Old 12-17-2011, 01:45 AM   #1
rcbildr
rcbildr's Avatar
My 83 Z28 project
Just wanted to post a couple pics of my current project. I picked up this 83 Z28 for $400 (saved it from the scrapper) and have been trying to get it road worthy over the last few weeks...I need it for my daily driver.
It's a carb'd 305/ 5spd car. I got it with the seats and most of the interior from an 85 IROC and the distributor had been replaced with a non-computer one. I have the original, but I'm not sure why it was replaced. The clutch linkage was messed up so I got the parts to convert it to a hydraulic clutch. I got most of that done, I just need to bleed the hydraulics. It's still on the jack stands because I have to hook up the back brakes. The PO swapped out the stock rear end with one from the same 85 IROC the interior came from. I just bolted on the hood a couple days ago. The hood is a steel goodmark cowl hood I found in a local wrecking yard for $80. I just need to sand down the surface rust and paint it, but it's been too cold for that. Once I get the brakes finished, All I need to do is rebuild the non-computer (edelbrock 1903 q-jet) carb I bought for it and then it should be good to go. So far the only real rust I've found is around the T-Tops and I hope to take care of that next year.
Before:
After:
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 01-19-2012, 11:18 PM   #2
spudz
spudz's Avatar
Re: My 83 Z28 project
NICE! I fipped a 86 z28 a couple weeks ago. It hardley ran when I got it. I rebuilt a regular non computer q-jet and stuck a regular HEI dizzy in it and it purred like a kitten.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 01-19-2012, 11:56 PM   #3
rcbildr
rcbildr's Avatar
Thanks!!! She's almost ready for the road. All I have left is to finish the carburetor and tune it, but I decided to add one more step. I have a Weiand 8004 intake that's going on it first. I want to get rid of the egr valve and I've heard that sometimes the valve gets stuck open and causes problems. So once the snow melts I will be working at it again.
My Projects:
1978 Camaro Z28
