Old 12-17-2011, 06:30 PM   #1
shermro99
Question Sluggish at High Speed
1970 Chevy C-10 5.7L Gas 400 Trans.
Had the breaks inspected, bearings and alignment done. All is well. Gping 30-45 the truck runs well. Going about 65-70 it seems sluggish. I am not sure what could be causing it. New spark plugs and tune up done. Just seems as though it is trying to pull back when I am going that fast. Any ideas?
R
shermro99 is offline   Reply With Quote
Old 12-17-2011, 06:40 PM   #2
into69z
"brand new second-hand"
into69z's Avatar
Re: Sluggish at High Speed
check the hose coming off "ported" manifold vacuum( on the carb) to the distributor for leaks and cracks. Also, check to see your vacuum advance is working on your distributor. If those are good, look for anymore vacuum leaks and then check your fuel filter,fuel pressure and float level on your carb.
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 12-17-2011, 06:45 PM   #3
72chevyk10
I built it
72chevyk10's Avatar
did the truck recently start being sluggish? my truck is like a garage door on the freeway at all times haha
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 12-17-2011, 07:04 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Aerodynamics are not the strong suit on these trucks. Add in a 3:73 rear gear and you are getting close to the limit of what may be doable. Still, it should run 70MPH without much effort.
Member Nr. 2770
Old 12-17-2011, 11:30 PM   #5
shermro99
It started about 2 months ago. Before that it used to run beautifully
Old 12-18-2011, 12:04 PM   #6
chopnchaneled
chopnchaneled's Avatar
Mine was doing that and it turned out to be trash in the gas and had the filter clogged.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 12-18-2011, 12:06 PM   #7
geezer#99
geezer#99's Avatar
Cam might be going flat. Pop off the valve covers and check the rockers.
Old 12-18-2011, 12:14 PM   #8
shermro99
I highly doubt it's the cam. It was installed brand new last year. It's a high performance can too.
Old 12-18-2011, 01:00 PM   #9
geezer#99
geezer#99's Avatar
New springs too!!
