Old 12-24-2011, 04:14 PM   #1
bakerboys
bakerboys's Avatar
clicking noise sounds like transfer case
I have 85 k20 37 inch tires had driveshaft lengthend and rear gear 4.10 replaced it was making a bad grinding noise thats all good now Just put a 355 roller in it wow is she fast to be big BUT new problem every now and then I hear a taptaptaptaptaptaptap noise its not the engine
Sounds like it is coming from where my rear driveshaft goes in to transfer case does not do it all the time If i manually shift into 1st or second its there go back to drive its still there put it in nuetral and back to drive it goes away mostly does it when first taking off or taking off and turning at same time
trans th400
t/case 208
3/4 ton truck
thanks for your help
bakerboys is offline   Reply With Quote
Old 12-24-2011, 04:41 PM   #2
bakerboys
bakerboys's Avatar
Re: clicking noise sounds like transfer case
has a good size lift not sure exactly how big do you all think a transfer case drop is a good idea or not
Old 12-24-2011, 06:52 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Nothing more than a stab in the dark, without being able to hear it.... maybe a u-joint going bad?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-24-2011, 06:54 PM   #4
mud.man.rj
mud.man.rj's Avatar
I am with stocker, try the ujoints first, the usual culprit.
mud.man.rj is offline   Reply With Quote
Old 12-24-2011, 07:01 PM   #5
bakerboys
bakerboys's Avatar
They qre brand new have you ever heard taptap noise from transfer.case before
Old 12-24-2011, 07:23 PM   #6
mud.man.rj
mud.man.rj's Avatar
I must say though that I have heard noise from a 208 transfercase that my buddy had problems with when we were out 4 wheeling that sounde very simular and was the chain in the t.case slapping around, put it up on stands and run it. maybe the new ujoints aren't as good as you think, like a needle fell out when installing. Grease them and see if that helps temperarily, got to locate the sound somehow. Start crawling under the truck and checking all you can.
Old 12-29-2011, 01:59 AM   #7
rayfinseats
Sometimes flexplates crack arouund the crankshaft and the noise is hard to detect unless you pull the flexplate to look at it. Just remember that as a last resort. Sometimes this sounds like an engine knock.
rayfinseats is offline   Reply With Quote
Old 12-29-2011, 06:27 PM   #8
chevy71super
Likely the thrush bearing in the T-Case is worn. Happened to me. Does the T-Case have a part time conversion kit in it?
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 01-03-2012, 11:29 PM   #9
bakerboys
bakerboys's Avatar
MAN FIGURED IT OUT
the noise was from the shield that covers flexplate and converter
took it off noise stopped and inside shield is scraped up inside
New Noise NOW converter is rattling WOW my luck guess Trans rebuil is in my future
Old 01-04-2012, 01:10 AM   #10
mud.man.rj
mud.man.rj's Avatar
Convertor usually only rattles when the convertor isn't shimmed back far enough into the front pump or is shot, but could just be the front pump if it has worked well for some time. So ya trans rebuild.
