Old 12-23-2011, 07:02 PM   #1
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
NP 205 questions
Hi All, got my np 205 torn apart while restoring the K20. It looks to be in great shape but how exactly do you tell if the input shaft bearing between trans and tcase is good or should be replaced? It feels smooth and stable but the thrust play of the sleeve is about 0.010" and it will angle a degree or two if you push it sideways.
Rest of case looks great, I read that they hardly ever need bearings and this truck has only 90,000 on it and fluid was full and looked good. Teeth show no signs of wear. Anything else I should do besides bearings and seals before i put it back together?
Also, anyone know specs on the orange color of these?
These needle bearings are a pain aren't they? Stuff falling all over gosh darn it Do you guys use chassis grease to keep them in place for reassembly?
Thanks,
Jud
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-24-2011, 03:31 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: NP 205 questions
Jud,
Assuming your talking about the bearing on the sleeve in the adapter between a t350 and the 205. It is the only one I usually find bad, Personally I would replace that one just because, Yes the rest of the bearings rarely ever need replacing unless of course the 205 had been run dry.
I would just do the one bearing and all the seals, make sure to compare the two seals in the adapter with your new ones as I have found there are more than one, I think there is a 1st design and 2nd design version. (not sure which is which)
I think the color is "Red Oxide" as in the old hot rod primer color.
Yup the needle bearings are a pain. I just use grease to hold them all in place.
If you remove the idler gear make sure you have the torque specs when putting the big nut back on, as the end play is crucial, I personally use locktite on the nut.
Livrat is offline   Reply With Quote
Old 12-25-2011, 11:43 AM   #3
Vintage Windmills
Vintage 4x4s
Thanks Mark! it does look like red oxide now that you mention it.
Old 12-26-2011, 10:25 AM   #4
madcow75
madcow75's Avatar
Yes use lots of grease for needle bearing re-assembly.
madcow75 is offline   Reply With Quote
Old 12-26-2011, 11:07 PM   #5
Vintage Windmills
Vintage 4x4s
Also do you guys know what bearings spin when in 2x4? Just the input and output or does the idler (middle gear) also turn? Mine's too hard to shift with some parts out now. Thinking maybe I'll replace all the 2x4 bearings to assure quiet operation since its apart this far anyways.
