Drag Shocks?
Hey folks.. I'm in the market for a nice set of front drag shocks for my '68 GMC. What can you guys recommend?
384 Stroker Small Block- Best ET: 13.24@103 |
The Engine Whisperer
Re: Drag Shocks?
Afco.
#3 | |
It's Better With Nitro
Re: Drag Shocks?
I run a double adjustable QA1 coilover set on my Super Gas car.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Re: Drag Shocks?
If bolting in stock location, I recommend QA1 stocker star. Compression is permanently set stiff, and rebound has 12 settings. They worked well on the stock front suspension. Paul
Re: Drag Shocks?
I'm looking for something budget minded.. I was looking at the Competition Engineering 2615 adjustable shocks...? The suspension is stock style, stock shock location. Will be using Moroso Trick springs, drop spindles, nothing fancy.
On a budget like Fred Sanford
Re: Drag Shocks?
I really like Strange stuff. Have their single adjustable coil-overs on my camaro and love them.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
Re: Drag Shocks?
The QA1 stocker star R series part # TR505 is 159.00 each through Summit. I believe I paid a little less through a local speed shop here in Atlanta. Paul
6>8 Plugless........
![]() Join Date: Sep 2007
Re: Drag Shocks?
I have competition engineering shocks on my Vette and they work great. Keep in mind that my car has more weight in the front than most pick ups do that are drag racing.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#9 | |
Re: Drag Shocks?
Posted via Mobile Device Posted via Mobile Device
Justin weight 3480 with driver 1.35 60ft 6.13@111mph 1/8 mile 9.80@131mph 1/4 mile 434 small block all motor |
Re: Drag Shocks?
Oops, that is just the part # that the Summit site spit out when I searched for our trucks. The price should not be any different though. YOu might have to call QA1 to get correct part#'s, then order from a dealer. Sorry about that, the photo showed eyes on both ends, so I went with it. Paul
Re: Drag Shocks?
Tr403 is the number I came up with the price is the same
Re: Drag Shocks?
I have the Chris Alston's Vari-Shock, it's Double adjustable and fits in the factory location. I like them a lot but they are expensive. I may be selling them soon if I get a new dropmember that uses coil-overs.
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning. 8.3@168mph 1700+ HP |
Re: Drag Shocks?
What about rear shocks? Mines a 71. Don't mean to HJ thread.
![]() Join Date: Jul 2009
Re: Drag Shocks?
I Installed the new front shock location brackets from cpp that mount to the top of the frame rail to add a little more travel because my truck has drop springs and spindles. Then I called summit and give them the ride heght of the truck and the sent me a set. They work great on the street but I have not been to the track with them installed yet.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ |
