Old 01-07-2012, 04:59 PM   #1
Livrat
Member #1049
Livrat's Avatar
69-72 4X4 front spring and core support brackets
4 wheel drive front spring hangers and core support brackets,
3 pairs and 4 right sides, these fit all 1969 through 1972 4X4's.
Several pairs (only one pair pictured) of front spring rear shackle bushing mounts.
$40.00 per pair shipped in Conus.
$20 each shipped for singles.
$20.00 pair shipped for shackle bushing mounts.
Livrat is offline   Reply With Quote
Old 01-07-2012, 06:35 PM   #2
67chevy4x4c
Re: 69-72 4X4 front spring and core support brackets
Do you have a 4x4 steering box for 69/72?
67chevy4x4c is offline   Reply With Quote
Old 01-07-2012, 06:44 PM   #3
WETOWM
I would be intrested in the best right side passanger front spring hanger you have thanks rich ...
WETOWM is offline   Reply With Quote
Old 01-07-2012, 07:07 PM   #4
Livrat
Member #1049
Livrat's Avatar
Sorry, I do not..
Rich.. I will pick out the nicest one, If your in I will send PM with payment info
Old 01-07-2012, 07:36 PM   #5
67chevy4x4c
I will take the pair of front spring hangers and core support brakets with no paint on them. I will take the pair of front spring rear shackle mounts with no paint on them.
Old 01-07-2012, 07:52 PM   #6
Livrat
Member #1049
Livrat's Avatar
unpainted set sold.
black ones and yellow ones still available, I will dig and make sure I have more rear shackle mounts
Old 01-09-2012, 10:31 PM   #7
Livrat
Member #1049
Livrat's Avatar
found one more nice drivers side, So I still have 3 pairs, 2 right sides, and lots of the rear bushing/shackle hangers left...
Old 01-12-2012, 12:22 PM   #8
Livrat
Member #1049
Livrat's Avatar
All gone..
Old 10-06-2012, 08:51 PM   #9
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
If you come across any more of these I would be interested in a set.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 10-06-2012, 10:17 PM   #10
Livrat
Member #1049
Livrat's Avatar
I may have a set, A 72 4X4 blazer just came into the shop for a conversion to 2WD, As soon as I get it apart I will know the shape there are in. Do you need a set of both the front hangars and rear shackle mounts?
Old 10-06-2012, 10:35 PM   #11
BLAZERMAN
BLAZERMAN's Avatar
Just the front core support, spring mounts.
Old 10-08-2012, 09:19 PM   #12
72 Super
72 Super's Avatar
Rob, are these correct?
http://67-72chevytrucks.com/vboard/s...d.php?t=546681
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 10-08-2012, 11:51 PM   #13
Livrat
Member #1049
Livrat's Avatar
Sorry to say the ones on the Blazer I have in the shop are not in good shape, they are cracked and very thin where the core support bushings go.
Old 10-09-2012, 12:06 AM   #14
BLAZERMAN
BLAZERMAN's Avatar
Thanks for checking for me.
Old 06-29-2013, 02:38 PM   #15
lucky71gmc
Looking for Front Spring hanger radiator support bracket for a 72 Chev or GMC 1/2 ton 4 X 4 front drivers side in front of steering box. Do you still have one for sale? Someone cut my with a torch and rewelded it, must have been in a wreck at one point. Thanks Br.
lucky71gmc is offline   Reply With Quote
Old 06-29-2013, 06:11 PM   #16
WETOWM
If no one comes up with them i have a real nice set
Old 06-30-2013, 12:12 AM   #17
Livrat
Member #1049
Livrat's Avatar
Sorry, I am not able to help you out, those are all long gone.
Old 06-30-2013, 10:22 AM   #18
lucky71gmc
Still Looking for Front Spring hanger with radiator support bracket for drivers side of 1972 Chev or GMC 1/2 4x4.
Old 07-02-2013, 01:05 AM   #19
67ctener
67ctener's Avatar
Do you part trucks livrat?
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 07-02-2013, 10:56 AM   #20
Livrat
Member #1049
Livrat's Avatar
I have been known to.. I do build a lot of trucks and usually end up buying parts rigs because I want something off of them,Those spring hangars posted above were all off of 4X4 to 2WD Blazer conversions that I did.
Is there something you are in need of? I do still have a few items around.
Old 07-02-2013, 11:56 AM   #21
67ctener
67ctener's Avatar
Well I'm in need of a cab. Figured I live around the corner from you so I'd ask. Been chasing them all over the state and just can't seem to find a nice one
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 07-02-2013, 02:49 PM   #22
Livrat
Member #1049
Livrat's Avatar
How bad is the cab you have?
Old 07-02-2013, 03:26 PM   #23
67ctener
67ctener's Avatar
I have 4 as of now. First cab needs inner/outer cowl and rockers etc. Second cab needs pans rockers etc. Third cab inner outer roof skin and bad pillar rot. And last cab is real bad from dash down. Would like to find one that didn't need a ton of work. Just don't have the skills/time/money to fix what I have.
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 07-02-2013, 06:59 PM   #24
Livrat
Member #1049
Livrat's Avatar
I will keep a look out for you although Your cab #1 and #2 do not sound that bad, Are you sure you do not wish to fix/have fixed one you already have?, I have been building these trucks for over thirty years and I can assure you that most any cab you find will more than likely at least need cab corners,foot wells and rocker panels.
Old 07-02-2013, 10:09 PM   #25
67ctener
67ctener's Avatar
Sent you a pm
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
