Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-24-2011, 01:31 AM   #1
dbmx66
spark plug indexing?
ive been hearing alot of mixed thoughts on this lately.
if indexing spark plugs makes a difference or not.
so let me ask some of you before i think about about doing it or not.
is it worth it?
what gains are there, if any?
should the ground strap be in the 12 oclock position or 6 oclock position?
we index the plugs in the race car, but thats because it has big dome pistons... for clearance, not for performance gains... well at least thats what i thought. maybe im missing something.
fill me in, id like to know more about this.
thanks
dbmx66 is offline   Reply With Quote
Old 12-24-2011, 01:58 AM   #2
Gumby
Gumby's Avatar
Re: spark plug indexing?
You can index both plugs and cap n rotor
Gumby is offline   Reply With Quote
Old 12-24-2011, 09:22 AM   #3
WAAF
on a street car you'll never notice it.. but at the track you'll see it in e.t
I've always wonder what would happen if you cut the ground off and welded on a washer that the hole was the gap you wanted.. it have a larger area than the ground strap, and not need indexing..
WAAF is offline   Reply With Quote
Old 12-24-2011, 11:59 AM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
I found nothing on the dyno or on the track with being overly anal about indexing on a small closed chamber head like a SBC AS LONG AS the spark kernel wasn't shouded by the ground strap. I mean there is about 180° there that is ALL WRONG for sure, but I havent found any measurable proof at the 797 n/a HP level that there is any 3HP in spark plug indexing,, and believe me,, we looked and looked for those last 3 HP
But that's just my combination,, your results may vary.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 12-25-2011, 02:06 AM   #5
raceman6135
Dino burner
raceman6135's Avatar
Like Marv, I haven't found any notable difference on the dyno or dragstrip to make indexing spark plugs worthwhile.
However, I do have to index my plugs because of the size and shape of the dome of my pistons and how close they come to the heads. In other words, if the ground straps are in the wrong position, the piston can kiss them and close up the gap.
raceman6135 is offline   Reply With Quote
Old 12-25-2011, 05:01 AM   #6
WAAF
I've found when you spray.. it makes a diffence..
Old 12-25-2011, 11:36 AM   #7
vin63
It's Better With Nitro
vin63's Avatar
X2...we dyno and have dyno'd all sorts of combinations for 20+ years and continue to find nothing measureable (supercharged, nitrous, NA, etc. combinations) between identical pulls, as well.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-29-2011, 03:52 PM   #8
dbmx66
does the ground strap go in the 6 o clock or 12 o clock position?
