Old 01-05-2012, 04:04 PM   #1
Car'n'Guitars
Car'n'Guitars's Avatar
Tire Help
Is there a way to make the flat tire hold air? It only leaks air out the rim. I'm not trying to make the tire for use on the road just want it to hold air so I can work on it without the truck being so low to the ground. Again not going to use these tires to drive just want them on it while it gets worked on. Also is there a way to clean off the rust on the rims without scratching them? Thanks for all the help you can give.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 01-05-2012, 04:52 PM   #2
xrcr
Re: Tire Help
Redneck advice...... If it's off the bead clean the bead with a sand disk or wire wheel depending on how bad it is. Clean that up and smear some grease around the bead. Put the air to it and seat. Do the soapy water test and if it's bubbling smack that spot with a hammer. This is assumming you don't care about the rims.
xrcr is offline   Reply With Quote
Old 01-05-2012, 05:30 PM   #3
Car'n'Guitars
Re: Tire Help
I like the resealing the bead idea with grease but plan on keeping rims so then what?
Old 01-05-2012, 05:48 PM   #4
donut
donut's Avatar
Re: Tire Help
Take it to a tire shop and get them to re-seat it. If it's bad, they may have a take off for you cheap. That's the easiest way imo.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 01-05-2012, 06:22 PM   #5
Car'n'Guitars
Re: Tire Help
I have an extra unmatched tire thats the same size that I will get put on an extra rim I have if I can't get this rigged up.
Old 01-05-2012, 08:30 PM   #6
bucannon
Salty Sailor
bucannon's Avatar
Re: Tire Help
throw a tube in the tire
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 01-05-2012, 08:46 PM   #7
Car'n'Guitars
Re: Tire Help
How would that work?
Old 01-05-2012, 08:52 PM   #8
bucannon
Salty Sailor
bucannon's Avatar
Cool Re: Tire Help
take it to a shop with a tube of the correct size and tell them to put it in, the tube will hold the air
Savannah, Georgia
Old 01-05-2012, 09:46 PM   #9
Car'n'Guitars
Re: Tire Help
Okay
Old 01-06-2012, 09:04 AM   #10
Keith Seymore
Keith Seymore's Avatar
Re: Tire Help
Agree with all the aforementioned techniques, and can add a couple:
a) If it's a bead leak, you can also try RTV sealer (rather than grease)
b) This is not supposed to work but I've also had some success with "fix a flat" for fixing a bead leak. (Theoretically centrifugal force should cause the the sealer to migrate to the inside of the tread portion of the tire, but I've had this work for bead leaks).
Regarding rust removal - good ole' fashioned elbow grease with sandpaper might be best. You can also try some chemical solutions ("naval jelly", rust removers or muriatic acid) depending on how desperate you are.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-06-2012, 11:42 AM   #11
Car'n'Guitars
Re: Tire Help
K
Will sandpaper hurt or scratch the finish on the rims?
Old 01-06-2012, 01:15 PM   #12
Keith Seymore
Re: Tire Help
Looking back at your picture - are they painted or chrome? I assumed they were painted rallys.
Painted - scuff 'em up and repaint.
Chrome - sandpaper might scratch, but I've heard some guys do good work with steel wool and polish.
K
1979-1986
1986 - 2019
Old 01-06-2012, 02:43 PM   #13
joe231
joe231's Avatar
Re: Tire Help
Alot of the surface rust can be removed with chrome polish.
Sometimes just jacking up the vehicle to get the weight off the tire will allow it to reseat if you have enough air pressure.
Another trick is to wrap a ratchet strap around the circumference of the tire in the middle of the tread and tighten the strap to force the bead out towards the rim. As soon as it stars sealing release the strap. You don't want to over stress the strap. And of course this is easier with the wheel of but can work with the truck jacked up so you can get tge strap around the tire. And don't forget safety! Never work around/under a vehicle without using sturdy jack stands that are rated to hold the vehicle.
Good luck.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-08-2012, 12:47 AM   #14
Car'n'Guitars
Re: Tire Help
Good luck.
I already tried you first suggestion but that didn't work. My neighbor might be able to get me a set of decent tires to hold it for now. But thanks for all the help.
