09-21-2011, 02:00 PM | #276 |
Sisyphus was my mentor!
Re: Header Solution
tac106842, why are you getting a different starter? Do these not fit the factory starter?
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
09-21-2011, 02:33 PM | #277 |
Re: Header Solution
I have a mild built sbc406 running 10.3:1 compression and a good friend of mine told me to never run a sbc 400 up on a stock starter. He has built several of these and the stock starter usually ends up trashed in about 4 months. So I was planning on running a geared starter. I spoke with Steve (Joker69) and he said that he is running a Powermaster geared starter with these headers and he has a starter that you can rotated the electric motor to fit your application. Summit and Jegs has these starters in the standard bolt or staggered bolt pattern for around $245.00 and they put out 200ftlb of cranking torque. To answer your question I am not sure if the stock starter will fit or not, I know from installing these headers it is pretty tight where the starter goes and I am sure that there will be plenty of heat coming off these headers. You may want to ask Joker69 this question.
09-21-2011, 07:17 PM | #278 |
Re: Header Solution
Just ordered a set of big block headers for my 1970 chevy 3/4 2wheel drive...should be a week or so ..update pics soon...thanks Steve..
WTB 1972 CHEVY 3/4 4X4 1971 chevy c30 4x4 NAPCO (project) 1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers 1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete 2006 chevy LBZ crew cab duramax,4 inch,beadlocks 2015 chevy tahoe Z71 my fifth one,love em 2016 chevy 2500HD Z71 LTZ duramax midnite 2018 chevy suburban Z71 midnite |
10-20-2011, 01:40 AM | #279 |
Re: Header Solution
Just recieved my stainless SB headers & they look great! Going overseas for a bit so I'll have to install them when I get back. Photos then...
10-20-2011, 02:59 PM | #280 | |
Re: Header Solution
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
10-20-2011, 03:18 PM | #281 |
C/10 junkie
Re: Header Solution
Now all I need is a set for my 292
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
12-13-2011, 07:08 PM | #282 |
Re: Header Solution
12-14-2011, 01:31 PM | #283 |
Active Member
Re: Header Solution
The bbc or sbc header will not work with stock transmssion crossmember. They both need aftermarket crossmembers.
02-01-2012, 01:51 PM | #284 |
Re: Header Solution
Steve, I have placed a call into Dan's shop 3 times now and haven't heard back. Are they still in business? I'm looking for a set of BBC headers.
Thanks.
71 K5 In progress! |
02-01-2012, 04:02 PM | #285 |
Active Member
Re: Header Solution
Yes they are still open. I can get you a set ordered. Give us a call 425-251-0210 thanks Steve
02-01-2012, 04:09 PM | #286 |
C/10 junkie
Re: Header Solution
02-01-2012, 08:45 PM | #287 |
Re: Header Solution
Are they doing the Big Block Headers in Stainless Steel?
What is the current price.
Dan 67 Chevy LWB, Small Window - In the process of being rebuilt. Small Block is coming out & I'm gathering parts to switch to a Big Block 496. |
02-01-2012, 10:34 PM | #288 |
Re: Header Solution
Is the price still the same for the big block headers?
Posted via Mobile Device |
02-02-2012, 12:30 PM | #289 |
Active Member
Re: Header Solution
I will check current pricing and availabilty in stainless. Let you guys know asap.
02-03-2012, 03:24 PM | #290 |
Re: Header Solution
Well it looks like there are 3 of us. If we can all pool together and get a couple more guys in for the BBC headers, perhaps we can score a group buy. I talked to Dan yesterday Joker, thank you.
02-05-2012, 09:47 AM | #291 |
Re: Header Solution
Depending on the price of the BBC headers, you can add me to your group buy. I would love a set for my 78 blazer.
02-09-2012, 02:17 AM | #292 |
Re: Header Solution
I'll be up for a sbc bare set when I get my taxes back, if enough of us group buy.
Always remember those that had your back Never forget those that turned it Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt, Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner |
02-09-2012, 01:24 PM | #293 |
Re: Header Solution
Well I think that's 3. Can we got some more so we can propose a group buy?
02-16-2012, 02:42 PM | #294 |
Re: Header Solution
Bump
02-22-2012, 11:35 AM | #295 |
Re: Header Solution
i figured i would give this a bump. Kinda interested in a set for sbc and was wondering if there was a chance for a group buy. if not is there any sales going on? thanks a lot
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. |
02-22-2012, 05:30 PM | #296 |
Re: Header Solution
I'm still in.
02-22-2012, 06:40 PM | #297 |
Re: Header Solution
I might be i dependingon the price for a coated set
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
02-29-2012, 10:01 PM | #298 |
Re: Header Solution
Never did see where you posted the current price on the BBC Stainless Headers.
04-19-2012, 01:36 AM | #299 |
Re: Header Solution
Update: I'm back & just got my stainless 1 5/8 sbc headers installed. Having a 67 with the wide framerails, I had to relieve it in a few spots. Nbd there. I used Stage 8 hardware. There were a few other spots of interference. My motor uses a factory long, high torque starter and I had to dimple one tube a bit to allow an airgap. I also had to bend/massage a few brake lines. Overall, they fit great and look even better. I'm using 1st gen Trick Flow Twisted Wedge heads with angled plugs and I'm able to use 90 deg plug boots. I'm doing a 3sp to auto conversion & so I built my own trans crossmember.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car Last edited by passthebuck; 04-27-2012 at 11:09 AM. |
04-19-2012, 12:36 PM | #300 |
Re: Header Solution
Everytime I call this guy's shop there's no answer and just voicemail. Has anyone ordered recently?
