Old 01-09-2012, 07:33 PM   #1
69C-owner
14 bolts's in 67-72 C-Series???
Anyone runnin one of the big boys in their truck?
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline   Reply With Quote
Old 01-09-2012, 11:16 PM   #2
Junkpyl
Re: 14 bolts's in 67-72 C-Series???
What are you trying to figure out? Will it swap? I have a 72 C30 cab chassis that I swapped a 14 bolt into in place of the eaton. It was a direct swap except for the shock mounts and a little finagling with the e brake cables. Coil sprung trucks will require new pads in place of the leaf perches. I don't know about the GMC version with the leafs if it will be a direct replacement or the possibility of moving the mounts. Hope this helps
Junkpyl is offline   Reply With Quote
Old 01-10-2012, 12:25 AM   #3
1972K20
1972K20's Avatar
I replaced my Eaton with a 14 Bolt and it's the best thing I did. You can't get parts for the Eatons. 14 Bolts are a lot more common.
1972K20 is offline   Reply With Quote
Old 01-10-2012, 04:07 PM   #4
kwmech
Same thing here, replaced the eaton with a 14 bolt and 3.42s in my longhorn. Didn't have to move the spring seats, but had a little fabrication with the shocks and parking brake cables
Old 01-10-2012, 04:59 PM   #5
69C-owner
Is an "Eaton" a 12 bolt? If not how do I know if I have a Eaton or not?
1994 GMC Sonoma
Old 06-18-2013, 01:23 AM   #6
69C-owner
Ttt
1994 GMC Sonoma
Old 06-18-2013, 01:30 AM   #7
1972K20
1972K20's Avatar
I can't remember the number of bolts on the inspection cover, but they have a "drop out" style third member kinda like a ford 9".
Here's a pic for reference:
Old 06-18-2013, 01:45 AM   #8
69C-owner
So it has bolts on each side right? The inspection cover on the rear and the 3rduse member on the front
1994 GMC Sonoma
Old 06-18-2013, 02:11 AM   #9
1972K20
1972K20's Avatar
Yes
Old 06-18-2013, 02:15 AM   #10
69C-owner
Well thats cool, didnt know those existed, if they were easier to get parts for id b on the hunt for one, already looking for too many hard to find parts already though
1994 GMC Sonoma
Old 06-18-2013, 09:42 AM   #11
farmall
farmall's Avatar
What is the U-Joint situation? I just stripped an 82 C30 front and rear to swap into my 71 C30 Dually. I am going to do the whole crossmember swap in the front and change out the rear. Shocks are obvious but NAPA shows different #s for the U-Joint.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 06-18-2013, 09:09 PM   #12
haysonj
haysonj's Avatar
Here is mine came from a 73 one ton
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 06-18-2013, 10:14 PM   #13
Don Quixote
Don Quixote's Avatar
For years, I ran a 14 bolt SF that I just swapped out in favor of the 14 bolt FF. I am letting someone else finangle the E-brake cables but even with the SF, I have to use conversion u-joints as I have the heavy duty driveline. If that's already done, it's a bolt-on. Even the SF was a good call but I pull a heavy trailer and where it had held up well, I just felt safer with the full-floater.
In short, it works and works very well.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
Old 06-18-2013, 11:53 PM   #14
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I run a late model 11.5" 14 bolt in my k20. The extra width and strength is only a set of perches and shock mounts away.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 06-19-2013, 08:55 AM   #15
Redline novdog
Redline novdog's Avatar
I'm in.I acquired a used "75 FF 14 bolt for free.Had been sitting for years.I had to throw away the drums ,backing plates,shoes wheel studs,etc... I hear that disc brake conversions on these are cheap and plentiful. I haven't gotten around to measuring width difference between '67 12 bolt and the 14 bolt. Mine won't be a bolt in with coils and track bar. I'm always looking for info,so if anyone has more please pile it on. Good thread!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 06-19-2013, 08:53 PM   #16
dennislbrooks
dennislbrooks's Avatar
I used 9.5 14 bolt from a 90 SS 454 in my 67 K10. relocated perches and used front gm 10 bolt shock mounts. Made a 6 lug from 5 on 5 with hub centric 1.5" spacers.
dennislbrooks is offline   Reply With Quote
Old 06-20-2013, 12:07 AM   #17
StepinNJ
TuTone Silverado
StepinNJ's Avatar
13 Corvette GS vert
13 Ram Laramie Longhorn
11 Wrangler Sahara unlimited
08 300
76 El Camino
67 Bel Air sedan
63 Corvette SWC
08 HD Road King Classic
68 HD Golf car
StepinNJ is offline   Reply With Quote
Old 06-20-2013, 01:46 AM   #18
lowrollin70gmc
Too many projects
You can also use a 9.5 14 bolt out of a K2500 (light duty 3/4) as they are a little wider and are six lug already.
Andrew
Old 06-20-2013, 09:43 AM   #19
Don Quixote
I'm sitting on an 8 lug 9.5" if you might be interested. The 8 lug is kind of rare and I ran it for years on my 72 without issue. I just upgraded to the 10.5"
Old 06-21-2013, 02:18 PM   #20
StepinNJ
TuTone Silverado
StepinNJ's Avatar
Why is it a 14 bolt? I see 10.
13 Corvette GS vert
08 300
76 El Camino
67 Bel Air sedan
63 Corvette SWC
68 HD Golf car
Old 06-21-2013, 05:41 PM   #21
1972K20
1972K20's Avatar
Post #12 shows a 14 bolt. It does have 14 bolts on the inspection cover.
Old 06-21-2013, 07:54 PM   #22
Bigdav160
Bigdav160's Avatar
The two other pics are Eaton axles. I think one has it's cover installed upside down.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
axle, bolt, corporate, rearend, yoke
