Old 01-09-2012, 07:39 PM   #1
84chevy4x4
84chevy4x4's Avatar
3/4 ton springs vs 1 ton springs
Ok heres the deal. Im running an 84 chevy 3/4 ton 4x4 and it had the original 3/4 ton springs under the rear end with a 4" lift block. Both stacks of springs had some busted leafs so i scrapped an old 1 ton c30 chevy and took the springs out of it. I took the correct leafs out of the 1 ton stack and matched them to my original ones and threw them under my truck. I set the bed on the frame and it looks like it has way more then 4 inches of lift. My question is do the 1 ton leafs have a higher spring rate or whatever? The picture is with only a 4 inch block out back abd some 4 inch springs up front.
1984 Chevy K20 work in progress
1977 Chevy C30 Dump
1979 GMC 35 4x4 Dump
1969 GMC 1500 Rat
84chevy4x4 is offline   Reply With Quote
Old 01-10-2012, 09:07 AM   #2
duallyjams
duallyjams's Avatar
Re: 3/4 ton springs vs 1 ton springs
I always thought that the only difference was how many leaves were in the pack and the over load.You got me don't know.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-10-2012, 11:15 AM   #3
modblacksmith
modblacksmith's Avatar
I resently just found out that theres several diffrent spring rates and diffrent arches within the same model of truck. I found this out when I was going to buy reproduction stock leafs for the front and rear of my truck. Found this out again when I went to the junk yard to pull a set of 56'' springs for the rear of my truck.
Professional hot glue and pop cycle stick engineer.
72 K/20 soon to be C/10, 454, Th400, 9” rear.
01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler.
78 Bahner 19’ jet boat, 460 Furd turd.
modblacksmith is offline   Reply With Quote
Old 01-10-2012, 09:30 PM   #4
84chevy4x4
84chevy4x4's Avatar
yeah i thought the same thing duallyjams. maybe these 1 ton springs have more arch in them? im not sure but i ordered a set of the degree shims for under a 6" front spring for the chevy today. we'll see how it sits after i put the 6" front springs in it
1977 Chevy C30 Dump
1969 GMC 1500 Rat
Old 01-10-2012, 09:49 PM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Yep you're exactly right. To the OP, you might be able to remove a leaf or two to try and get the truck to sit lower to be more level.
Ryan
1969 Chevy milk truck
Old 01-11-2012, 04:19 PM   #6
84chevy4x4
84chevy4x4's Avatar
heck no! i was just curious as to why it sat so high with only the 4" block. The higher the better haha. i was going for 6" suspension and 3" body for this truck. im going to have to jack the house up to lol not much room left lol as you can see.
1977 Chevy C30 Dump
1969 GMC 1500 Rat
Old 01-11-2012, 04:21 PM   #7
Dieselwrencher
Ryan
Old 01-11-2012, 09:58 PM   #8
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
I would stay away from a body lift at all cost. I'd go all leaf! BL cause a whole mess of headaches.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 01-12-2012, 07:29 AM   #9
84chevy4x4
84chevy4x4's Avatar
I understand where your coming from 100% but im 16 and this truck is a budget build. I already have the body lift and its the highest i can go without messing with my driveshaft geometry and all that fun stuff.
1977 Chevy C30 Dump
1969 GMC 1500 Rat
