Old 12-14-2011, 09:27 PM   #951
BMERDOC
BMERDOC's Avatar
Re: Make it handle
Originally Posted by theastronaut View Post
They would allow water to drain out easier, but also let water in easier. Drilled or slotted shoes would have the same effect without letting water in.
I think that as off topic as this is getting Rob would like us to think outside the box so I will expand on this by saying that I like your idea combined with my thoughts. Yes, drums hold water but they are not water magnets. They hold water when they are imersed or completely saturated. In normal rainy situations drums are not ENTIRELY bad. I could envision the crossdrilled/skeleton brakes with a shoe setup that is manufactured to either have slots across the face to direct gases/water toward the backing plate (think tire sipes) or seperate pucks on them as to induce the same kind of action. I could be wrong....
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 12-15-2011, 12:14 PM   #952
robnolimit
robnolimit's Avatar
Re: Make it handle
Thanks DOC. When it comes to 'outside the box', I have some good advice for hot rodders and builders. Take the box, and carefully open it, cut the edges, and lay it out flat. Now, Use the cardboard to make a test-fit template for the parts/ideas that you have. Thats the only good use of 'the box'.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 12-15-2011, 12:25 PM   #953
BMERDOC
BMERDOC's Avatar
Re: Make it handle
So what is your opinion of a set of pumped up drum brakes Rob?
Nick Carter
Old 12-15-2011, 12:56 PM   #954
robnolimit
robnolimit's Avatar
Re: Make it handle
BRAKE TESTING WAS A BLAST It was a long day, with a lot of laughs and fun. Special thanks to Jim, CJ, and Mike. First we had to learn how to use our new test equip. - I-phone lap timer/GPS/G-meter gadjet. We all started with the OE pads, and drove down to bed them in. This is also a pad we're used to driving on. We ran 5 laps on the 1.1 mile road coarse to learn the layout, checked over the vehicles, got started. The premium pads had the same outcome for all drivers. They felt good at first-After 2 or three laps, the heat cased them to fade. On the 70-0, the pads were not cool enough to grab hard. Next, it was Hawk's turn. A noticable improvement. Everybody liked them, they put up good road coarse times, and stayed for the stop tests. Baer's pads seamed to be very close to Hawk. The improvement in RC times may have been due to driver experience (could not test these on the JT, it needed a rest anyway) On to Wilwood BP-20. Lots of brakes. Now we had to learn how to drive. These pads slowed every up on the first two or three laps, then we got fast. Also, an improvement 70-0, We did hear them a bit, and noticed a little dusting, or it was El-Toro. Last up was Wilwood #A pads. ultra agressive. A new learning curve here, or a real driver is needed. None of us could get used to them on the RC, But, if you could modulate the pedal just right, 70-0 was great! Oh, noisy and dusty. So, at the end of the day, we all needed new tires (thank you so much BFG) and were tired of changing pads. W all dicided that the more agressive Wilwood pads would be great for competition, but may be too much for a driver. The Hawk, Bear, (or an equal) were worth the money), and none of us will run OE pads again.
Camaro times: O.E. pads - RC=1.38, ST=128ft
Hawk - RC=1.31, ST=121ft
Baer - RC=1.28, ST=117ft
BP-20 - RC=1.24,** ST=118
#A - RC=1.27, ST=106**
Bullit times: O.E. pads - RC=1.41, ST=139ft
Hawk - RC=1.29, ST=134ft
Baer - RC=1.29, ST=133ft
BP-20 RC=1.26**, ST=126ft
#A - RC=1.31, ST=111ft**
J.T. O.E.pads - RC=1.58, ST=165ft
Hawk - RC=1.49, ST=147ft
Baer - RC=1.47, ST=145ft
PB-20 - RC=1.41**, ST=137ft**
#A - RC=1.44, ST=1.52ft
Old 12-15-2011, 01:02 PM   #955
robnolimit
robnolimit's Avatar
Re: Make it handle
Note: was it scientific? - NO. Does it prove anything? A little. Are we experts? - NO. The J.T. posted the biggest overall gains, which is a good sign for the average truck lover. We learned the none of us are good enough drivers to take full advantage of the most agressive pads. We also learned without a doubt, that a good set of pads is worth the extra $$$. And, that a day with friends at an abandend airfield is way better than actually working.
Old 12-15-2011, 01:06 PM   #956
robnolimit
robnolimit's Avatar
Re: Make it handle
A good drum will out brake a comparable disk the first time, but they get hot faster, and are harder to cool. We do some 'period' builds with the old stuff, big aluminum cased buick drums, and I am always shocked at how well they work.
Old 12-15-2011, 01:13 PM   #957
67cheby
67cheby
67cheby's Avatar
Re: Make it handle
cool info thanks for sharing !!
67cheby is offline   Reply With Quote
Old 12-16-2011, 02:07 AM   #958
Grimee
Grimee's Avatar
Re: Make it handle
Rob ,Sounds like a fun day also very informative , thanks for taking the time and sharing your findings I have always wondered if the more expensive pads performed better. Not trying to change the subject but I am curious what your thoughts are on front suspension. Do Camaros and Corvettes have a design advantage over the trucks when it comes to the basic geometry ? if so do you know what the differences are ? Are the differences in the spindle design or the upper and lower control arm mounting points ? or all of the above ? is it possible to obtain the same geometry using truck components ? just curious
Grimee is offline   Reply With Quote
Old 12-16-2011, 12:53 PM   #959
robnolimit
robnolimit's Avatar
Re: Make it handle
Thanks, Hey, how's you'r new project coming, any picts? The biggest advantages has to be weight. Not total weight, but where it is. Height of the CG, and ft/rr balance. Corvette stuff works great, in a 'vette. One problem with the 'vette stuff is the rack placement, which is relatively high. So, in a non-'vette, the motor must be raised to clear (motor sits behing the rack in a 'vette) Any gain in suspension performance was lost in raising the motor, and CG. A-arms are pretty simple, 3 pivit points, 2 chassis and one ball joint. Spindles are also kind of basic. Height, ball joint to ball joint, pin height, pin inclination, and steering arm location. (also brake mounts) It is the location of al the pivit points and components that makes the diffence. Trucks sat up, and have a higher roll center than most cars, so they don't tip over. This high RC makes them 'push' if drivin hard into a corner. The specs of a C-10 spindle, and an Impalla spindle are almost the same, brake mounts are different, but the C-10 spindle is 8 lbs heavier (truck) It is possible to move the truck parts around and make them work well, ask Hotchkis and Mike Hickman, they've finally got the Big Orange C-10 working well. Track width is also an issue when swapping. C-10's are WIDE. Looks like our new p/u will have a 64" track. (gen II Camaro is 61) . Hunt down a copy of "Supension Geometry Pro" and try plugging in some numbers.
Old 12-16-2011, 01:11 PM   #960
Ackattack
Ackattack's Avatar
Re: Make it handle
Which model of Hawk pads were you using?
Ackattack is offline   Reply With Quote
Old 12-16-2011, 04:28 PM   #961
robnolimit
robnolimit's Avatar
Re: Make it handle
We used the HPS pads, very street friendly and only about 50 bucks a set. The HP pro is more suited for autocross and track days, but we thought that they were not a good comparion for our tests.
Old 12-16-2011, 05:40 PM   #962
SCOTI
SCOTI's Avatar
Re: Make it handle
Originally Posted by robnolimit View Post
....Corvette stuff works great, in a 'vette. One problem with the 'vette stuff is the rack placement, which is relatively high. So, in a non-'vette, the motor must be raised to clear (motor sits behing the rack in a 'vette) Any gain in suspension performance was lost in raising the motor, and CG.
Ok, Vette stuff works great in a Vette & does not perform the same if swapped into a C10. That being said, it should still work better vs. the truck stuff & would shed some front end weight??? Yes, no?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-16-2011, 05:52 PM   #963
PBFAB.COM
PBFAB.COM's Avatar
Re: Make it handle
I don't want to step on any toes jumping into a thread that another vendor started... but I do have a little input on the Vette stuff. There are going to be a lot of variables, but the there can be some major performance gains if configured properly. A C4 conversion can be configured so that it only raises the motor 1.5" from stock, but lowers the entire truck a good 6-7 inches from stock. It can also achieve a roll center height of 4.725" and get a nasty 9.09 degrees of caster. The unsprung weight savings is also a big plus.
If configured properly, the vette components can perform extremely well on a truck.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-16-2011, 08:30 PM   #964
SCOTI
SCOTI's Avatar
Re: Make it handle
Well.... you already know what I have . I was kind of just curious about where that line of 'diminishing returns' starts when guys start swapping parts vs the C10 stuff.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-16-2011, 08:48 PM   #965
robnolimit
robnolimit's Avatar
Re: Make it handle
Nate us correct. - No thread jacking issues - the more the merrier. I encourage all the input. I have to agree with Nate on the performance gains. Would it be better if it had a magic 'Z' rack so you could drop the motor? - sure. But there is no such thing. Remember that everything we do is a trade-off.
Old 12-17-2011, 02:49 PM   #966
Grimee
Grimee's Avatar
Re: Make it handle
Thanks for the input everyone ,As for the new project we are pulling it into the shop early next week right next to the Tahoe ( still waiting to get on the dyno at Whipple) I will post some pics so you can see what a pile of crap we started with thats the reason for all the questions. I am starting with a clean slate and plan on a full chassis build so I want to explore all my options before I get in to deep . I plan on using the same rocker arm rear suspension I have on the tahoe ,Robs familiar with it . I also plan on setting the motor back at least 4 inches so i thought the steering clearance issues would be minimal . here is another question on frame rail design I want to keep weight to a minimum so what do you guys think is the strongest yet lightest way to go? I do plan on a cage with engine hoop and rear kickers . Oh yeah this is a 70 blazer and will be a roadster when finished .Thanks for the help
Old 12-17-2011, 04:49 PM   #967
robnolimit
robnolimit's Avatar
Re: Make it handle
Kurt, it seems like you got bit at Optima. Sorry to tell you, - there is no cure.
Old 12-18-2011, 01:34 PM   #968
Grimee
Grimee's Avatar
Re: Make it handle
Your right Rob I did get bit but it was long before our invite to the Optima ,this project has been in the works for a while and now that we are getting close to finishing the tahoe its time to get moving, It will be nice to have something that I can run at all the events and not be limited by year plus it will be cool to build something without the normal expectations we deal with at the shop everyday
Old 12-18-2011, 11:08 PM   #969
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Make it handle
Can't answer the question on the frame rails, but would love to see you have a build thread for this truck.
hgs_notes is offline   Reply With Quote
Old 12-19-2011, 12:22 AM   #970
Grimee
Grimee's Avatar
Re: Make it handle
I was thinking about a build thread if its something people would like to see. Also EVERYONE needs to know I am not a professional chassis builder and should not assume any thing I do is either safe or sane . I was hoping if I start a build thread that you guys will keep me in check
Old 12-19-2011, 01:05 AM   #971
jayman68
Fun Stuff
jayman68's Avatar
Re: Make it handle
Go for it we'll watch!
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 12-19-2011, 10:41 AM   #972
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Make it handle
Have you seen the build threads? There are like 3 people who would be considered pro chassis builders. The rest of us are just throwing spagetti at the fridge to see if it sticks. It's all about sharing ideas, good and sometimes bad. he feedback helps in both keeping us in check and motivation to continue. Go for it.
Old 12-19-2011, 04:36 PM   #973
robnolimit
robnolimit's Avatar
Re: Make it handle
If your going to build a cage assy that spans front to rear, you can use 2 x 3 x .120" tubing. Normaly we would blend 2x4 and 2x6 if no cage.
Old 12-20-2011, 03:48 PM   #974
scottofksu
scottofksu's Avatar
Re: Make it handle
I must have read this thread a hundred times now and finally have a plan and some ideas. However, I also have questions... Let me start with my plan, by the way, this is for a 65 Chevy C-10 (383, 5-speed).
Plan:
1 1/8" Sway Bars Front and Rear -
Helwig from Summit (HEL-7423 - $206.69; HEL-7401 - $270.99)
3" Drop Front - 2" from drop spindle; 1" from shorter springs
4" Drop Rear - 2" from lowering block; 2" from shorter springs
30" Adjustable Panhard Bar
KYB GR2/Excel-G Shocks
AGR Performance SB2 Steering Box #204317 - $339.95 (Summit)
Relocate front end weight rearward – Battery & gas tank.
Partial Belly Pan and aero design to reduce front end lift at speed.
18X9 Wheels & 295/35ZR18 Continental Extreme Contact DWS Tires
Goals: 1) To make the truck handle as good as possible so as to support my spirited driving style. 2) To allow for the safe transition of nearly 350 rear wheel lb/ft at idle (1200 RPM) to acceleration.
Questions:
1) Are my plans complete and acceptable?
2) Are the stock mounts appropriate for the adjustable panhard bar or do new ones need to be fabricated?
3) Which would be a better 1st gear for this transition 2.87:1 or 3.28:1?
4) Are the shocks I selected adequate for the price (About $60/shock) or would spending a little more result in substantial improvements?
Thanks!!
scottofksu is offline   Reply With Quote
Old 12-20-2011, 04:31 PM   #975
robnolimit
robnolimit's Avatar
Re: Make it handle
Looks like a pretty solid plan. I recomend our new C-10 sway bar over the Helwigs, especially in the rear. There front is comparable to ours. (ours is 1 1/4) You really need a panhard rod that allows you to adjust the Roll Center. Ours, or Hotchkis. If you have 400+ fl./lb. of torque avail, you dont need the 3.28 first gear, stay with the 2.87. That is a fairly good shock. - but you may want to consider relocating the rear mounts. Our shock mount kit realy does make a difference, better money spent there. When will you be starting.
