?
try this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=355152
may I also suggest picking up a factory assembly manual....although its very unorganized,
it has a great detailed diagram in there too....OH...I think they sale a searchable CD formatted one too...
check ebay for one!!!
Good luck and hope this helps ya!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 12-13-2011, 12:42 AM   #3
FirstOwner69
FirstOwner69's Avatar
What year? 2WD or 4WD? 1/2 or 3/4 ton?
71s and 72s are different from the earlier trucks. I believe the 1/2 and 3/4 ton 2WDs are the same except for the rear axle lines, and the earlier trucks may have used different style clips to secure the lines. I have lots of photos I took of the original lines when I disassembled my 69 3/4 ton with a H-052 axle if you think they would help.
FirstOwner69 is offline   Reply With Quote
Old 12-13-2011, 12:50 AM   #4
SHOWDOG
Yikes! I guess I could at least list what I'm working on. It's a 67 short step with 72 suspension front and rear. Brake line are from Inline tube and for a 72 short step.
Many Thanks!
Dog
Old 12-13-2011, 12:56 AM   #5
SHOWDOG
Thanks Geoff!
The pics should help me get started!
Dog
Old 12-13-2011, 06:14 AM   #6
gysgtc
Here are the lines I just got from inline and where they go. If you need more pictures let me know. Wayne
gysgtc is offline   Reply With Quote
Old 12-13-2011, 10:12 PM   #7
MAK191
You will have to change up the rear a little. The 72 hardline snakes around the cross member and has a hose that attaches on a small bracket that is mounted with diff cover bolts. The 67 hard line ends on the frame side rail. Easy to fix you just have to work with what you have. here is a picture of a 71/72 rear
MAK191 is offline   Reply With Quote
Old 12-14-2011, 01:30 AM   #8
SHOWDOG
Many Thanks!
The pics should really help!
This site is the best...Thanks for helping out a rookie!
Mike
Old 01-23-2012, 11:22 PM   #9
fasttech
fasttech's Avatar
gysgtc, have you installed the lines that come down from the prop valve to the frame? I was planing to buy a kit from Inline Tube (CTB67D4), but when I called Inline Tube they were unable to say for sure if this kit went inside or outside of the frame rail. I am trying to make sure these go outside of the frame and not inside. Any more pics you have would be helpful.
fasttech is offline   Reply With Quote
Old 01-28-2012, 07:05 AM   #10
gysgtc
No I have not but if I have time today I will check them out and let you know. Sorry was out of town and didn't see your post.
Old 01-28-2012, 09:55 AM   #11
gysgtc
Fasttech, here is a picture of the lines that run to the valve. They run on the outside of the frame. When I ordered mine from inline I just told them it was for a 67 c10 with front brake conversion. Let me know if you need any other pictures. Wayne
Old 01-29-2012, 11:38 AM   #12
fasttech
fasttech's Avatar
Great pic thanks Wayne! This is certainly outside the frame. Very important to keep heat from the headers away from the brake lines. If you have time can you post the Inline part number(s) you purchased?
Old 01-30-2012, 06:51 AM   #13
gysgtc
Sorry I don't have a part number. I just called them and told them I wanted the complete set for a 67 long bed with front disc conversion. I bought the stainless set. If I have time later today I'll dig thru my box of receipts and see if I can find a part number for you.
Old 01-30-2012, 09:05 AM   #14
gysgtc
The part number for a 67 C10 long bed stainless with disc brake conversion is SCTB67D3.
Old 07-06-2013, 11:22 AM   #15
HotRod C/10
HotRod C/10's Avatar
this helped a lot..............better than INLINE could do.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 07-07-2013, 01:56 PM   #16
elf w/capital T
elf w/capital T is offline   Reply With Quote
Old 07-07-2016, 07:46 PM   #17
Aztec.A
When you purchased these lines, did they come with the T block and necessary connections? The kit I ordered and received today did not have them. I'm hoping they forgot them. I have a 72 long bed, coils in the rear, front disc, factory booster, 8 lug, ho-52 rear axle, 350 w 3 on the tree, 2wd.
Aztec.A is offline   Reply With Quote
Old 07-07-2016, 08:07 PM   #18
elf w/capital T
Ts were all seperate purchased
Old 09-13-2016, 02:10 PM   #19
gayle
Do you have more detailed Diagram from master to rear
Thanks Gayle
gayle is offline   Reply With Quote
Old 11-15-2016, 04:50 PM   #20
stevenfromtexas
stevenfromtexas's Avatar
hello guys, rookie builder here.
I was very thankful to stumble on this thread. this is right where i am with my pick up.
is everybody pretty happy with the Inline product? i too did the disc conversion on my67 SWB
thank you guys for all of the pictures!!!!
stevenfromtexas is offline   Reply With Quote
