Old 08-30-2003, 05:48 PM   #1
ScottH
ScottH's Avatar
Hard starting bbc when hot.
Just picked up a 72 402/400 over the weekend and noticed it barely starts when it gets hot. It starts just fine cold, but hardly cranks at all when warmed up. Any ideas?
Thanks.
ScottH is offline   Reply With Quote
Old 08-30-2003, 05:51 PM   #2
jef5150
Inline 69
jef5150's Avatar
put a heat shield by the starter,my old pontiac did that, i tried replacing the starter,but it still did it
jef5150 is offline   Reply With Quote
Old 08-30-2003, 05:55 PM   #3
jef5150
Inline 69
jef5150's Avatar
Cool pic #1
Old 08-30-2003, 06:02 PM   #4
jef5150
Inline 69
jef5150's Avatar
heres the shield
pic#2
Old 08-30-2003, 06:06 PM   #5
jef5150
Inline 69
jef5150's Avatar
Thumbs up 3
ill get the link ,,,,,good luck,,,,jeff
Old 08-30-2003, 06:07 PM   #6
ScottH
ScottH's Avatar
Thanks! Any idea of where I can get a shield?
Old 08-30-2003, 06:24 PM   #7
jef5150
Inline 69
jef5150's Avatar
you can get them at any speed shop,but heres for moroso type,#74300 http://www.moroso.com/catalog/catego...?CatCode=42022
Old 08-30-2003, 06:43 PM   #8
crazy longhorn
Fabricate till you "puke"
That one confuses this old man.... I have run BB olds, BB caddy, & big inch sb in my truck. a good battery, good set of cables, & a good starter are the ticket. im not tryin to start a fight, but if the fore mentioned parts are in good shape.....I havent seen a problem I have also run headers on the Olds, & the Chev(2 of them in the longhorn)......no sheilds , or remote solenoids....no problem. the 461 Olds ran @ 9.8 on comp ratio, as does the 383 Chev(alum head on the chev helps), but I dont see the problem that many guys have stated......perculated fuel, yes I have seen that problem. Good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-30-2003, 07:01 PM   #9
dinnut
dinnut's Avatar
this may confuse you, but my 72 did it and it turned out my timing and points were off
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 08-30-2003, 07:14 PM   #10
jef5150
Inline 69
jef5150's Avatar
Smile
come on guys,,,he asked for ideas! so i was helping him out,my idea isnt so far out in left field,,,,,,jeff,,,,,
Old 08-30-2003, 07:33 PM   #11
crazy longhorn
No trouble Jeff.....he asked for ideas, & I gave mine ......Im not tryin to "stirr" a problem, but havent seen the problems that MANY guys talk about? crazyL
Old 08-30-2003, 07:46 PM   #12
My old Pontyrat did the same thing. It was Ok after I replaced solenoid. The heat shield does help..so I'm told...with the starter & solenoid prematurely wearing out because of heat. I never used one, so I can't say if they would have made a difference or not.
Old 08-30-2003, 08:35 PM   #13
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
you may wanna lookinto a heavy duty starter too with the heat shield
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-30-2003, 08:39 PM   #14
ScottH
ScottH's Avatar
Thanks for everyone's input. I just got the truck and haven't had the chance to check it out yet. I know the timing was off when I got it, had to advance to spot it from popping (HEI). I got several milk crates of parts, and although I haven't gone through them I did notice an old starter. Oh yea, it has headers also.
The shield sounds like a good way to start, not expensive and can't hurt. Thanks again.
Old 08-30-2003, 09:33 PM   #15
ddsmith
Glowing since 1978
ddsmith's Avatar
The big block 454 in the vette was factory equipped with a heat shield and a hi torque starter. It does make a difference. It absorbs the radiant heat from the headers as long as there is an air gap between the shield and the starter.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 08-30-2003, 11:35 PM   #16
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You'll be best off puting a new starter under that new heat shield too. The damage is already there.
I've lost one starter to my headers, and seen plenty more.
In the newer Grumman delivery trucks with the GM 6.2/6.5, they come stock with the heat shield on them.
Old 09-01-2003, 10:22 AM   #17
HennyM
Definitely do the starter thing. But don't forget to check the timing & advance. Make sure vacuum isn't getting trapped in the hose to distributor & holding the advance to max position. Thermal vacuum switches can do strange things.
'72 Longbed 2WD
Mostly used to hide under from the wife & kids. (But coming along nicely)
Southampton, PA
'87 Chev 1-Ton 4X4
'52 Ford F1 '97 Harley
" No Falls... No Balls ! "
HennyM is offline   Reply With Quote
Old 09-01-2003, 10:30 AM   #18
hgs_notes
GEARHEAD
hgs_notes's Avatar
This happened with mine too. The timing was advanced too far. I turned it back a few degrees and hot restarts are no problem.
HG
hgs_notes is offline   Reply With Quote
Old 09-01-2003, 03:06 PM   #19
MOTHERTRUCKERS
Check to make sure your ground straps are good, a bad ground will overheat the starter also
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 09-01-2003, 05:29 PM   #20
Blue67
Blue67's Avatar
Check the battery cables also
Blue67 is offline   Reply With Quote
