Old 12-23-2011, 10:26 AM   #26
Gene
Gene's Avatar
Re: Shade tree mechanics at their best. Your opinion please!
I agree. ez out is the best option.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 12-23-2011, 02:26 PM   #27
slomotion
Old Duffer
slomotion's Avatar
When you re-assemble the parts, a little Never-Sieze or teflon tape won't hurt.
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 12-23-2011, 04:30 PM   #28
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Originally Posted by baja View Post
They make a tool for removing that. most auto stores have it.
X2.
The right tool for the right job makes life easier.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 12-23-2011, 05:42 PM   #29
OhOneWS6
OhOneWS6's Avatar
Originally Posted by dfwright View Post
Wow... I still have the original on my Suburban. I think I'll go pull it off and replace it before I end up in the same boat.
Be prepared. 95% of the time they break if they are the original pot metal piece. The saw method is by far the easiest way to get the broken one out. You will be surprised at how easy that soft metal is to cut and how easy it is to knock the pieces out after you cut a slot or two in it.
OhOneWS6 is offline   Reply With Quote
Old 12-26-2011, 04:05 AM   #30
Rooster's 67
Rooster's 67's Avatar
WOW.. all I can say.
Heres Link to the proper removal tool http://www.google.com/products/catal...ed=0CEkQ8wIwAg
And any part store that calls itself one should stock the aftermarket Steel Fitting. and they should be able to cross this part number:
ACDELCO Part # 1530900
or
DORMAN Part # 800401
Do it right and be done with it,
you'll spend more on eaze-outs and a tap, and other crap.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-26-2011, 09:40 AM   #31
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Just checkin in to see if you got it out?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-26-2011, 10:16 PM   #32
allchevy58
allchevy58's Avatar
NAPA sells the tool to remove it and then bought a nipple and run rubber hose.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 12-27-2011, 04:05 AM   #33
lil hoodlum
lil hoodlum's Avatar
Oh boy! I wanted to thank everyone for their input and advice!
I haven't worked on it yet. I bought an 1/2 inch easy out but have decided to use a heater hose coupler remover like the one that Rooster's 67 posted. I thought I would be working on this Christmas day but was enjoying the day instead.
Hopefully tomorrow will be the day that I can get this project done! My girlfriend is currently using her step dads truck. He is out of town but will be back in the next few days so it's got to get fixed before then.
I would like to get my girl to make a video of me fixin' it so that I can post it here for anyone else who may run into the same problem as us.
I laugh about it now, about how I was going to "fix" it with some copper tubing and J.B. Weld. Everyone who has posted has encouraged me to repair it correctly the first time. I am sure my planned "repair" would have failed at the worst time.
Again thank you everyone for the advice! It is very much appreciated!
Keith
lil hoodlum is offline   Reply With Quote
Old 12-29-2011, 10:41 PM   #34
lil hoodlum
Well I finally had a day off from work so I decided to get this truck fixed and back on the road. I went ahead and purchased a heater hose coupler remover tool made by Lisle at O'reilys. Was like $6.
I ponded it in, didn't have to pound it to hard because the metal was pretty soft. I squirted some penatrant to aid in the loosening up. I attached my ratchet on the coupler remover with a 5/8" socket and gave it a couple turns. I instantly knew that the metal was too soft and the coupler remover wasn't going to work.
So I just got to it with a screwdriver and hammer. The metal bent so easily and actually got 2 good size portions cleared out of the way. The left over fitting opening was too large for my tap and die set.
So I headed back to O'reilys to find the correct size tap. Unfornutely they didn't have one that size. I ended up using a hook and pick set to scrape the remants out of the threads. I tightened up the fitting hard but not too hard to strip the threads. Then I took the fitting off and would pick some more of the old coupler out of the threads. It took me a little over an hour to get most of it out. I called it good enough for government work and wrapped some teflon tape around the new fitting and snugged it down. I also replaced both of the heater hoses while I was at it. I bought a new heater core but unforunetly I got confused and told them it was without A/C. My girls truck has A/C, mine doesn't.
Well so anyways I will replace the heater core with the correct one and also replace her thermostat and radiator hoses next.
I got everything put back together and her truck is back on the road. I just wished it wouldn't have taken me 2 weeks to get this thing fixed.
Again, I want to thank everyone for their input and advice!
Keith
Old 12-29-2011, 10:45 PM   #35
lil hoodlum
more pics.
Keith
Old 12-30-2011, 12:07 AM   #36
mcbassin
Still Learning
mcbassin's Avatar
Way to go Buddy! I told you could do it. It looks like an EZ-out would have done you no good either. I'm glad you got her fixed up right.
Old 12-30-2011, 11:20 AM   #37
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Originally Posted by mcbassin View Post
Man, I would get an ez-out that fits the hole closely. Heat it up the intake around the fitting with a hair dryer or a heat shrink type heat gun. Then just try easing the left over fitting out.
If that doesn't work you can stuff a small rag inside the fitting then cut through the fitting with a die grinder on both sides being careful not to get shaving inside the manifold (that's what the rag is for). Be careful not to cut throught the threads. Then just break the fitting in two pieces and unscrew what's left.
I have done a ton of these kind of repairs. If you have time to wait I will send you an ez out.
You don't need to take the manifold off to get that thing out. Or take it to a machine shop.
Use one of these once you get it out.
I have performed this exact repair just like mcbassin describes using the dremel tool. You could also use a small round hand file to "cut" in two small reliefs in the old pot metal. The relief cuts will reduce the pressure caused by the corroded pot metal swelling. Done carefully, you might not have to run a tap into the manifold if the corrosion isnt too bad.
Just saw I posted to late! Congrats on the successful repair!
Al
'69 GMC 2500 Custom Camper
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 12-30-2011, 12:26 PM   #38
BurnoutNova
BurnoutNova's Avatar
Originally Posted by Maxxd07 View Post
Anybody that works on these for a living has a special tool that removes the broken piece with ease. Maybe you have a friend or a old classmate or someone you know that is a mechanic or works at the local chevy garage that could loan you the tool? It has some strait groves in it that are sharp and tapered. You beat it in with a hammer like an easy out but it works 10 times better. The replacements are better but I still consider it a serviceable item, like when the coolant is changed replace it. Keeps the head pains at ease.
http://buy1.snapon.com/catalog/item....re&dir=catalog
I use one of these, works pretty good most of the time.
BurnoutNova is offline   Reply With Quote
heater core pipe fitting, intake manifold repair, shade tree mechanics
