Old 08-28-2003, 10:57 PM   #1
gmc67swb
gmc67swb's Avatar
question about vintage air
got my kit in and was wondering if any one had this problem. the instructions show a pass through hole in the core support. i don't have this. does any one know where the hole should be. don't want to screw this up, there are pre-bent hard lines that go through there.
also, the allen grove brackets that came with the kit aren't even close to fitting over my headers. did any one have this issue.
thanks in advance
larry
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 08-29-2003, 01:06 AM   #2
A.P.
Black 72 Chevy
A.P.'s Avatar
I don't have any advice to give you but I do want to install a vintage air system into my truck some time in the near future. Could you show pics of your progress. Thanks and good luck.
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 08-29-2003, 01:49 AM   #3
1970blazin
Blazerless:-(
1970blazin's Avatar
I saw a post about this earlier, but can't find it now. Sorry. The guy that installed his vintage air wasn't too happy with the quality of the instructions he recieved.
1970blazin
1970 CST Blazer-Orig. Dark Blue-SOLD
Progress Pics of Blazer for sale
1970blazin is offline   Reply With Quote
Old 08-29-2003, 01:49 AM   #4
1970blazin
Blazerless:-(
1970blazin's Avatar
Here it is.. in the FAQ
http://67-72chevytrucks.com/vboard/s...threadid=61810
1970blazin
Old 08-29-2003, 03:53 AM   #5
A.P.
Black 72 Chevy
A.P.'s Avatar
1970blazin
Thanks.
Old 08-29-2003, 08:49 AM   #6
busterwivell
I just installed my Vintage Air system a few weeks ago. I have an AC cab, and got their kit for AC cabs. EVERYTHING was a bolt on, including the Alan Grove brackets. Do you have a non-AC cab? or a replacement core support?
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 08-29-2003, 01:40 PM   #7
Tim Christian
Tim Christian's Avatar
1967 GMC radiator support I have on my truck is the same way. I am going through the same thing right now. I am going to take a Greenlee Punch and make my hole.
Tim Christian is offline   Reply With Quote
Old 08-29-2003, 04:09 PM   #8
gmc67swb
gmc67swb's Avatar
TOO BAD I DIDN'T THINK OF THAT. WE HAVE A GREEN LEE (HYDRAULIC) AT WORK. I'M OFF FOR 4 DAYS AND DON'T WON'T TO GO BACK. ARE YOU GOING TO USE THE GREEN LEE TO DO THE 2 1/2" HOLES FOR THE VENTS. ARE YOU MEASURING THE HARD LINES TO DETERMINE WHERE THE HOLE SHOULD BE. IF YOURS WORKS OUT BEFORE I CUT A HOLE IN MINE, MAYBE YOU CAN GIVE ME A COMMON REFERENCE POINT AND SOME MEASUREMENTS ON WHERE YOUR HOLE ENDED UP.
Old 08-29-2003, 04:12 PM   #9
gmc67swb
gmc67swb's Avatar
I'M RUNNING A NON-AC CAB. AND THE HEADERS WON'T CLEAR THE GROVE BRACKETS. THE NUMBER 1 (DRIVER'S FRONT) AND THE NUMBER 2(PASSENGER FRONT) HEADER TUBES GO OUT AWAY FROM THE BLOCK AND THEN BACK RIGHT IN FRONT OF THE 3RD BOLT HOLE ON EITHER SIDE, PREVENTING THE USE OF THE SPACERS.
Old 08-29-2003, 04:31 PM   #10
john
member #16
john's Avatar
There are some dimples in your core support to locate the holes. Its been five years,but I think I pulled the battery box and drilled from engine side with a hole saw. There are also dimples on front side to locate holes for drier bracket holes. Hope this helps. John
john is offline   Reply With Quote
Old 09-03-2003, 07:06 PM   #11
gmc67swb
gmc67swb's Avatar
HEY, TIM. JUST CURIOUS TO SEE WHAT PROGRESS YOU MAD WITH THE A/C INSTALL. I GOT MY HOLE THROUGH THE CORE SUPPORT. USED A HOLE SAW. CAME OUT GOOD. MY DAD CAME UP WITH THE IDEA OF USING A COAT HANGER BENT IN THE SHAPE OF THE HARD LINES FROM THE CONDENSER TO LOCATE WHERE THE WHOLE SHOULD BE.
Old 09-04-2003, 08:52 AM   #12
Tim Christian
Hey gmc67swb, That is a Great ideal your Dad has with the coat hanger. I will give it a try. I have not had much time to work on my truck. Since I started selling truck parts I have no free time at all. I am going to finish it the winter if I have to hire someone for the parts bussiness.
Old 09-04-2003, 01:14 PM   #13
Mixup
I used a hole saw to go through the support. I just bolted the condenser in place and held the lines up and marked the support. I used Zoops brackets for the A/C, Alt and P/S and they worked great.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 09-04-2003, 01:37 PM   #14
mrein3
mrein3's Avatar
I just happened to be looking at the factory assembly manual last night in preparation of making my own AC system out of various stock parts. According to the manual there are dimples for EVERY hole you need to drill. The manual even tells you what size the holes were from the factory.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-04-2003, 06:41 PM   #15
gmc67swb
gmc67swb's Avatar
THAT'S PRETTY COOL, BUT I SWEAR THERE WAS NO DIMPLE IN THE AREA WHERE I DRILLED MY CORE SUPPORT. MAYBE THE GMC IS DIFFERENT. THE KIT CAME WITH TEMPLATES FOR THE HOLES IN THE DASH AND I KNOW THERE'S NO DIMPLES THERE.
Old 09-05-2003, 06:24 AM   #16
Tim Christian
Smile
Hey gmc67swb, They are no dimples in mine either.
Old 09-05-2003, 07:19 AM   #17
mrein3
mrein3's Avatar
You're right. There are no dimples in the dash. But the core support has dimples for the "big" hole you run the hard lines through, it has dimples where you drill holes to mount the condensor and receiver/dryer. The kick panel on the passenger side (for the vacuum pot to operate the door) has dimples too.
'72 Malibu hard top
Center City, MN
Old 09-05-2003, 09:44 AM   #18
Mike Culpepper
Red
Mike Culpepper's Avatar
GMC67swb,
I'm guessin you aren't quite at this stage in the install yet, but something to think about. My V.A. system calls for you to remove the pass. side kick panel vent door and silicone in a block off "plate" they supply, in order to prevent hot air comming into the cab. I did this, but got to thinking later on that by doing this, it's going to be alot harder to get access to the area behind the kick panel in order to clean out the leaves and other gradoo that tends to accumulate there. I'm not quite sure what the "solution" to this would be, but maybey you could brainstorm a bit. Maybey some way of using a gasket or foam weatherstrip ans an extra sheet metal screw(s)???????? I guess installing a trash guard in the cowl area would minimize the need to clean the kick panel recess out. Anyway, I never thought about this when I was installing my system.
Also I would recommend you bench test the unit like the instructions call for.....I almost skipped this step thinking it unnecessary, but my dealer said he's had 2-3 units in the last 4-5 years that have had problems, and the time to find that out is BEFORE you install it. Like my grandpa said....a million to one odds don't mean anything if you're the one.
Mike
'72 Cheyenne LWB 350/350
"The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game).
Mike Culpepper is offline   Reply With Quote
