Old 01-09-2012, 04:48 PM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Need to replace a bent axle
I did some searching around and im trying to figure how many splines are on the axle besides taking it apart. I have a 12 bolt in my 61. Im not sure if its the original rear.
I have seen number like 28 and 30 splines. Is there a way to tell without pulling it apart?
Steve
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-09-2012, 05:13 PM   #2
padresag
Re: Need to replace a bent axle
if you are not sure if it is the original rear , how is any here supposed to know?
that leaves you to taking it out to be sure, otherwise you are just guessing.
ron
padresag is offline   Reply With Quote
Old 01-09-2012, 05:59 PM   #3
61_FL_Apache
Who Me?
You have a point there.
Steve
2001 Blazer 4D 2WD
Old 01-09-2012, 07:38 PM   #4
63sbssbbw
UCA63
63sbssbbw's Avatar
A good starting point would the #'s on the outside of the axle tube.
6 lug or 5 ?
Does the panhard bar mount come off the tube or the pumkin?
The iffy years should be '63-'65?.
Even with all this info it still could have been changed.
Like Pad said ,we'd still be guessing!
You're gonna have to replace it...so just pull it!
All in all it's a pretty easy task.....Unless it's your DD lol
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 01-09-2012, 09:01 PM   #5
61_FL_Apache
Who Me?
6 lug or 5 ?
T
Its at a shop right now so I cant get numbers of it.
6 lug and panhard bar mount is on the pumpkin.
When it comes back with the tranny rebuilt it will be my DD.
Steve
2001 Blazer 4D 2WD
Old 01-10-2012, 01:52 AM   #6
Captainfab
60-66 Nut
If the panhard bar mount is on the pumpkin, then it is a '65 and newer, which have 30 spline axles. Although I would still recommend pulling the axle to verify.
Old 01-10-2012, 09:05 AM   #7
61_FL_Apache
Who Me?
Would that range be from 65-72? Im not sure when the leaf springs came in at.
After some more thought, this rear came from a wrecked truck. It must have been bent in a wreck then salvaged and bought again. It has written on the pumkin 21k which I assume was the milage when salvaged. Who knows when that was done.
Thanks again for the help.
Steve
2001 Blazer 4D 2WD
Old 01-10-2012, 12:05 PM   #8
63sbssbbw
UCA63
63sbssbbw's Avatar
'65-'69 (and some early to mid '70).
'71 and '72 are 5 lug and have shorter axles.
Yes,leaf springs could be had in our trucks,the last year for coil sprung was '72
T
member#7816
'61 GMC in progress
Old 01-11-2012, 01:09 AM   #9
Captainfab
60-66 Nut
Correction. Starting in late '70, the differentials were actually 1.5" wider overall than the early '70 to '63 12 bolts. So each axle is aprox .750" (3/4") longer. Yes the 5 lug wheel bolt pattern did start in '71.
T
Old 01-11-2012, 07:21 AM   #10
63sbssbbw
UCA63
63sbssbbw's Avatar
Yes, Cap't you are correct,WTF was I thinking,Esp. when this is something that I KNOW.!
Ummm,my data entry device(finger)was not calibrated correctly....LOL
Thanx for the save Cap't
Trent
member#7816
'61 GMC in progress
Old 01-12-2012, 12:27 AM   #11
Captainfab
60-66 Nut
No problem....I have those moments too
