Old 12-20-2011, 10:48 AM   #1
205dke187
sectioning front crossmember
if i take 1.25" out of my front crossmember, that will raise my lower control arms that much. correct? well, do i still mount the upper control arms in the stock location? (off the side of the frame?) or do i need to move that mounting point UP 1.25" also. like to the top of the frame? any help will be greatly appreciated.......
205dke187 is offline   Reply With Quote
Old 12-20-2011, 11:50 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: sectioning front crossmember
The upper mounts will move too, if you section only between the frame rails. You could leave the uppers in place, by sectioning the entire crossmember, which will be similar to using tall balljoints and will increase camber gain.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-20-2011, 09:16 PM   #3
205dke187
so if i section the entire crossmember, move the lower control arm mount and the upper control arm mount up 1.25", then everything should be like stock geometry? i do need to take lots of measurement and set the spindles at the angle they where before the section? any pics would be awesome....... thanks so much for your help already.....
Old 12-20-2011, 09:57 PM   #4
SCOTI
SCOTI's Avatar
The geometry might get worse. The already poor (factory amount) of bumpsteer will prob get worse. You can swap in a NoLimit R&P kit & fix that issue easy enough....
http://www.67-72chevytrucks.com/vboa...d.php?t=465423
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-20-2011, 10:04 PM   #5
205dke187
Thanks for that information. I am gonna do a rack and pinion set up. So i am right in thinking that i should keep all of my angles and measurements the same as stock. Control arms will just be in a different location.
Old 12-20-2011, 10:40 PM   #6
SCOTI
SCOTI's Avatar
Yep, that's the basics of it.
There are 2 different 'common' methods: a) removing a section out of the middle of the entire width of the x-member; or b) notching out a section just where the frame rails seat.
Choice 'a' allows you to maintain the factory gap between the oil-pan & the x-member as well as using the factory mm towers/mounts. Option 'b' requires new mm towers (or modifying the factory units) & possibly some clearancing depending on the engine size/oil pan type.
Option 'b' is what NoLimits bases their R&P kit off of. I'd check w/them to determine if their kit will possibly work w/option 'a' if that's a concern....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-20-2011, 11:13 PM   #7
giles70chevy
giles70chevy's Avatar
Check out this build thread from dnd1978. He's doing a section now and is using a rack and pinion unit. He's doing a really nice/clean job too.
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
giles70chevy is offline   Reply With Quote
