Old 12-18-2011, 09:59 PM   #1
Last_Paladin
Where can I find billet "AC balls"
I want to get rid of the plastic. Where can I find nice drop in AC vents for a stock dash board?
I have billet everything else...
Last_Paladin is offline   Reply With Quote
Old 12-19-2011, 12:26 AM   #2
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Where can I find billet "AC balls"
Time for you to spend 500.00 per side for a CnC machine cus i want5ed a set of hub's made for my Bmx bike and they said 500--900 per hub out of a brick of alum so if you have money to spend or know of a guy that can cast them out of alum it might be cheaper best off make about 50 sets so you can pay for the prossess of 5000.00
stsalvage is offline   Reply With Quote
Old 12-19-2011, 05:24 AM   #3
cdowns
cdowns's Avatar
not billet but around the same time frame some highend cars had the exact same balls made of cast potmetal that was chromed
if you've got an oldtime junkyard you could spend some weekends lookin
i'm thinkin riveria toronado or caddys would b where they might b not sure tho
Old 12-19-2011, 07:27 AM   #4
I like less plastic. But,I can live with these rather than spend big bucks just to know I have billet sitting inside a plastic housing. I'm sure you could ditch the whole factory outlet deal and use a billet product made for street rods. It doesn't appear you are concerned with an original look.
Old 12-19-2011, 09:54 AM   #5
Last_Paladin
Not going even remotely factory. Did you link something?
I despise plastic. I also don't feel like cutting or welding to a painted dash. so, if I can replace the entire thing,including the housings, I am game.
Old 12-19-2011, 10:32 AM   #6
Last_Paladin
Found these:
http://www.hotrodexpress.com/index.p...t_detail&p=204
May be able to make a sheet metal outer sleeve that replaces the plastic...
Old 12-19-2011, 10:38 AM   #7
No,I didn't link anything as far as I can tell. But,here are some:
http://www.billetspecialties.com/pro...cid=8&scid=113
http://www.jegs.com/i/Billet-Special...oductId=756994
http://www.zigsstreetrods.com/Pages/...or.html#ACVent
http://www.streetrodgarage.com/louversandvents-1.aspx
http://www.shop.triquemfg.com/A-C-Vents_c7.htm
http://www.zirgo.com/catalog/Air-Conditioning/AC-Vents
http://www.trucknvans.com/Billet-A-C-Vents-s/671.htm
They may not all be a straight forward no alterations installation but should be a good start to give you some ideas. When you want to go custom you may have to alter,requiring paint.
Old 12-22-2011, 10:44 PM   #8
Yes,I did. Did you reply? I see you posted one source while I was posting. Got any ideas?
Old 12-23-2011, 02:00 AM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I like the Jegs one.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-24-2011, 12:24 PM   #10
Last_Paladin
Found these, that look like the will work.
Old 12-24-2011, 02:14 PM   #11
darkhorse970
darkhorse970's Avatar
What does the face of it look like? Who makes/sells them?
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 12-24-2011, 03:56 PM   #12
Andy4639
Old member
Andy4639's Avatar
Wink Re: Where can I find billet "AC balls"
I found these.
http://www.ss396.com/mm5/merchant.mv...ode=camaro6769
http://clubroadster.net/vb_forum/sho...d.php?p=975701
Says he found them on Ebay.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-24-2011, 07:32 PM   #13
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Where are these from?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
