Project 7dos
Bagged - Key to Low Ride Height
Hey guys,
I will be bagging my truck soon and need something splained to me. I don't want the truck to lay rockers, I want it low though. More importantly, I want the actual ride height to be low. Take the below truck (BIG AL's) I want the truck to ride at this height, not be aired out at this height. Does that make sense? In other words, I don't want the truck to have to ride at a height that doesn't look as good as the below truck does. Now I have no idea if this is Big Al's aired out height or not. But what would it take to be able to ride at this height? I don't want to go to crazy with the frame mods, and I know I most likely will have to remove the inner fenders. I plan on running 18x8 and 20x12 wheels. Thanks for all the help! BTW Great looking truck big al
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 Last edited by chevjayfsd; 01-12-2012 at 12:05 AM. |
Project 7dos
Re: Bagged - Key to Low Ride Height
Here is the truck as it sits now... No notch no nothing.
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 Last edited by chevjayfsd; 01-12-2012 at 12:11 AM. |
We make a Mild Dropmember kit that will give you that ride height.... but doesn't lay the frame on the ground when deflated.
You will have to mod the front inner fenders and also raise the bed floor about 4 inches. If you would like more information, shoot me your number in a PM and I can give you a call to dicuss all the options. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
67-72 parts collector,…
![]() Join Date: Nov 2002
Big Al's truck is air'd out in that picture.
The problem is the stock front crossmember. They are too close to the ground to drive them that way. Give Porterbuilt a call. He has exactly what you need to accomplish the ride height you want. Posted via Mobile Device
Yes, Nate is the man!! In a month I will being getting a new truck and one of the goals is to be able to drive the truck extremely low. Nate helped me come up with a plan to do that.
C/10 junkie
Subscribed.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
Project 7dos
Damn... Had no idea I would need a dropmember... I thought most of my work would be in the rear, but you're right, my front member right now is about 5 inches off the ground...
Anyone know what Big Al's truck looks like a ride height?
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
Project 7dos
I've PMed him and requested that he post pics of his ride height here.
I could be wrong, but from experience I would say that the pic you posted of Al's truck is setting on the inner wheel wells in the front and then bottomed out on the notch in the rear.
There could be a little more room gained in the front by modifying the inner wheel wells... but you will need to keep an eye on lower control arm to ground clearance. You could drive the truck 2" higher than that and would probably only rub on occasion with normal driving (normal means like a responsible adult... not sure if that's how everybody defines it). If you want to drive at that height.... there's a lot of work to do. Nate
#10 | |
C/10 junkie
#11 | |
needs more $$$
1970 2wd Blazer |
#12 | |
In that picture the truck is completely aired out and it is on the bumpstops front and rear. My truck has tubular arms in the front and a small cnoth in the rear. In order to go lower the next step would be a drop member, no inner fenders and a step notch in the rear. First picture is aired out next two picts are at a safe ride height technically I could go about an inch lower to drive it but as already mentione the front cross member is really low. I hope this helps....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
In the last picture the front is at it's limits pretty much it has maybe about 1 1/2 travel the back could go lower about 2 inches and still be able to drive it.
Project 7dos
Awesome! Thanks Big Al, beautiful truck.
Big Al's ride height is just right where I want to be.... Although, he has 20's in the front, so i need to figure out how that will affect me...
#15 | |
Thank you!!!! I can take more pictures for you if you need me to...
#16 |
![]() Join Date: Oct 2009
Big Al. Where is your tank and air compressors located? I do not want to place them behind my rear seat. Kinda tight on room? Any pics or advice would be appreciated! I am nervous about finally writing a check for all the parts
Posted via Mobile Device |
#17 |
Project 7dos
Another question... What advantages are gained when using tubular arms vs. stock arms? I ask this because, if my wheel wells are the limiting factor, and I want to be right at where Big Al is aired out and at ride height, why would I spend the coin on the tubular arms, when they aren't the limiting factor?
#18 | |
My valves/tank & compressor are under the bed in front of the right rear tire... Checkout this picture it kind of gives you an idea.
#19 |
I bought them because of several reasons:
Better looking, lighter and I beleive stronger...
#20 | |
needs more $$$
Unfortunately, this won't work with the blazer since it has the rocker boxes in that location. I've been trying to think of something too to get the tank out from behind my seat, but coming up short. My only plan that's somewhat feasable right now is getting 2 3 gallon tanks and mounting them on the sides of the gas tank under the rear, but they may show from the side due to the body coming back up towards the bumper.
1970 2wd Blazer |
#21 | |
Project 7dos
![]() Quote:
#22 |
You can use the dropmember with your stock arms to get lower than Al's. That is a great looking truck, Al.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#23 |
I was to understand that some tubular arms like cpp [I think] would give you a inch or alittle less when aried out
#24 |
C/10 junkie
Here is a good deal on a set of lower control arms.
http://www.ebay.com/itm/300648815916...84.m1438.l2649
#25 |
I'd say definitely do the drop member or Z the front and the c-notch to the rear. In either case, money will be spent...but I will say it pays off
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
