Old 09-02-2003, 12:56 AM   #1
Dwaynes56&68
Inline six power steering brackets
I am in the process of installing a six pumper in the 69. I need to locate a power steering bracket setup, and have gathered that they are difficult to find. I have also heard you can use nova brackets and van parts. But others are saying the later brackets wont fit right. Sooo, what car or truck will have the right parts? will the 73 up truck brackets work?
Are we there yet?
Dwaynes56&68 is offline   Reply With Quote
Old 09-02-2003, 01:21 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Seems like everybody with any info offered it here....6 cyl PS bracket thread
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-02-2003, 05:42 PM   #3
Brad
Out of the carpool lane.
Brad's Avatar
Where are you at in Oregon?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 09-02-2003, 10:34 PM   #4
Dusti
Not Dusti,just Bob
Dusti's Avatar
Post Brackets
Good luck finding them,What size 6 do you have?I think the 250 and 292 have different brackets.
I did use newer brackets but had to modify them to work.
I used brackets off a newer truck,73 I think.
the lower bracket that holds the upper part of the alternator and holds the power steering pump should bolt to the head,but the newer model would not line up with the old head.
So i cut off the part that bolts the brackets to the head and bolted what was left of the lower bracket to the old upper alternator bracket,bolted the pump and pump bracket to the lower bracket and had to fabricate a brace from the head to the front of the pump.
dont forget the water pump pulley ,you need one made for 2 belts.
Alot of trail and error ,but you can get anything to work if you try hard enough,and seeing the price that the original parts go for helped motivate me also
72 cheyenne super 1/2ton
89 camaro
Dusti is offline   Reply With Quote
