Old 12-14-2011, 10:28 PM   #1
69 gmc
69 gmc's Avatar
Sand blasting
I want to do sand blasting myself and from reading a few different threads I have noticed that most who have done it themselves say that they would rather pay to have it done again. What is bad about doing the sand blasting yourself?
69 gmc is offline   Reply With Quote
Old 12-14-2011, 10:38 PM   #2
dmack91
dmack91's Avatar
Re: Sand blasting
Just my 2 cents worth.
I bought a small blasting cabinet and it works great on small projects. So, I decided to sandblast a motorcycle frame I had that I was working on. I used the blast gun out of my cabinet and made an open-air spot to work and capture the sand.
It took me 5 hours. Absolutely sucked. My 5hp, 25 gallon compressor couldn't even think about keeping up.
I guess if you have a very large compressor and enough capacity to keep up with both the air and capturing sand, it could be OK.
Also, look up silicosis, and then invest in a very good respirator.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 12-14-2011, 10:59 PM   #3
fakerwade
fakerwade's Avatar
Re: Sand blasting
What are you thinking of blasting? (frame or body panels or???)
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 12-14-2011, 11:03 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Sand blasting
Yeah what're you blasting?
If its something more than brackets etc PAY SOMEONE it blows
John
1999 Toyota Tacoma 4x4
Old 12-14-2011, 11:30 PM   #5
Holt
Re: Sand blasting
i have a 60 gal ingersol rand air comp. it keeps up ok. but i bought a small syphon blaster, think it holds 60 lbs i think. the problem is even using the biggest tip that comes with it it is very slow going. great for tailgate hinges, door hinges, things of that size. u won't even make a dent trying to do the frame. *just my experience*
Holt is offline   Reply With Quote
Old 12-14-2011, 11:41 PM   #6
LEEVON
Moderator
LEEVON's Avatar
Re: Sand blasting
Ok if you need to be talked out of it, here are a couple of take-it-from me experiences:
1) turning the wrong valve and spraying 10lbs? of sand directly into your previously clean garage.
2) dropping the nozzle while wearing shorts, to find out that indeed your flesh can be blasted off.
3) washing sand out of your orifici (plural for orifice) for a week.
4) making about 3 trips to the store for more sand, while getting close to the cost of a pro.
5) clogging
6) more clogging
7) using enough electricity to power a Ted Nugent concert.
8) do I really need to continue?
Around here I can throw a rock and hit 5 blasting places. If it's any more than a small spot it's not worth it!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-14-2011, 11:54 PM   #7
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: Sand blasting
What is the approx cost of a lwb rolling frame if you take it somewhere?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-15-2011, 01:55 AM   #8
Jeffs70
Jeffs70's Avatar
Re: Sand blasting
as most have said, small sand blasters suck. best to have someone do it, if its a big project
Jeffs70 is offline   Reply With Quote
Old 12-15-2011, 02:01 AM   #9
85chevy383
85chevy383's Avatar
Re: Sand blasting
I paid $300 for my lwb frame and epoxy primer
85chevy383 is offline   Reply With Quote
Old 12-15-2011, 06:25 AM   #10
gysgtc
Re: Sand blasting
I agree with Leevon. I did mine this summer and would pay someone if I had to do it again. I think I'm still getting sand grit out of some of my orifices. I've got a ton of black grit behind my garage so neighborhood cats think it is a giant litter box.
gysgtc is offline   Reply With Quote
Old 12-15-2011, 08:36 AM   #11
cdowns
cdowns's Avatar
Re: Sand blasting
it is a very dirty job no doubt about it
i've blasted stuff for a very long time
have perfected my technique to get the most out of my time when i blast so i dont waste time product or energy
the way i look at ity is if you only plan to do on project in your lifetime it is not worth it
inin the longrun i've saved many tens of thousands of dollars by being able to sandblast things myself
Old 12-15-2011, 08:59 AM   #12
jhwkns
Registered Cruiser
jhwkns's Avatar
Re: Sand blasting
It's no big deal. I'd much rather run my sandblaster than a shovel.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 12-15-2011, 09:24 AM   #13
no moa
no moa's Avatar
Re: Sand blasting
I been blasting for years, i bought a 80 gallon 2 stage compressor for blasting, and i have a TIP 20 gallon blaster. I did my frame, took a couple hours. Its very dirty, nasty job. I only blast outside. Even with the garage doors closed, sand still gets in there somehow. lol
Get a good mask, and blasting hood, you'll be glad you did. (FYI i think you can rent a blaster and hood, the local renting place here i get my sand from, rents all of it and its reasonable)
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 12-15-2011, 10:27 AM   #14
eurospec1
eurospec1's Avatar
Re: Sand blasting
Its really not that bad to do it yourself, in the middle of doing my cab as we speak, it makes a mess but beats the 125$ an hour for 5-7 hours i was quoted by the local blasting shop.
68 SWB Fleet 383
eurospec1 is offline   Reply With Quote
Old 12-15-2011, 11:31 AM   #15
68gmsee
Active Member
68gmsee's Avatar
Re: Sand blasting
Yep, even small jobs can be messy but after what I find out they charge around these parts it may be cheaper to buy a compressor and all the equipment than doing my whole truck by a commercial sand blaster.
Not saying I would do it myself but they must be sandblasting with gold dust in these parts. Check around for prices in your area first.
68gmsee is offline   Reply With Quote
Old 12-17-2011, 07:44 PM   #16
GRX
GRX's Avatar
Re: Sand blasting
My preference is glass beading. But yeah, I agree. With big jobs like frames or body panels, I'd pay someone. Smaller parts are another matter. I do them with a siphon in my empty driveway then sift the beads through a screen and re-use until it's dust.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 12-17-2011, 08:22 PM   #17
odog
odog's Avatar
Re: Sand blasting
If your gonna do it and rent stuff to do it, rent a 185 cfm compressor. Its a screw type compressor and doesnt run out of air. I sandblasted the low boy trailer at work a couple of years ago and it wasnt to bad. with the 185 I never had an air problem. I did it outside so the mess want a problem. WEAR A MASK, the ricocheting sand hurts the face, a dust maks is a great idea, I didnt wear one, but I should have, silicosis is not a good thing.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 12-17-2011, 11:58 PM   #18
doubleb's69
doubleb's69's Avatar
Re: Sand blasting
A sandblast/powdercoat place near me wants $250 to do my shortbox frame, trailing arms, and control arms and that doesn't include primer.
Bud
doubleb's69 is offline   Reply With Quote
Old 12-18-2011, 12:47 AM   #19
biggestjohn
Re: Sand blasting
Not to mention that it is noisier that heck!!
In Indiana, it gets so humid, that by the time you get half way done, its starting to rust again.
There is one bright side:
The next time that you wash your hair, you can scrub your scalp real good!!
biggestjohn is offline   Reply With Quote
Old 12-18-2011, 01:20 AM   #20
mbgmike
Re: Sand blasting
Pay someone .Yes it costs money. Everyone seems to want something for cheap. If you want to waste time buying cheap ass equipment like most , go for it. Even if you are doing alot of blasting work you need high dollar equipment. you can mess around with all these harbor freight and similiar equipment The shop we have a 3 phase portable huge ass 15 hp compressor and a professional pot that cost as much as most compressors but I personally would send it out. You won't regret it. Its a nasty job. $250 to shoot a frame. We pay less but thats still worth it. people have to realize car and truck restoration costs money.
My vote is to pay them. We take it in and its done. Small parts that we decide not to bead blast in a cabinet sometimes cost us a couple of cases of 7 up. Of course we are in a industrial area
mbgmike is offline   Reply With Quote
Old 12-22-2011, 06:56 PM   #21
69 gmc
69 gmc's Avatar
Re: Sand blasting
Paying to have it done sounds like the most time efficient approach
Old 12-22-2011, 07:29 PM   #22
blkcorvair
blkcorvair's Avatar
Re: Sand blasting
Depends I suppose. On what exactly your blasting.
I have a blast cabinet that I blast every small part with. it can be slow, but I usually do a part or two a night, than paint and theyre ready the next day. Sometimes the turn around from a pro is a bit longer.
Bodey panels however I would opt for a pro. Just not to risk warping otherwise good metal. I do have a pressure tank (100 lb) I feed it about every 8 minutes or so re-using approx 60 lbs of media. I use it for parts parts under 4' in length and bring home a large 4' square box to blast in. (with no bottom, I put it on a tarp.)
I stay clean this way, but it does take a long time and I alway have to talk myself into starting and cant wait to finish once I do. My 60 gal compressor has trouble keeping up.
Anything bigger than that I wont bother to attempt. In fact the pro guys love the at home units that eastwood and harbor freight sell, because most get so frustrated they opt to go pro any way. (And also have a new appreciation)
blkcorvair is offline   Reply With Quote
Old 12-22-2011, 08:13 PM   #23
72gmcshorty
72gmcshorty's Avatar
Re: Sand blasting
I found a place that builds dump truck boxes near me. They have their own blasting and paint booth. Got my blazer frame blasted and painted for $200. Maybe find something similar. I have also blasted my own frame at an open air do-it-yourself place. If you go that route, make sure to dress correctly. It does get messy. It is also very tiring.
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 12-22-2011, 08:34 PM   #24
webfoot
Re: Sand blasting
I don't think it is that bad. For 4-5 hrs of filthy work I'd rather spend that couple hundred dollars elsewhere. Sand is $10/100 lb bag around here so I don't see how it almost adds up to a pro cost by doing it yourself. 70 grit works great, get the white silica stuff, the play sand is for kids & cats to play/poop in.
1 word of advice - strain that sand 1st! I have found lots of larger size grit in sand before and a regular kitchen strainer catches all these contaminants. It takes less time to strain a bag of sand than it does to stop and get your tip unplugged. You will also want a moisture separator right next to the blaster, even if you have one on the compressor. You will be working the piss out of that thing and as the air cools down the water is condensing and making your life harder.
Wear a respirator and as much clothes as you can, preferably a hood. (shorts? no!) Silica dust is a health hazard, moreso than launching it at your bare leg at 100 psi+.
To do something big like a frame, make your blasting experience easier and scrape all the old caked on grease and undercoating off. Sand will not remove this as efficiently as good ol fashioned elbow grease. Took me ~3 hours tops to blast the frame for my GTO which is also a full frame. I sandblast everything removable, fenders, trunklid, core support, etc etc.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 12-22-2011, 09:36 PM   #25
leddzepp
Moderator
leddzepp's Avatar
Re: Sand blasting
x 100.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
