Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-28-2011, 11:20 PM   #1
jb1016
"Oh well, it's a driver."
jb1016's Avatar
new to air tools
For Christmas I got a 100 psi pancake compressor. I've never had air tools before, and I have no idea what this thing is capable of. What are the limitations on a compressor like this? What essential tools should I get to go with it? I already have an air drill and a brad nailer. I'm pretty excited. Any input is appreciated!
Old 12-28-2011, 11:23 PM   #2
BMERDOC
BMERDOC's Avatar
Re: new to air tools
linky no worky
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 12-28-2011, 11:27 PM   #3
jb1016
jb1016's Avatar
Yeah, fixed it. Not sure what happened there.
Old 12-29-2011, 12:01 AM   #4
yousesteers
It will run any air tool just some of them not very long. We have one that we use on trips easy to throw in the back of truck or on trailer with generator. It is handy for airing up tires and using an impact to change tires and such but will not run the impact very long if you need more capacity you can plumb it to a 100 lb air pig and get more volume to run your tools longer.
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 12-29-2011, 02:31 AM   #5
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Air chuck & Gage, tool oil, air blower.
Maybe a stapler & air ratchet.
I like the siphon sprayers for spraying cleaner and the like.
The brad nailer will do well unless used as a machine gun or
on extremely hard woods.
For the compressors health, try not to run it on miles of
extension cord...the shorter (or none) the better.
One good tip is to never place an airtool, that's still on the hose,
on a bench or anywhere the hose can be tripped over.
Disconnect around kids too.
I've had umteen of the little buggers and love them!
ETsC10 is offline   Reply With Quote
Old 12-29-2011, 04:49 PM   #6
jb1016
jb1016's Avatar
Originally Posted by ETsC10 View Post
For the compressors health, try not to run it on miles of extension cord...the shorter (or none) the better.
Why is that? And thanks for the input!!
Old 12-29-2011, 09:50 PM   #7
Notch1988
Notch1988's Avatar
Three tools I use the most are:
1. 1/2" impact
2. 3/8" ratchet
3. Air hammer
Notch1988 is offline   Reply With Quote
Old 12-30-2011, 03:03 AM   #8
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
The motor likes lots of amps to start and run on. Extension cords cut down on the amps delivered to the motor.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 12-30-2011, 11:50 AM   #9
jb1016
jb1016's Avatar
Good to know, thanks!
Old 12-30-2011, 11:51 AM   #10
jb1016
jb1016's Avatar
Originally Posted by Notch1988 View Post
3. Air hammer
Is this the same as an air chisel?
Old 12-30-2011, 12:19 PM   #11
Notch1988
Notch1988's Avatar
Yes... that's the beauty of it, just change the bit and it will do anything.
Old 01-08-2012, 05:18 AM   #12
GRX
GRX's Avatar
Pancake compressors are more for low volume tools like a brad nailer, when just a quick shot is needed. This is why you seem them at construction sites. Tools like air hammers & 1/2 impacts will drain that very quickly. Which is why automotive shops employ compressors with big tanks.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 01-10-2012, 02:14 PM   #13
Cue-Ball
Cue-Ball's Avatar
^What this guy said. A light duty pump and small tank aren't going to work for anything but a very small job. I've got a 6hp, 33 gallon compressor and it can barely keep up when I'm using some of my air tools. When using my 4" cut-off wheel it has to run pretty much constantly, and I have to stop work to let the pressure catch up. Same thing with my air chisel if used for more than a minute or two at a time.
For small jobs like light nailing, taking of wheel lugs with an impact, airing up tires, etc. you'll be okay, but that's about it.
Cue-Ball is offline   Reply With Quote
