#3776 | |||||||||
1 thing at a time is progress.
Re: Project Vitamin C-10
Thanks guys!!
![]() Quote:
![]() Quote:
![]() Quote:
![]() Thanks guys!! Quote:
Got my DOT5 brake fluid in yesterday. Getting ready to bench bleed (on the truck) and bleed the system. I wonder how many leaks I will have?
Alan
Philippians 2:14-16 |
#3777 |
May I suggest only as a word of caution to have a water hose handy when bench bleeding the master cylcinder in the truck, Ask me why ?????
#3778 | |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#3779 | ||
![]() Quote:
![]() Got the brakes almost bled. I used my vacumn pump and gravity to get it done. I want someone to pump the pedal and do a final bleed. I had a couple minor leaks and tightened easily since the threads had oil in them. i heard of nite mares of sealing up SS brake lines. So far so good. NOTE: Don't mix DOT5 with anything other types of brake fluid.
Alan
#3780 |
Nice!
I was going to ask if you had primed your brake lines first. I probably would have used a large syringe and pushed fluid from the top out, but seems sucking it in with a vacuum pump would do the same trick! Why did you go with the DOT 5, any particular reason? It is better for the SS lines?
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#3781 |
Hey Y'all!!
Wow! Finally all caught back up and all I can say is, Alan, you are the man!! Great job!
Just hopin' I live long enough to finish something!!! |
#3782 | |
Thanks Tim. Glad to see ya back at it.
Alan
#3783 |
I wasn't thinking about eating the paint only the mess oil on new paint can be. Ask me how I know LOL
Posted via Mobile Device |
#3784 | |
![]() Posted via Mobile Device
Alan
#3785 |
Well how about having to repaint an entire fender the underside of the hood half of the fire wall , interfender, frame and part of the engine because I forgot to cover the master cylinder and pumped the brakes one time.. Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
#3786 | |
![]() Got a little painting done today. I painted the grill, headlight rings, trim panels and turn signal housings. I also had to repaint the glove box door.
Alan
#3787 |
great work alan.. again...
#3788 |
![]() I had to respray the door trim panels. I used a new clear today that dries in 20 minutes with no heat. It really lays out nice. It's great for small jobs. If I remember right it is Deltron DSC 2000. They also have a 3000 and 4000. To my knowledge so far the 3000 dries a little slower and the 4000 is really slow. I installed the trim panels and was hoping to check the doors off the list as being done. Then I discovered I can't find or hadn't ordered the inside door handle.
Alan
#3789 |
Resistance is Futile
Looks super nice Alan!!
![]() ![]() I'm sanding the 'burb roof, care to join me?? ![]()
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#3790 |
Rollin' Old Skool
^^ i agree, looks nice!
#3791 |
Did you add the p-side arm rest?
I was noticing on a lot of these trucks, only the driver got them. I remember on the one we had when I was a kid being a tad perturbed because I didnt have an arm rest to .... well .... rest my arm on! My truck doesnt have it, and I will be adding it. Why did you have to repaint your glovebox door by the way?
#3792 |
Looking good !!!!
#3793 | ||
![]() Thanks buddy!! Quote:
I had to repaint the glove box due to memory loss. ![]() ![]() Got the glove box door hung, but discovered the stricker is MIA. I guess I will just make one since they aren't available. I thought I might could use one of my old cab thinking the striker would be the same from the Impala to a truck. It wasn't there. Looks like the hole pattern is the same. I'll figure out something. I'd like to see what it's suppose to look like.
Alan
#3794 |
That dash and glove box door sure are looking good! Keep it going together and we will keep cheering you on!
C@rnut001 (Owen) Alaskan Members Check In http://67-72chevytrucks.com/vboard/s...22#post5094422 http://67-72chevytrucks.com/vboard/s...18#post6778618 |
#3795 |
looks great allen, all i can say is your the man
#3796 |
Alan the stricker is only a small piece of medal with a raised portion in it to catch the "button" . I looked at a friends of mine and his looks just like the one on my 57.
#3797 |
Man I haven't checked in forever,looks like its moving along nicely! Also I have become a big fan of speed clear you can do colision damage/spot repairs in one day vs having to wait 24 hours to sand and buff... Looking good Alan!!
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#3798 | ||||
![]() Quote:
I resprayed the inner fenders, radiator support, head light mount panel and cowl screen.
Alan
#3799 |
looks great, i cant make up my mind about the inner fenders and rad. support not sure if i want to go with body color or black.man you and 198 have this stuff down pat.
#3800 |
Hello Alan,, LOL you respray more than I've ever sprayed... LOL
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
