Old 12-29-2011, 12:44 AM   #1
CSoliz
Torn between 66 and 78
CSoliz's Avatar
3" drop spindles in relation to the scrub line
I have a 66 C10 with a 84 3/4 ton LCA. I want to run a 3" drop spindle, will this combo put the LCA below the scrub line with 15" rims? If so, what size rim would be needed so it isn't as an issue?
Thanks for any help.
CSoliz is offline   Reply With Quote
Old 12-29-2011, 11:16 AM   #2
Hertzdaddy
Re: 3" drop spindles in relation to the scrub line
Not sure but some local/state ordinances describe scrub line as an imaginary line from the bottom of the rim on one side to the bottom of the inflated tire on the other (measured with the truck on flat ground). The reasoning being that in most cases only one tire will blow. If you are comfortable with this description then I think that 3" drop spindles would not put the lca below the scrub line with a 15" tire, although tire profile will have an effect on this too.
I suppose if you have the truck on its wheels/tires right now then you could pull a string as described above and see if it clears the lca by more than 3".
Hertzdaddy is offline   Reply With Quote
Old 12-29-2011, 11:42 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
It will be close, but should clear, depending on how much drop spring you use. The ballpoint area will be inside the edge of the rim, but barely- you may have issues with clearance there, depending on back spacing of the wheel...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-29-2011, 09:20 PM   #4
CSoliz
CSoliz's Avatar
I wish it was sitting on wheels, it is just a frame right now. Still working on it.
I plan on having 3" springs as well, if I go with 16" rims that should clear up any "maybes", right?
Old 12-29-2011, 09:30 PM   #5
WAAF
look at whats aval in 16" they are getting less and less size choices
WAAF is offline   Reply With Quote
Old 12-30-2011, 12:14 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
He is correct. Before you decide on a rim size make sure the tire size you want is available and/or affordable. I have found that 17's and 20's have the best size and price ratio.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
