Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-27-2011, 03:46 PM   #426
HotRodGMC68
HotRodGMC68's Avatar
Re: How about some pics of High Performance haulers.
My '68.
384 Stroker Small Block-
Best ET: 13.24@103
HotRodGMC68 is offline   Reply With Quote
Old 12-28-2011, 08:17 AM   #427
djracer
djracer's Avatar
Cool truck Hot68gmc. Have you ran it at the track? How fast is it? Tell us more about it.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 12-28-2011, 05:20 PM   #428
HotRodGMC68
Thanks! So far it's gone 13.24@103 on a pump gas tune and at 5280 ft up. I'm hoping once the suspension is set up for the track and not street it'll dip 12's.. Spins like a motha off the line right now.
It's running a 384 small block, 11.8:1 compression, custom FTI cam, Canfield 217cc/64cc heads, Brodix HV1000 manifold, Quick Fuel 1050 carb, forged bottom end from Eagle/Probe, Hooker headers, 3" manderal bent exhaust system with SpinTech mufflers. Hughes Competition TH350, manual valve body, fwd pattern, Hughes 10" 4100 stall converter. 3/4 ton Dana 60 rear end, 4:10 gears.
Front suspension consists of Moog ball joints, tie rod ends, etc. ECE drop springs, drop spindles, 3/4-1/2 ton conversion, disc brakes. The rear has a custom 4-link with Aldan Eagle coil overs.
The body is all steel. Complete interior.
It's driven on the street to work and back every day and hauls my 3 year old daughter to grandmas house!
Best ET: 13.24@103
Old 12-28-2011, 06:39 PM   #429
HotRodGMC68
forgive the double post.. Here's a link to the Garage Built Rides artical that was done on the truck this year. http://www.garagebuiltrides.com/home...ver-drag-truck
Best ET: 13.24@103
Old 12-29-2011, 01:26 AM   #430
65Pickup
65Pickup's Avatar
Great truck, very aggressive looking, any hp numbers and what tires are you running?
65Pickup is offline   Reply With Quote
Old 12-29-2011, 11:33 AM   #431
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
Tough looking truck HotRodGMC68.
Brandon
Street Car Mafia
limitedstreetoutlaw is offline   Reply With Quote
Old 12-29-2011, 01:21 PM   #432
bigboybodry
bigboybodry's Avatar
sweet ride brother!
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 12-29-2011, 01:22 PM   #433
HotRodGMC68
Thanks for the good words! The tires in the photos are 28x11.5x16 MT ET Streets. I've since gone to a 295x50x16 Hoosier Drag Radial.
Best ET: 13.24@103
Old 12-29-2011, 01:25 PM   #434
bigboybodry
how does it hook with the drag radial and can you leave on the kit
Old 12-29-2011, 01:37 PM   #435
HotRodGMC68
as far as horse power numbers go, it's never been on a dyno.. When we built the engine we estimated it at 490 hp and 508 lb/ft at the crank.
Best ET: 13.24@103
Old 12-29-2011, 01:38 PM   #436
HotRodGMC68
I put the drag radials on it right when our racing season ended this year so it hasn't been on the track with them yet. The nitrous kit came off of the truck and went on my wife's camaro. Never got the chance to run it on the button.
Best ET: 13.24@103
Old 12-31-2011, 10:56 PM   #437
Dinos63
chevy only
Dinos63's Avatar
my 66 prostreeter
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 12-31-2011, 11:20 PM   #438
CoggedBelt75
CoggedBelt75's Avatar
^^Sweet^^
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 01-02-2012, 01:02 AM   #439
limitedstreetoutlaw
Dinos63 that is sweet.
Brandon
Street Car Mafia
Old 01-03-2012, 12:24 AM   #440
Dinos63
chevy only
Dinos63's Avatar
thanks duudes
Old 02-05-2012, 10:02 AM   #441
83gmc4x4
Your truck is now on my desktop! Awsome build, and props for keeping it a DD! How do you like the Spintechs?
1972 Custom 1500 Long Step 250 I6, 4spd
1974 F350 cummins/4x4 conversion (hopefully)
83gmc4x4 is offline   Reply With Quote
Old 02-10-2012, 07:45 AM   #442
Handfull 54
Handfull 54's Avatar
I probably don't fit in with these rocket ships but here is my 54. It's got a 489 with Brodix heads and a mighty Demon 850. Continental 3'000stall converter, turbo 400, and a 9" with 4.56 gears. It has about 500 miles on it and I just drive it on the weekends. I did 95% of it in my 2 car garage. I run 31x18.50x15 MT Sportsmans which seem kind of hard. Will probably go to same size Hoosier radials in the future. There are some outstanding trucks on these pages. I have a few more things to do before I'm done but at least it's on the road. Best wishes to all of you out there.
Handfull 54 is offline   Reply With Quote
Old 02-10-2012, 10:03 AM   #443
thirdstreettito
Resident of Here
thirdstreettito's Avatar
That thing is the sex! Nice!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-11-2012, 12:46 AM   #444
65Pickup
65Pickup's Avatar
Beautiful truck, just badass... love the color. What shifter you running?
Old 02-11-2012, 09:25 AM   #445
Handfull 54
Thanks for the kind words. The shifter is from Precision Performance Products in Cerritos California. My model is the Kwik Shift 1. Each one is built by hand one at a time. I went to the shop and picked mine up. He assembled it while I waited. Great shifter. There are other models and attachments available. I added a piece of 5x7 mirror finish stainless to raise the shifter off the floor. Their web site is
precisionperformance.com. Hope this helps.
Old 02-13-2012, 10:35 PM   #446
bustedknuckles
bustedknuckles's Avatar
update:
84 GMCummins
91 CCSB Dually
american squarebody association
bustedknuckles is offline   Reply With Quote
Old 02-15-2012, 08:46 AM   #447
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Very nice!!!
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 02-15-2012, 10:07 AM   #448
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: How about some pics of High Performance haulers.
That's One Bad Mamma Jamma 5 Window!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-15-2012, 10:13 AM   #449
1Bad62Pro/Street
Talking Re: How about some pics of High Performance haulers.
Not mine but............
Worlds Fastest Pickup Truck! - Fast Freddy's 1966 Pro Mod Chevy Pickup
http://67-72chevytrucks.com/vboard/s...d.php?t=506582
Old 02-20-2012, 01:32 AM   #450
nebdrummer
nebdrummer's Avatar
Lot of work to do yet.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
