01-10-2012, 10:27 AM | #276 |
Re: my 86 Backhalf'd SWB c10
looking good son! crack the whip on that boy!!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
02-06-2012, 05:24 PM | #277 |
the truck is looking awesome, i love those wheels, id leave them how they are i think itll really pop against the color you picked, but awesome build, cant wait to see more
02-06-2012, 07:11 PM | #278 |
looking good bro....
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... |
02-07-2012, 10:38 PM | #279 |
Thanks guys more pictures coming soon! inner fender and more body work!
My build thread. Boy what did i get myself into! |
11-05-2017, 09:41 PM | #281 |
Back from the dead
I'm doing a cammed LS motor with all the Edelbrock EFI goodies Built 4L60e Building a fuel cell to fit in the rear of the back half more updates to come soon!
11-12-2017, 06:48 PM | #282 |
11-18-2017, 07:09 PM | #283 |
Fuel cell tacked together
I put a sump to help starvation of the fuel pump we'll see how it works. The way I have the sending unit it is just below the empty mark. I still need to weld on the flange for the sending unit and fuel pump. the sump was an afterthought it was a real mother to weld it in there
12-07-2017, 06:07 PM | #284 |
Here is a little update, I was able to get the motor accessories on. I ended up changing the motor color to titanium to match the budnik wheels ill be ordering. I think the warmer color looks great with the brown color.
accessories are from March Performance, the custom series pro-track, I added the billet alternator fan, that will be painted black and the A/C compressure will get a coat of the titanium.
12-10-2017, 12:23 AM | #285 |
Intakes stripped and repainted with Cerakote, along with the coil covers. I think ill do some satin black on the covers and intake "Edelbrock" and the lines on the coil covers
I had to notch the coil covers to fit around the alternator. The intake is just set on there to see how it looks.
12-17-2017, 04:25 PM | #286 |
shot of the accessories, I went with these because they were affordable, but they brought everything lower and having all new components for a piece of mind.
01-17-2018, 12:02 AM | #287 |
Small update I am waiting for my updated motor mounts from Porterbuilt.
I was able to get the steam ports all re-routed with stainless hard lines into the top of the water pump. this was a slight challenge with the Eastwood pro flare tool you need about 1.5" of straight tubing to create the flare.
03-30-2018, 01:24 PM | #288 |
Its been a while a little update I reinstalled all of my suspension I went to install the motor and the transmission was hitting the tunnel pretty bad so instead of messing with the motor mounts I just decided to make a new taller tunnel giving me plenty of room even if I decide to do a 4l80 in the future.
The tunnel is just about in a few more fitment things to clean up and get her welded in. In the process of installing the motor I also scratched my firewall, this got me thinking of updating my color choice.
04-18-2018, 01:41 PM | #289 |
Update!
I got the motor in! the trans tunnel worked I have a ton of room! the motor fit no problem. The steering just cleared the headers I'm so glad they fit they are mid-length Headman C10 LS swap headers. Fuel cell brackets have been cut and broke. I will bolt these to the bottom sides of the frame rails for easy removal of the fuel cell if needed. I have started the process to flush mount the booster/master cylinder to the firewall since I put a nice scratched in it. Its been a pain in the ass the Brake pedal/booster support inside the cab is offset to one side, I will basically have to cut is all back and remake the booster side. more pictures to follow as I work on it. I will smooth the firewall on the driver's side and maybe do some bead rolling work.
04-23-2018, 11:05 AM | #290 |
Update
Well, I was able to get the booster/master cylinder in place. This seem to be uncharted territory, I see a lot of people with flush mounted boosters just no info on how they do it. I tried to keep mine setup like the factor system and location. The stock bracket is more in line with the steering column, which mounted the booster off centered. I cut off the end of the old booster support which did not line up at all with the flush mounted booster. I then offset it and welded it to the original support bracket. I plan on supporting the lower column from inside the truck, I ordered a boot for the exterior to keep everything looking clean. The firewall will be re-skinned with some nice bead rolled panel. The last picture is just a picture of the floor in primer, no seam sealer or bodywork.
My build thread. Boy what did i get myself into! Last edited by draggin86; 04-23-2018 at 03:47 PM. |
04-26-2018, 06:19 PM | #291 |
Im waiting on a few things for the fire wall, i was able to get the mounts tacked on the fuel cell and rivnut it to the underside of the frame. The rear longer mount was to tall so i will have to design it and cut another then add it to the fuel cell. Now i can start the hardlines to the motor and figure out the full neck.
05-25-2018, 12:02 PM | #292 |
Good work! Glad to see that you got it moving forward again. Good updates. I wasn't on the forum when you started this project, but I've enjoyed reading through the build thread.
06-22-2018, 02:59 PM | #293 |
Thanks, man! I will have some updates again soon, I have to get some projects done around the house.
01-13-2020, 12:18 PM | #294 |
Formerly- 1972SuperCheyenne
Looking killer man. any progress on this one?
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Tags |
air bags, air ride, back half, dropmember, porterbuilt |
