1956 truck spare tire
where does the spare tire go on a 56 chevy 1/2 ton i dont have the spare tire fender so i know it mounts under the bed ? but i never seen one mounted there would it be same bracket from a 60s trucks ?
#2 | |
Re: 1956 truck spare tire
I could be wrong though because the Cameo trucks had a special mount under the bed, so maybe they also fitted the step-sides with a similar mount?? |
#3 | |
![]() Join Date: Jun 2007
![]() Quote:
my truk has it's spare handy at it's side.
![]() yes, the 55-59 had a bracket under the bed, most were discarded because they are such a pain to get at. you had to jack up the spare just to unbolt the bracket. if i need a spare tire carrier, i'd look into fitting a tire winch under there, like they have on the new vehicles. or travel with a tire wench, let her get your spare out... ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
my 49 spare tire was mounted behind the rearend from the factory, mine was missin so i used a spare tire underbed mount off a 60 model chevy truck an worked perfect
ogre, i was gonna use the winch setup myself but after askin a bunch of people an seein for my self, they brake why to easy an have seen damage on hotrods from this, i would suggest if u went that route by a brand new one,
Mines in the bed.
Truck's just for the fun of it. ![]() |
cool thanks alot for all the replies , i have the brakets from a 69 chevy truck i had i will see if it works and ifts if not i can just drill an extra hole
hey OGRE where did you get your bed wheel tubs ? or did you make those your self ,like the countors like the bed has ?
#10 | |
![]() i cut the bed side with a jigsaw and reused the cut out for the tub. i cut some 10ga steel 3'' wide for the tub portion and just welded them together. ![]()
