Old 01-01-2012, 05:09 AM   #1
JumboAMONGus
JumboAMONGus's Avatar
heater switches or blank out
i have a 56 military 1/2ton and it dont have heater switches has the blank out ,,i was wondering i found a heater unit to put in it ,but what did they have for a switch if it didnt come with the heater controls ? mine just had a on off switch hanging on the floor and i flip a lever on heater for defrost to heat ? and i looked in pics and googled and still never seen a heater on off switch ?
JumboAMONGus is offline   Reply With Quote
Old 01-01-2012, 05:22 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: heater switches or blank out
The factory "Deluxe " heater had a dash control with cables to operate the venting. Aftermarket units usually were manually operated with either a switch mounted under the dash or a switch mounted in the factory heater control blank
Post a picture of what you have.
Old 01-01-2012, 02:29 PM   #3
oldcouple
oldcouple's Avatar
This type was used as an aftermarket, clamps to bottom of dash,or you can drill a hole in the block off plate. Some types had a bulb inside that lit up when on. Under 20 bucks, do a google search for heater switch.
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 01-01-2012, 02:32 PM   #4
oldcouple
oldcouple's Avatar
The factory one is about 200 and you need the cables as well.
Old 01-01-2012, 04:10 PM   #5
OrrieG
OrrieG's Avatar
The standard heater had a single knob switch in the blank out plate. Deluxe had the three lever type.
Old 01-01-2012, 04:31 PM   #6
JumboAMONGus
Old 01-01-2012, 04:34 PM   #7
JumboAMONGus
the top pic is what the dash looks like now in my delete plate i didnt have a hole for a switch but i found a 55 panel at a junk yard and it has two switches on a factory plate that mounts between the vent knobs ,,im gonna get it tomarrow and i picked up a delux heater control from it yesturday , and it all works only missing one knob
Old 01-01-2012, 04:36 PM   #8
JumboAMONGus
it looks dirty than it is not as bad pitted i havent cleaned it yet ,,,just wondering to leave factory or add the heater controls
Old 01-01-2012, 04:38 PM   #9
JumboAMONGus
it was originally grey the inside i had the body guy paint it in primer so it would be ready for paint all i got wa a dp90 over coat that cost me 400 bucks hahhaa ..
Old 01-01-2012, 04:43 PM   #10
oldcouple
oldcouple's Avatar
I think I have some extra cables, will look if you are interested.
Old 01-01-2012, 04:45 PM   #11
oldcouple
oldcouple's Avatar
I think you can see the delux one in there, I have it converted for AC
Old 01-01-2012, 06:40 PM   #12
Russell Ashley
Russell Ashley's Avatar
You were lucky to score that deluxe heater control from a junkyard. You can get all of the parts to restore it. Those bring a good price on EBay.
Russell Ashley is offline   Reply With Quote
Old 01-01-2012, 07:34 PM   #13
mknittle
mknittle's Avatar
http://www.scribd.com/full/75817434?...ekaw0jyon6pa1h
page 29 go by the blue page numbers also parts for old ones
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 01-01-2012, 08:23 PM   #14
azsnow
azsnow's Avatar
You can get used ones that need restored pretty cheap. I have the original standard heater with the switch in the plate. If your interested, PM me.
azsnow is offline   Reply With Quote
Old 01-01-2012, 10:14 PM   #15
G&R's57GMC
G&R's57GMC's Avatar
The Filling Station sells the levers,knobs, cables etc. check them out at http://www.fillingstation.com
G&R's57GMC is offline   Reply With Quote
