Old 12-24-2011, 02:00 PM   #1
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
HEI Question
I am trying to hook up a tach on my HEI distributor. I'm from the old school where it meant hooking to a coil. I see on the HEI where it should be hooked but I don't know how it hooks. I looks like it takes a special plug that I don't have and don't even know what to ask for at the parts house.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 12-24-2011, 02:04 PM   #2
1972RedNeck
1972RedNeck's Avatar
Re: HEI Question
The "correct" plug has a little clip to hold it in. A normal female spade connector works great.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-24-2011, 02:08 PM   #3
kcsa75
kcsa75's Avatar
Re: HEI Question
I guess it depends on the HEI, but I just used a spade connector and all was good.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 12-24-2011, 02:19 PM   #4
BIG CHEVY 3600
Re: HEI Question
Your pic is female spade, is that the right spade?
Abraham Lincoln
Old 12-24-2011, 02:19 PM   #5
booger1949
Re: HEI Question
i used the same spade on mine
booger1949 is offline   Reply With Quote
Old 12-24-2011, 02:29 PM   #6
kcsa75
kcsa75's Avatar
Re: HEI Question
Yes.
Willie
'72 C10 Highlander
Old 12-24-2011, 02:33 PM   #7
BIG CHEVY 3600
Re: HEI Question
Thanks guys, the check is in the mail.
Abraham Lincoln
Old 12-24-2011, 02:53 PM   #8
Tims37chevy
Re: HEI Question
Or the next time your in the salvage yard keep your eyes open for an oe type connector
Tims37chevy is offline   Reply With Quote
Old 12-24-2011, 07:52 PM   #9
azsnow
azsnow's Avatar
Re: HEI Question
You can get them from Summit for under $5. All it is is infact a spade, but if you want the one with the clips, here it is. I am using the one for the power wire.
http://www.summitracing.com/parts/PCO-5664PT/
azsnow is offline   Reply With Quote
Old 12-25-2011, 03:08 AM   #10
mr48chev
mr48chev's Avatar
Re: HEI Question
The female spade does work but I had problems with the one on mine getting just loose enough to cause the engine to either quit or misfire. I finally picked up the correct one with the locking tang on it.
This is what you need and you should be able to get a similar one at the local parts house. http://www.repairconnector.com/produ...d-Repair-.html Nabbing a used one and a length of the heavy gage wire to go with it works too though.
Old 12-25-2011, 05:05 PM   #11
OrrieG
OrrieG's Avatar
Re: HEI Question
I just used standard spade connectors for my power and tach too. Does the factory clip type have both wires, or two separate like the Pico ones?
Old 12-25-2011, 11:45 PM   #12
booger1949
Re: HEI Question
should have both wires
