Old 01-09-2012, 11:12 AM   #151
Mattman2010
Mattman2010's Avatar
Re: Project: B.A.D. 1976 K30 CCLB
Looking good man!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 01-09-2012, 12:17 PM   #152
tecky11
damn that loks great, cant wait to see her finished
Truck: 1972 International Harvester 1210
Engine: Caterpiller 3116 220 HP 630 tq
Transmission: Eaton Fuller rt 6610
Axles: Merritor I beam front axle
tecky11 is offline   Reply With Quote
Old 01-09-2012, 01:51 PM   #153
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Wow lots of progress, the polished VC and intake is gonna look great on it!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 01-09-2012, 03:53 PM   #154
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Originally Posted by Mattman2010 View Post
Looking good man!
Thanks!
Me either.
I wish I could have gotten more done but every time you think you have gotten it, you see something else that won't work or isn't right and you have to modify. I'm planning on polishing the turbo compressor cover as well eventually.
Ryan
1969 Chevy milk truck
Old 01-09-2012, 04:45 PM   #155
tecky11
ryan, you are making me look bad. trying t fight the damn engine in the bay and i cant get it angled in just right
Old 01-09-2012, 06:39 PM   #156
FrankieD
FrankieD's Avatar
Nice work, it should be a torque monster. Are you going to have to beef up the frame I know they like to crack by the steering box?
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 01-10-2012, 05:48 PM   #157
Dieselwrencher
Tecky, I've done this once or twice. Getting the engine right where you want it is usually half of the battle. I had to move mine a few times. Wrestling these heavy things can be a pain, but worth it in the end.
I plan on building a plate with a brace that extends to my front cross member to help support that area. I'll post pics when I get that far.
Today I welded up the LH engine mount. I have to make a few more cuts and drill a hole and it should be done. I'll post pics tomorrow.
Ryan
Old 01-11-2012, 04:52 PM   #158
Dieselwrencher
Got the LH mount finished up this morning and installed back on the truck. I then put a dummy trans cross member in place and jacked the truck up and removed the jack stands from under the engine. I have been worried that the weight would sag my front springs and kill my clearances. I sat the truck down and it didn't settle much. I then bounced the crap out of it, and it's good to go. Everything I was worried about is just fine.
I then moved on to start the modifications to the front cross member. I thought about hacking the rivets and building a new one, but decided I'd concentrate that time on the engine cross member because I know that'll eat up the most of the time any way. I'm going to add a piece to the top and bottom to follow the original cross member's lines. Plus it will be plenty strong as well. Then I'll have to decide how I want to do the steering box brace.
Ryan
Old 01-11-2012, 05:01 PM   #159
madcow75
madcow75's Avatar
Is it just me or do you have negative arch on those front leaf springs? I think you may need a set of 5 leaf 1 ton stock leaf springs with that motor.
madcow75 is offline   Reply With Quote
Old 01-11-2012, 05:06 PM   #160
Mattman2010
Looking good man!
Build Thread
Build Thread
Thread
Old 01-11-2012, 07:35 PM   #161
Dieselwrencher
These are stock springs and that's how they are stock. They're rated for 1400lbs each. Those springs jad negative arch with no engine in them. You can kind of see it n this pic. That's the only pic I seem to have showing it.
Ryan
Old 01-11-2012, 07:36 PM   #162
Dieselwrencher
Looking good man!
Thanks Matt!
Ryan
Old 01-11-2012, 09:17 PM   #163
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
My K30 came with 9 leafs in the rear with 2 overloads and 4 leafs in the front with just a slight positive arch with or without a 454 sitting in it. It was a cab & chassis model and it also has the camper special badges on the cab so I guess that's why it was so beefed up.
The truck keeps looking better and better man!
Could you have torched the rivets out of that front cross member, slid it forward then re-drilled and bolted it in place?
Tony
Old 01-11-2012, 09:40 PM   #164
Dieselwrencher
I was originally going to buy 4 leaf fronts for this. but then I rode in a truck with a BBC and 4 leaf springs. My wife would never drive this thing if it rode like that! So I figured I'd go with the 3 leaf and see what it does. The 3 leaf springs can hold a BBC and a 8' Western snow plow for years, so I think the extra 300lbs of the cummins won't bother them too much.
I thought about that on the front cross member too. But the problem with that is I'd have to put it in front of the steering box bolts and then there goes my support in that area of the frame. That's why I decided to leave it in the original location and modify it.
Ryan
Old 01-11-2012, 09:53 PM   #165
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Oh ok I'll have to see what you're going to do for your bracing up there.
Tony
Old 01-11-2012, 10:04 PM   #166
Dieselwrencher
I haven't quite figured it out yet either.
Ryan
Old 01-11-2012, 10:05 PM   #167
tecky11
looks pretty damn good ryan
Old 01-11-2012, 10:12 PM   #168
yousesteers
On my Crew with the cummins it originally had a 350 I measured the frame to the floor with the 350 in, then no motor, and the cummins in and there was less than 1inch difference in all 3 measurements and about a 1/4in between the 350 and the cummins it was about 400 lb different by the specs so that less weight than me and one of my buddies sitting in the front seat. I am going to put new springs on but mine the bushing are completely shot
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 01-12-2012, 05:43 PM   #169
Dieselwrencher
Today I continued on the front cross member. I was making great progress until I ran out of mig wire. So I cut out templates for the pieces I need to cut out to weld in place. Hopefully tomorrow I'll get it done.
Here's a pic of what this truck would look like with big meats.
It was a bad idea, cause it'd look bad azz!
Ryan
Old 01-12-2012, 11:56 PM   #170
rs72z
rs72z's Avatar
Your build is coming along nice.
What auto trans would you use on a cummins swap?
rs72z is offline   Reply With Quote
Old 01-13-2012, 12:03 AM   #171
tecky11
it does look great
Old 01-13-2012, 03:28 AM   #172
Dieselwrencher
It depends how much money you want to spend really. Ford 4R100's are real tough trannies and work great behind them. However, you'll have about $5k in one before it's done. GM 4L80E's will work too, but you still have to buy an adapter plate and a controller. I like the 47RH's because they can be directly bolted to these engines using a dodge engine plate. You have to use 2 toggle switches or vacuum switches to control over drive and lock up. I'm going to put both on mine and will post up when I do so. I'll have all the good parts in this trans except billet shafts but it'll still be a super strong transmission.
it does look great
Thanks Toby!
Ryan
Old 01-13-2012, 09:38 AM   #173
tecky11
once we both get our projects done will have to play tug o war :0 and thank you for the incenteive to keep going ryan
Old 01-13-2012, 02:53 PM   #174
Dieselwrencher
Tug o war is done on a 300ft track! I used to hook trucks all the time. It's not all about power for sure. 2wd trucks don't stand a chance most times.
Ryan
Old 01-18-2012, 03:47 AM   #175
Dieselwrencher
Over the weekend I didn't get as much done as I would have liked to. I had to make some repairs to the shop, and we had some family stuff to attend to. Here's what I've gotten done lately.
I was curious how the turbo was going to fit over there and here is what it looks like with a S362 on it. I plan on running a HX35W as long as the turbo is rebuild-able.
Ryan
