Old 08-28-2003, 11:45 AM   #1
GreenMystChevy
electrical problems...she's trying to die
Long story short- I was driving as usual, noticed my blinker would take a while to start blinking and would blink very slowly. Noticed my lights getting dimmer. Turned it off at a buddy's house, dead battery. Clutch started it, drove it home. Didn't think I would make it because I couldn't see anything with my headlights so dim.
The voltage gauge seemed to be in the same spot as usual, straight up and down. I am taking the alternator in today to see if that could be the culprit. What else should I look for and check. I have the alternator grounded, the battery grounded to the block. This is very frustrating because this is my daily driver.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 08-28-2003, 11:48 AM   #2
JimKshortstep4x4
Smile
The alternator is a good place to start. Do you still have an external regulator?
Also,
I would check the inline fuses on each side of the radiator. It sounds like your ampmeter is not working.
Jim
Old 08-28-2003, 12:17 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Straight up/down, indicates no charging or discharging....
I thought mine was okay, too. But, I replaced the alternator belt, and had previously installed a new regulator and a new wiring harness....due to an unfortunate electrical incident that fried a wad of wiring from the alternator.
Bad alternator belt could be a culprit, but I'd let someone check it (the alternator) with the proper equipment.
Member Nr. 2770
Old 08-28-2003, 01:06 PM   #4
GreenMystChevy
External regulator? = The little black box thingy? What would an internal regulator be? Hmm, can't wait to get off of work to take a peek.
Inline fuses on the sides of the radiator? Gonna have to look for those too, didn't know they existed.
Just might try a new belt too. Man, can't I just drive it
No worries, whatever doesn't kill me...
just takes my money and makes me smarter.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Old 08-28-2003, 01:37 PM   #5
JimKshortstep4x4
Smile
The external regulator mounts to the radiator support on the left side, close to the horn(s). They do cause problems.
The inline fuses are on the main feed wire and they look like small
rubber footballs, only they will come apart. I believe that they use a very short 5 amp fuse, (to protect the guage).
Unfortunately, even these trucks need attention! (Part of the attraction).
Good luck!
Jim
Old 08-28-2003, 04:22 PM   #6
GreenMystChevy
Well, i took the alt in and sure enough, it was dead. I got a new regulator while I was at it. Thanks Jim and Chevloray for the help.
If these new parts don't fix it I'll be sure to let ya know.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Old 08-28-2003, 10:51 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Good call on getting the new regulator at the same time. It's kinda amazing how many are original.
Old 09-01-2003, 01:28 PM   #8
72c10step
WHYBYNU when old will do?
72c10step's Avatar
Thanks JimKshortstep4x4! My ampmeter hasn't been working since I got it, and I never even knew that there was fuses inline on either side of the radiator! They were hiding up under the lip of the radiator shroud where I couldn't find them. After your reply, I searched until I found them, and one was a 25 amp fuse, the other was blown. So I get new fuses, replace them, and now the gauge works great! Thanks a lot!
BTW: Does someone have a good set of electrical diagrams, that tell where all the inline fuses are and stuff?
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 09-01-2003, 01:39 PM   #9
71-longbed
Its Magically Delicious
71-longbed's Avatar
those inline fuses call for a 4 amp fuse .. there dinky little guys ...both of mine were blown as well ... my ammeter only moves when i start the engine ... while its running the needle sets in the middle of the gauge....
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
