#126 |
65 suburban vortec 5.3 bagged
Re: Mesquite 1966 C10 - LS3 W/Air Ride
I cant believe how clean the shop is!!!super nice build nice work i just got my ls 5.3 runnung and drove it and it was great yours should be awesome!! Thanks for all the pictures!!!
Posted via Mobile Device |
#127 | |
![]() ![]() Join Date: Oct 2011
Not sure yet, I like the bench seat, but I'm also thinking about building a center console out of mesquite as well.
Thanks, I learned a year ago on this site pictures are worth a thousand words and that saves me a thousand misspelled words ![]() Quote:
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
#128 |
Got the front of the motor installed, air conditioner compressor is tight, I will have to drill some holes in the rails to install the bottom two bolts, or remove the motor again.
I sure hope someone makes some short 90deg A/C line. ![]() ![]() ![]() ![]()
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 Last edited by 66ChevyMax; 12-19-2011 at 02:33 AM. |
#129 |
I'm very surprised at how short the throw of this transmission is, cross member is temporary.
#130 |
60-66 Nut
Yeah, the A/C mounting seems to be about the biggest issue with the LSx swaps. I haven't kept up on what guys are doing about it, since I am still working with Gen I engines. If you haven't been there yet, you might check out possible solutions in the LSx Swap section......
http://www.67-72chevytrucks.com/vboa...ysprune=&f=206
#131 |
Wow.. That is so nice. You are gonna have a truck that is by far better then a new one you can buy at any dealership.. I know the planning that goes into this is extreme. Do you sleep at night?
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
#132 |
Man Im glad you posted pictures of the Vette accessory belt system. I new it would clear..haha The truck setup that most people run is uber ugly. After owning a Nova with an LS2 and Vette accessories it looked like it would clear on these trucks. You just proved it..
Thanks again! |
#133 | ||
Sleep like a baby "when thing go perfect"
![]() Quote:
#134 |
Well the front rail has two new holes. Lower left hole is half way on the cross member bolt. To get the lower left bolt in it has to go in first and I had to shorten the treads by about 1/2".
Upper left bolt was replaced with a standard bolt, it's all tight now! ![]() Starter is in. ![]()
#135 |
Rear disc brakes are in "finally"
#136 |
Two more
#137 |
Rollin' Old Skool
niiiice!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#138 |
454 club
nice build
David 1965 Chevrolet c-10 454 automatic Custom bbw swb. 1965 Chevrolet C-10 swb (Sold) 1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's. R.I.P "I will miss you. 1967 Chevrolet C-10 6 Cyl Custom lwb 1939 Chevrolet Coupe, 350 v8 automatic. 1935 Chevrolet 2 Dr Standard in the works. 2015 Harley Davidson Street Glide. 2023 Chevrolet Stingray Z51 Convertible. I never want to grow up. |
#139 |
BTW did you ask to have a double bellowed air bag in the bag? My understanding was thatn type of bag was used for hauling it's almost to much for the back end of our trucks, versus just a single sleeved bag that is much softer and really on handles the hieght of the vehicle.
Just curious |
#140 | |
Double convoluted bags work well in a truck arm application because the leverage is increased because they're located further forward of the rear end vs when the bag is mounted directly to the rear end housing. The dbl convoluted bag is the standard bag spec'd for these truck arm set-ups.
#141 |
Awesome, clean and well thought out work man!
Those CPP rear disk setups look well made. Any install issues? BTW what ever happened with that BOSS front wheel issue? I know alot of guys on here have talked about how the BOSS 338's have fitting issues with the larger 1 1/4" rotors and wont fit over the hub unless you have it machined down. For your engine I see that you used CPP perches...are those the motor mounts and adapter plates they sell as well? Kinda like a complete kit? What headers are you thinking of running? Keep up the great work and keep the pics coming!
Tommy~ The difference between genius and stupidity is that genius has its limits -- Albert Einstein 63 build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=317341 |
#142 | |
Thanks |
#143 |
Thanks a million
#144 | |
Well obviously scoti knows more than me. This is my first experience with bags, I've used air shocks before but not bags.
This kit it the Level 3 kit from ridetech, as listed on their website with no modifications. Quote:
#145 | |
Thanks custom, drivers side rear disc went on with no issues, I had to persuade the bracket on the passenger side a little. Outside pad was way too tight.
As for the BOSS problem, there is apparently two versions of this wheel out there. The first pic on left is the one that fits, the second does not. Notice the difference in the center bore and the cap mounts completely different as well. ![]() ![]() CCP mounts and perches work well and come as a kit. They do create header problems. I tried some BBK headers for a camaro but no luck (pic below) sanderson headers has one (shorty) that looks promising. Talked to Doug Thorley Headers they say they will have one in about 6 weeks? ![]() Quote:
#146 | |
Fellow Texan, you da man!
![]() Quote:
#147 |
#148 |
Just West of Lubbock, actually the two have grown together. Frenship School District.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 Last edited by 66ChevyMax; 12-21-2011 at 07:56 PM. |
#149 |
![]() Join Date: Aug 2004
66ChevyMax, I used the Sanderson Shorties, CSLS1 is the part number, I am very pleased with them.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#150 |
Ahhh.... I was just in Lubbock last Wednesday (Texas Tech). My GF's daughter was in a car accident the night before their semester ended for the holiday break. We had to go pick them up & move 'em home for a month.
