Old 12-25-2011, 08:02 PM   #1
Jemo
Ideas for running wires under carpet to back of cab?
I won't have a console in the truck but need to run a few wires to the back of the cab from under the dash. Is there some type of conduit that is flat so it isn't noticeable when the carpet lays over the top? What are some other ideas?
Jeff
'59 Big Window Fleetside
Jemo is offline   Reply With Quote
Old 12-25-2011, 08:22 PM   #2
81ShrtBox
MadMan
81ShrtBox's Avatar
Re: Ideas for running wires under carpet to back of cab?
i usually run mine under the door sill molding... or run wires on bothsides so you dont have so many wires run in one spot.
But, there is a flat conduit if you can find it.
81" Shortbed C10 Full Restoration underway, who needs a budget?? LS Pro Touring Build
81ShrtBox is offline   Reply With Quote
Old 12-25-2011, 08:24 PM   #3
Wybrow
I've used steel brake line, fuel line, you can get it in a bunch of different sizes, but I'm not sure that it would be very discrete under your carpet, worth a shot, though.
Wybrow is offline   Reply With Quote
Old 12-25-2011, 09:47 PM   #4
Trucknut57
Trucknut57's Avatar
Why not run them out with the main harness and bring them back up thru where the original gas line goes out of the back of the cab. This was you don't have a bunch of wires messing up the carpet.
Just my .02
Somehow, the idiots survive despite their best efforts to kill themselves.
- dcozzi
Trucknut57 is offline   Reply With Quote
Old 12-26-2011, 01:48 AM   #5
OrrieG
OrrieG's Avatar
If you look in the big box home stores in the electrical section they have flat metal conduit, about 1/2 inch high x 1 or so inch wide. I think it with the Wiremold. I am going to use that, my floor insulation and carpet pad will be about the same thinkness so carpet will lay flat.
Old 12-27-2011, 12:03 AM   #6
G&R's57GMC
G&R's57GMC's Avatar
You could use trailer wire , flat 4 wire or flat 5 wire.
G&R's57GMC is offline   Reply With Quote
Old 12-27-2011, 12:15 AM   #7
OrrieG
OrrieG's Avatar
My 64 chevelle has a flat wire harness from the front to the back under the driver and back seat too. It has wires for the brake, tail, turn, backup lights and gas tank sender. Probably for the trunk light option too.
Old 12-27-2011, 12:41 AM   #8
parkwood
parkwood's Avatar
What i try to do if i need to run wires to the rear is lay the wires out flat and tape them down.. you can't get them any thinner than that.. you can see from the photo how i did it in the '67 chevelle
parkwood is offline   Reply With Quote
