Old 12-16-2011, 04:32 PM   #1
chevymotocross
chevymotocross's Avatar
Rear broken shock mount
Anyone ever experience a broken rear upper shock mount? I was adjusting my rear brakes today and noticed. I will have to get it welded.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 12-16-2011, 06:48 PM   #2
rwhit57
rwhit57's Avatar
Re: Rear broken shock mount
Pretty common problem on these old trucks. I have made a plate and used a couple of big washers to fix it temporarily until I could weld it up.
rwhit57 is offline   Reply With Quote
Old 12-16-2011, 07:30 PM   #3
Goldfinger
Goldfinger's Avatar
It's best to reinforce them when this happens. beat the crack straight, weld the gap then weld on a plate and mount your shocks on it.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 12-16-2011, 10:24 PM   #4
Zebb
Zebb's Avatar
Drill the end of the crack to stop if from going any further too.
Zebb is offline   Reply With Quote
Old 12-17-2011, 02:53 AM   #5
kunzy420
Does it look anything like this lol Im going to drill the end of the crack, and plate it. My truck will be bagged so I wont be using the stock shock location anyways.
kunzy420 is offline   Reply With Quote
Old 12-17-2011, 03:52 AM   #6
68 TT
Still plays with trucks
68 TT's Avatar
They really should have made the upper rear shock mount a double shear design. Every one of them I have ever seen has been wallowed out or torn up. Just too much pounding for a single mount point stud.
I'm going to fab up a secondary bracket for mine and convert it to a through bolt design.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-18-2011, 08:34 PM   #7
chevymotocross
kunzy420..... looks EXACTLY like that lol... Thanks for the info guys. I agree it's a pretty lame design IMO
Old 12-21-2011, 11:40 PM   #8
chevymotocross
Does anyone know a part number for the stud that goes through the frame where the shock bolts to? I ended up having to cut mine since the backside nut was completed corroded to the stud. Hopefully these are still available to purchase.
Old 12-22-2011, 12:41 AM   #9
chevymotocross
http://www.classictruck.com/product/...Absorber_Items found it!
Old 12-22-2011, 12:43 AM   #10
kunzy420
If you cant get the studs, Ill check my shocks to see if mine are still attached/useable..and send them to you. like I said if you cant find any or fab anything up.
Old 12-23-2011, 12:19 AM   #11
68 TT
68 TT's Avatar
Pretty much any auto parts store that sells shocks will have them or can get them.
