Old 12-31-2011, 04:26 PM   #1
dstarrett
dstarrett's Avatar
cab sound deadening
Any thoughts on sound deadening material inside the cab before carpet goes in? Would roll on bed liner work? Lizard skin rolled on instead of sprayed? Dynamat? (Or similar product) Or just carpet?
dstarrett is offline   Reply With Quote
Old 12-31-2011, 08:03 PM   #2
blackedoutharley
Re: cab sound deadening
The stuff I used was basically bubble wrap packing material that has an aluminum foil covering on both sides. Bought it at a hardware store and it was quite inexpensive.
http://www.acehardware.com/product/i...ductId=1296203
blackedoutharley is offline   Reply With Quote
Old 12-31-2011, 08:47 PM   #3
T2vigil
T2vigil's Avatar
Inexpensive is good. Does anybody know how much difference in sound deadening there is between these and Lizardskin?
T2vigil is offline   Reply With Quote
Old 12-31-2011, 09:26 PM   #4
TopFuel1966
TopFuel1966's Avatar
I got excellent results with Dynamat. You can get it on Ebay in rolls instead of squares. Saved a lot of money buying it that way.
TopFuel1966 is offline   Reply With Quote
Old 12-31-2011, 10:16 PM   #5
awitate
I'm interested in trying mass loaded vinyl. You can get it in 1/8-1/4 inch thickness. You wouldn't have to glue it down. I've heard that dynamat or peel & stick retain moisture so you should probably paint 1st.
awitate is offline   Reply With Quote
Old 01-01-2012, 12:48 AM   #6
rbar
rbar's Avatar
The eastwood version of dynamat is cheaper and was great on the one vehicle I saw.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 01-01-2012, 05:54 AM   #7
losthope
losthope's Avatar
I used EZCOOL sound deadner on my 54 ford,they are a Hamb vendor and alot of guys use and have had great results,super fast shipping.....it doesnt have peel and stick so you just use 3m spray adhesive. reasonable price also.
heres the link:
http://www.lobucrod.com/
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 01-01-2012, 09:51 AM   #8
dthela
dthela's Avatar
12" wide rubber sticky roofant sealer about 10' long at home depot. stretchable, mouldable and waterproof.
dthela is offline   Reply With Quote
Old 01-01-2012, 11:49 AM   #9
coulter
coulter's Avatar
i was kinda thinking bout this stuff to seal up the bottom of my cab... its gotta cut down on the noise to
https://www.getflexseal.com/
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 01-01-2012, 03:31 PM   #10
rbar
rbar's Avatar
I bought a can of that for my house gutters at Bed Bath and Beyond. I would be leary of how well it holds up over time and even though it's cheaper, it's not going to come close to a dynamat tpye product.
1965 Chevy swb 383
