Old 01-05-2012, 09:28 PM   #1
CC69Rat
CC69Rat's Avatar
Considering a C Notch in my truck - need opinions and input please
I am considering a Notch in my 69. The back is low now but still needs to come down some.
What brand would you recommend? I am thinking Porterbuilt but are there pros and cons by brand? The PB just looks stronger to me. I don't know, never done it before.
What's the best way to cut the notch out? Will a Ziz wheel cut it? Do I need a Plasma cutter or ?? How do you guys cut it?
I'm thinking I will just get the PB Stage 2 kit. I am discussing an ECE notch on another post .. are they ok? I can't find them on the ECE site. Thanks.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 01-05-2012, 09:34 PM   #2
big_al_71
big_al_71's Avatar
Re: Considering a C Notch in my truck - need opinions and input please
If you look in my build thread you can see how we did mine. We installed the mild c-notch from CPP. We cut it with a cutting wheel, the quality of it is great you have to cut some rivets then drill about a dozen holes and bolt it in.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-05-2012, 09:42 PM   #3
big_al_71
big_al_71's Avatar
here are some pictures...
Old 01-05-2012, 09:46 PM   #4
CC69Rat
CC69Rat's Avatar
Dang Al .. What page is it on?
Chad
Old 01-05-2012, 09:47 PM   #5
CC69Rat
CC69Rat's Avatar
Oh, thanks man.
Chad
Old 01-06-2012, 06:23 PM   #6
SCOTI
SCOTI's Avatar
PB's bolt-in notch is 'multi-piece' which helps replace some of the frame strength lost when cutting the notched section out.
CPP also make a thicker, bolt-in, HD unit that's a good choice as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-06-2012, 08:19 PM   #7
fuzzy1nickels
I recently fabbed up my own c-notch from 1/8th" flat stock. I simply took the measurements for my center line. made 2 60* bends and traced it out for a cut template. I could have made it a bolt on, but I was doing it while I was boxing in the frame, seems stiffer than it ever was. Wish I had a pic to post up.
It seems to me that your final purcahse decision should also depend on how far your total drop is going to be. I know you haven't mentioned "slamming" it. But how low is low?
P.S. your cutting tool is going to depend on your level of patience. I have cut my long bed down with a sawz all, just not fun. I finally coined up and bought a plasma cutter, but for that little bit of cutting I wouldn't reccomend buying one. I really think a good angle grinder and cut off wheel might be your best option for that cut, which ever tool you use, make sure the frame is setting nice and level on jack stands. I knocked mine off the jack stands after cutting, it will bend :-(
fuzzy1nickels is offline   Reply With Quote
Old 01-06-2012, 08:23 PM   #8
shawno72
C/10 junkie
shawno72's Avatar
I've used the CPP notch and it is great, plus for less than $100 shipped to your door of eBay, you can't beat that price.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-07-2012, 12:12 AM   #9
leddzepp
Moderator
leddzepp's Avatar
x 2. I am very happy with mine. I have some pics in my build thread.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-07-2012, 01:28 AM   #10
YBNORML
YBNORML's Avatar
X3 I am running a CPP notch in my blazer. I used a zip disc to cut out the notch. It didn't take too long at all. All in all I think it took me about 4 hrs to do the whole job.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-07-2012, 01:44 PM   #11
nds1968
nds1968's Avatar
I went with the PB stage 2 http://www.porterbuiltfabrication.co...-Basic-Kit-799
PB also has a mild notch seen here for $199 http://67-72chevytrucks.com/vboard/s...d.php?t=366945
Here is PB's 2 piece notch http://www.porterbuiltfabrication.co...in-C-Notch-225
I used a grinder with a cutoff wheel to cut my notch Nate
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 01-08-2012, 01:48 AM   #12
MOTOIMPAIRED
MOTOIMPAIRED's Avatar
I used he CCP notch also. Check my build thread..
MOTOIMPAIRED is offline   Reply With Quote
Old 01-10-2012, 12:38 AM   #13
grs
Here is mt sons C-Notch
grs is offline   Reply With Quote
Old 01-26-2012, 09:30 AM   #14
CC69Rat
CC69Rat's Avatar
Wow .. GRS, that one will be laying frame huh ?
Chad
Old 01-26-2012, 10:58 AM   #15
big d's red67
big d's red67's Avatar
I put the PB stage 2 in my 67 last weekend it worked great, I used a sawzaw to cut the frame. Hate those rivets!!
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 01-26-2012, 11:44 AM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
My first choice would be to support or Forum Vendors. If I felt the need to order from a non supporting Vendor, I would look in our Feedback Forum and base my choice on Vendors with the best feedback.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-26-2012, 11:47 AM   #17
CC69Rat
CC69Rat's Avatar
I went with PB I'm thinking maybe sell a kidney or something so I can get the rest of it too. Ahh, .. maybe someday !
Chad
Old 01-26-2012, 11:53 AM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
Good choice. Nate will get you where you need to be.
Articles-
"Refining Sierra"
Old 01-26-2012, 12:39 PM   #19
shawno72
C/10 junkie
shawno72's Avatar
How much is the PB notch??
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 01-26-2012, 12:47 PM   #20
CC69Rat
CC69Rat's Avatar
$199 I believe, not sure. I got the notch and the upper shock bar, and it was $369 shipped. .. somewhere in that range.
I'm planning to get the frame braces, drop trailing arms, and lower shock relocation too (as soon as I can) Nate is talking about bags, maybe Shrader bags .. we'll see what happens. I probably will not be too terribly difficult to talk into it.
Chad
Old 01-26-2012, 02:15 PM   #21
grs
Here is the C-Notch I put in my 87. This c-notch also goes over the top of the frame. I had a quarter inch plate made to give it more strength.
Old 01-26-2012, 03:03 PM   #22
shawno72
C/10 junkie
shawno72's Avatar
I really like the Pb notch, but the cost is double the Cpp notch. But cause Nate's customer service and the fact that he is a forum vendor will ensure that I buy the notch for my 68 from him.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 01-26-2012, 03:24 PM   #23
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by cc69rat View Post
nate is talking about bags, maybe shrader bags .. We'll see what happens. I probably will not be too terribly difficult to talk into it.
do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it!!!
Old 01-26-2012, 03:27 PM   #24
VA72C10
VA72C10
VA72C10's Avatar
I think bags would be great....and bags with schrader valves aren't much more than drop springs...but give you some adjustment if you ever wanted to load anything in the back (can add some air) AND it lets you dial in ride height exactly.....
Old 01-26-2012, 05:59 PM   #25
CC69Rat
CC69Rat's Avatar
You took all my money punk !! Lol .. kidding.
I have to save up for the drop arms, will probably put (pretty much) the rest of the stage two kit on it when I can afford it.
Chad
