Old 12-30-2011, 06:47 PM   #76
Apache63
1# Drobmember in Germany
Apache63's Avatar
Re: My new 1963 SWB 5.3 Vortec Pickup
today was my Garage day since a couple of month , install the new Steering Column and i was really nice to change it , very simple!!
so and here are the picīs , in the 2nd pic is the reason why i changed it into a new column!
next step is to install the power steering , maybe tomorrow!!
Pat
Apache63 is offline   Reply With Quote
Old 12-30-2011, 10:58 PM   #77
Nobby
Nobby's Avatar
Looks Great! I love that wheel....
Nobby is offline   Reply With Quote
Old 12-31-2011, 12:36 AM   #78
allaboutchevelles
allaboutchevelles's Avatar
Looks really good!! So did that new columns wiring harness plug straight in the factory harness with no cuting of wires??
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 12-31-2011, 03:16 AM   #79
Fabian
Fabian's Avatar
Nice work Pat!
1964 Chevy C10 http://67-72chevytrucks.com/vboard/s...d.php?t=470509
1967 GMC "Sancho" built by Del http://67-72chevytrucks.com/vboard/s...d.php?t=516801
1961 Chevy Parkwood
1962 Chevy Impala Wagon
http://www.facebook.com/fabsspeed
Fabian is offline   Reply With Quote
Old 12-31-2011, 11:49 AM   #80
Dinos63
chevy only
Dinos63's Avatar
sweet nice work, still got those wheels ?
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 12-31-2011, 01:14 PM   #81
Apache63
Apache63's Avatar
Thanks Buddy ! ship it baby!!!!
the ugly one and the beast
in and nice
and the problem
the new pitman arm wonīt fit because it is bend and the original one is straight , i used a 1979 Blazer powersteering!
i need help to get the right part!
help heeeelp heeeeelllllpppppp please!!!!!!!!!!
Pat
Old 12-31-2011, 04:04 PM   #82
duallyjams
duallyjams's Avatar
Was the Blazer a 2wd because the 4x4 will not work the sector shaft is different.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-01-2012, 01:42 AM   #83
Captainfab
60-66 Nut
I agree...
However in looking at the pic of the box closer, it is a 2wd steering box, as the sector shaft is threaded and has the nut on it. That pitman arm on the bottom of the pic is the correct one for a 2wd steering box, and should work just fine on your truck Pat. If there is a clearance problem, the box may not be positioned correctly.
Old 01-01-2012, 06:34 PM   #84
Apache63
Apache63's Avatar
Thanks Guyīs , iīll check the clearance!!!
Pat
Old 01-02-2012, 04:51 PM   #85
Fabian
Fabian's Avatar
!!!! Done?
1961 Chevy Parkwood
Old 03-20-2012, 01:57 PM   #86
Apache63
Apache63's Avatar
I used a Ididit Steering Column and i bought a adapter from American Autowire Systems with part #37618 and it works perfekt "plug and play"!!
Pat
Old 05-28-2012, 05:58 PM   #87
Apache63
Apache63's Avatar
i had trouble with water pump , i figured out that she was leaking but i didnīt found the leak at the first sight !
so i had another water pump in my garage (nearly new without the upper water neck)!
a buddy of mine welds an adapter in and now iīve an sender for the Water temperature , next will be install a adapter for the oil pressure !
Pat
Old 06-15-2012, 10:15 AM   #88
Apache63
Apache63's Avatar
One shoot from the "Bottrop Kustom Kulture" last weekend!
Pat
Old 06-15-2012, 10:18 AM   #89
jasonhall
jasonhall's Avatar
Awesome!!!
jasonhall is offline   Reply With Quote
Old 06-24-2012, 01:19 PM   #90
Apache63
Apache63's Avatar
Sitcker from the Bottrop Kustom Kulture !
Pat
