Old 01-03-2012, 09:01 AM   #1
69c10step
69c10step's Avatar
69 Wrecker on SC CL
$1600
http://columbia.craigslist.org/cto/2774782818.html
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
Old 01-03-2012, 10:17 AM   #2
no moa
no moa's Avatar
Re: 69 Wrecker on SC CL
Wish i was closer, i'd love to have another one!
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 01-03-2012, 11:10 AM   #3
Looks like a good deal. I wonder if it's a C/20 with a 1t rear
Old 01-03-2012, 11:14 AM   #4
Lee H
Lee H's Avatar
Looks like the primered over the shop logos? Wonder if you could get the primer off without damaging the logos.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-03-2012, 11:17 AM   #5
RenoKeene
Florida Edition
RenoKeene's Avatar
I'd say you could. I wouldn't mind having one to go with all my other stuff, I could do alot with two big winches.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-03-2012, 05:21 PM   #6
earlthegoat2
earlthegoat2's Avatar
Well I would have looked MIGHTY hard at that one if it was up on CL two weeks ago. As it was I bought my 69 in Myrtle Beach. Columbia would have been a little shorter of a drive.
I really needed a proper truck box though so I would not have pulled the trigger on it. It is in much better hands with someone who will keep it as a tow truck.
earlthegoat2 is offline   Reply With Quote
Old 01-03-2012, 06:12 PM   #7
no moa
no moa's Avatar
Couldn't we all my friend, couldn't we all.
Old 01-03-2012, 06:35 PM   #8
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
It does appear that way with no cab lights and the SRW front end.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 01-03-2012, 07:20 PM   #9
C10 - C90 Bill
C10 - C90 Bill's Avatar
A lot of guys will put 3/4 Ton Wheels on the Front End of their 1-Tons. They will fit fine and look pretty good too, although I personally don't like it that way. Also Cab Lights were not standard on a 1-Ton. Some will have them and some won't. The real way to tell would be by the VIN Number and/or the GVW rating.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 01-04-2012, 07:38 AM   #10
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Thumbs up Re: 69 Wrecker on SC CL
That sure does look like a good deal but the pics are small and not much description so who knows.
Nice to see one all together! I'm used to mine that is in pieces.
That looks like it might even have a wreck master set up on it.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-04-2012, 07:48 AM   #11
That does look like a Wreckmaster. The rear looks like a later wider rear and from '69-on dual rear C/30s came with clearance lamps. The truck isn't bad.
Old 01-04-2012, 09:21 AM   #12
C10 - C90 Bill
Although I really like Clearance Lamps, I've got a '64, '65, '68 and a '72 all C-30's and all with no Factory Clearance Lamps (Cab Lamps), besides the many more I see on the road.
GMC 9500 Fan
Detroit Diesel Fan
